New DVDO iScan Duo [2.0 firmware released] - Page 101 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
Old 02-06-2012, 02:08 PM
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
Not sure if this have been mentioned in this thread before, but if you change the display on either of the 2 video outputs. The saved profile seems to reset back to the default. At least that what occurs on my unit. Luckily for me, I always back up my profiles and put all of the values down in a separate spread sheet.
avsform1 is offline
Old 02-08-2012, 05:29 AM
magicj1's Avatar
Quoted: 67 Post(s)
Would anyone have a set of RS232 codes for the Iscan Duo. I am looking for:
HDMI Audio.
HDMI Video
Letterbox
Night
Day
I have followed the DVDO Iscan Duo Serial Automation Protocol, but could just do with checking my work.
Here is an example.
Night:
STX 30 05 C4 NUL 1 NUL 0 converted to \\02\\33\\30\\30\\35\\43\\34\\00\\31\\00\\03
magicj1 is online now
Old 02-08-2012, 11:11 AM
mjf_uk's Avatar
I presume you just missed it out on your post, but you are putting "ETX" at the end, right?
mjf_uk is offline
Old 02-08-2012, 12:03 PM
magicj1's Avatar
Quoted: 67 Post(s)
Hi mjf
x03 at the end is EXT
\\x02\\x33\\x30\\x30\\x35\\x43\\x38\\x00\\x30\\x00\\x03
STX 30 05 C8 NULL 0 NULL EXT - mosquito noise reduction - off
this one works:
\\x02\\x33\\x30\\x30\\x35\\x34\\x43\\x00\\x38\\x00\\x03 - hdmi 2
9. ASCII to Hex Conversion Table
ASCII HEX
0 $30
1 $31
2 $32
3 $33
4 $34
5 $35
6 $36
7 $37
8 $38
9 $39
A $41
B $42
C $43
D $44
E $45
F $46
- $2D
+ $2B
. $2E
STX $02
ETX $03
NULL $00
SPACE $20
I really can not get my head round this. I have got some codes that work, and can change the values to suit over codes which again work, but others won't.
Old 02-08-2012, 02:45 PM
kucharsk's Avatar
Quoted: 1263 Post(s)
Liked: 685
I've had the following three issues occur on my AVS-sourced Duo in the past few weeks and wonder if they're glitches or something I should contact DVDO about:
1) Once I came home to find the unit in a loop with the front LED cycling blue, green, blue, green, etc. I had to hard power cycle it and it was fine.
2) I was watching HD and saw small horizontal black lines on edges like you used to see on some programs sent via analog satellite when the receiver was bandwidth-limited. This time, a soft power cycle fixed it.
3) If my Oppo BDP-95 is turned on when the Duo is set to any other input, the video will be a solid green screen when I switch to the Oppo's input unless the Oppo does something to change resolution (listen for the relay clicks from the Oppo.) I assume this one is an HDCP issue as the fix here is to hit "stop" on the Oppo, but I thought HDCP would resume every few seconds?
kucharsk is offline
Old 02-08-2012, 04:01 PM
magicj1's Avatar
Quoted: 67 Post(s)
I would like to know how you contact DVDO? I have emailed them at least 3 times now and they never get back.
Any ideas?
I am UK based
Old 02-08-2012, 05:57 PM
praz's Avatar
Liked: 26
Any ideas?
I am UK based
Same here. I have also called. Goes to voice mail and no returned calls. Seems these products are sold with absolutely no support.
praz is offline
Old 02-10-2012, 09:35 AM
cwt
cwt's Avatar
Liked: 32
Never had No1 with mine kucharsk usually just blinks blue while it reads the display edid then locks on with a solid blue .green means an unsupported signal in the manual ? No idea on No2 ;is edge enhancement ;mosquito nr off ?
No 3 sounds like you may have the other input with a higher priority ? I am getting in the habit of switching off sources with conflicting edids before a new source is switched on ;different from my old 4x2 matrix switch but a necessity probably
Code:
 Input Priority
Input Priority selects which input to use when multiple inputs are active at the same time and
Input Select is set to Auto. The selection is based on priority.
cwt is offline
Old 02-11-2012, 11:25 PM
CIH USER
Franin's Avatar
Quoted: 2192 Post(s)
Liked: 1313
I've contacted them without no reply also.
_________________________
Franin is offline
Old 02-11-2012, 11:32 PM
SJHT's Avatar
Quoted: 244 Post(s)
Liked: 124
My oppo 93 does the same but always resyncs and then things are normal. SJ
SJHT is offline
Old 02-13-2012, 07:42 AM
Ranger41's Avatar
Try this
Ken.Nguyen@siliconimage.com
Ken Nguyen Support Engineer
Silicon Image, Inc. 1140 East Arques Avenue
Sunnyvale, CA 94085 USA
Tel: +1 408-616-4147 Fax: +1 408-616-6398
Ranger41 is offline
Old 02-13-2012, 09:31 AM
CIH USER
Franin's Avatar
Liked: 1313
Originally Posted by Ranger41 View Post
Try this
Thankyou for that.
Franin is offline
Old 02-13-2012, 09:45 AM
khollister's Avatar
Quoted: 22 Post(s)
I called last week to ask a few questions about a Duo before ordering one, and when I hit "2" or whatever for tech support, Ken answered the phone. Very nice guy.
Emotiva XMC-1 & XPA-5, B&W CM9s2, CM8s2, CMC, Hsu VTF-15, Sony BDP-S790 & HX929, Auralic Aries, Apple TV
khollister is offline
Old 02-13-2012, 11:14 PM
kucharsk's Avatar
Liked: 685
No - I usually keep watching whatever I'm watching until the BD player is fully booted up, but I've found with the Oppo I have to have the Oppo's input selected when it hits the menu screen or it will never sync with the display, instead displaying the "green screen."
kucharsk is offline
Old 02-13-2012, 11:18 PM
kucharsk's Avatar
Liked: 685
I noticed my iScan Duo is REALLY sensitive to timing, as if sources need a TBC to be safe.
For example, when viewing a LaserDisc, if I hit pause or put up text, when viewed through my iScan Duo the picture becomes "shaky" - wobbling from side to side horizontally. If I view the picture on one of the TV's native inputs, I see no such effect.
I suspect this is because the LD's timing is "good enough" for TVs but not for a processor, but it was still surprising to see.
Note the iScan Duo delivers a rock-solid picture when the LD is actually playing.
kucharsk is offline
Old 02-14-2012, 01:29 AM
cwt
cwt's Avatar
Liked: 32
Ive had the green screen with my 95 as well kucharsk ;does it also happen when the oppo is set as No1 priority ? Its most likely that the duo is still reading your other sources edid so cant lock on to the oppo's until the other source is switched off . Thats my reading of the priority system I surmise ;could be wrong
One thing I have noticed as my secondary lcd isnt 1080p is to turn off the secondary av output otherwise it can mean a factory reset if it locks up
cwt is offline
Old 02-14-2012, 04:16 AM
kucharsk's Avatar
Liked: 685
I don't use priorities on my Duo.
kucharsk is offline
Old 02-14-2012, 10:39 PM
cwt
cwt's Avatar
Liked: 32
Thats the workaround ; using priorities . The other sources edid is still locked on until its switched off ;hence the oppo green screen ..
Its a given that the order of start up with hdmi comms can have an effect on handshaking between components . For example I always boot up my pvrs before the display to make sure the hdmi repeater function can communicate properly ; gotta love hdmi
Another factor is the res your sending from the oppo ; is it source direct and do you have 24p set or is it auto and your sending 1080p/60 say ? Negotiations for dif rez can take a while . I just send source direct and set the duo to frame rate in = frame rate out for that input
cwt is offline
Old 02-15-2012, 10:00 PM
p5browne's Avatar
Quoted: 2806 Post(s)
Liked: 2127
Back a while ago, did an auto calibrate with my iScan Duo and Calman - the people ended up with fluorescent slotches - someone gave me a setting fix for the iScan Duo: I forgot which one it was, and also can't find the answer anywhere in my e-mails - anyone else run into this problem, and how did you fix it, because I just did another Auto-Cal with the same results.?
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is online now
Old 02-16-2012, 07:47 AM
SJHT's Avatar
Quoted: 244 Post(s)
Liked: 124
That happen to me the last time I ran an auto calibration (for CMS). My fix so far has not been to use it as post greyscale the colors on my JVC RS55 were almost dead on. Greyscale autocal works great. Let me know if you find out anything. SJ
SJHT is offline
Old 02-16-2012, 04:58 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
what are your Y values for each step? i seem to recall running into this, and if my memory serves me correctly, my Y values were off the reservation! im having a hard time remembering what the reason was too......
1forsnow is offline
Old 02-16-2012, 05:34 PM
p5browne's Avatar
Liked: 2127
My CMS values are dead on with Zero values after calibrating the White Balance Cool, Medium and Warm, then followed by the IREs. The RGB were almost dead on on the 100 line as well. As soon as I did the Greyscale Auto-Cal, all the final values were above the 100 line, and the people turned splotchy. Had to reset the iScan Duo to clear out the remnants. Turning ON the CMS Bypass didn't help! Leaving Auto-Cal out of the picture for now. I do a better job, and the people look Natural!
Old 02-18-2012, 05:14 PM
cardoski's Avatar
Quoted: 1175 Post(s)
Liked: 1148
Hi all am new to video processors and have decided to get either the duo or the edge green, the green has all the inputs and outputs I need my question is, is there a quality hit when going with the green or is it the same as the duo minus some inputs. I do have a 3d tv and bluray player so 3d does matter to me.
It's always in the last place you look.
cardoski is offline
Old 02-19-2012, 01:02 PM
Bluescale's Avatar
Quoted: 465 Post(s)
Liked: 169
The Edge Green doesn''t allow you to do any image calibration. The Duo has a fully functioning CMS which allows 10 point greyscale, primary and secondary color adjustments. It also allows gamma correction.
If your TV has comprehensive and working controls, you'll be fine with the Edge Green. If not and you want to correct it, you'll need the Duo.
Bluescale is offline
Old 02-19-2012, 01:58 PM
cardoski's Avatar
Liked: 1148
Thank you for the reply I have a LG55LW5700 which has the 21 point ire so looks like the green will be enough, I had heard they had the same processors inside but when looking at the site the duo seemed to be able to output 72hz and the green up to 48hz. I like the picture on my tv but the tru motion is very weak and there is alot of ghosting and judder when it is on, so I am hoping the edge green will prevent that. This may get me ripped for saying this but for some content I love the SOE, I know terrible right lol.
cardoski is offline
Old 02-25-2012, 04:34 PM
chexi1's Avatar
Quoted: 62 Post(s)
Liked: 115
I don't think the 21pt IRE scale is a CMS. That is probably gray scale only, which is an important tool, but is not a CMS.
chexi1 is offline
Old 03-06-2012, 02:56 PM
magicj1's Avatar
Quoted: 67 Post(s)
It looks like my Duo has died, has anyone else had one go down?
Old 03-06-2012, 09:25 PM
CIH USER
Franin's Avatar
Liked: 1313
Not yet how long have you had yours for?
Franin is offline
Old 03-06-2012, 11:20 PM
magicj1's Avatar
Quoted: 67 Post(s)
Just 2 years.
Gutted, as I do not use it that much. I am hoping it may come back to life, but I doubt it
Old 03-06-2012, 11:29 PM
CIH USER
Franin's Avatar
Liked: 1313
Just 2 years.
Could be the adapter. My vp30 once gave up and i was told to change the adapter and it was fine. I was told the adapters dont last long.
Franin is offline
