New DVDO iScan Duo [2.0 firmware released] - Page 129 - AVS | Home Theater Discussions And Reviews
post #3841 of 3849 Old 08-26-2014, 07:39 AM
whmacs's Avatar
Quoted: 30 Post(s)
Originally Posted by whmacs View Post
Hi All,
I have been using a DVDO Duo for a few years now. All my HDMI equipment connects into it. My current audio processor (Rotel RSP-1098) has no HDMI capability so I have the coax output from the Duo connected to it, the two HDMI video outputs from the Duo are connected to my tv and projector.
I am going to replace the Rotel with a Yamaha CX-A5000 audio processor. I understand I can connect the audio only HDMI output from the Duo to the Yamaha for sound. What however is the best way to connect the a Yamaha to the Duo so I can see the Yamaha's on screen display?
Regards and thanks,
Stephen
smacmillan@qvalent.com
Hi Guys,
Thanks for talking the time to reply. I've checked the Yamaha manual and you can turn off video processing. I have also read that the CX-A5000 can do video pass through when in standby mode, so it looks like I can watch TV without having to turn on the CX-5000 (which I want to be able to do) using your suggested hook up method.
Regards and thanks,
Stephen
whmacs is online now
post #3842 of 3849 Old 12-04-2014, 09:49 PM
drvais's Avatar
Quoted: 45 Post(s)
Liked: 30
Using the DUO, is there a way to take an HDMI input and output both an HDMI signal (essentially for the HDMI audio stream to a receiver) and an optical audio signal simultaneously?
unOFFICIAL D-Box FAQ here!
unOFFICIAL D-Box HEMC FAQ here!
Hail to the King, baby!
drvais is offline
post #3843 of 3849 Old 12-06-2014, 06:19 PM
Liked: 0
rs/
xthetrainx is offline
post #3844 of 3849 Old 12-07-2014, 10:47 AM
Kilgore's Avatar
Quoted: 275 Post(s)
Liked: 217
I'm not 100% positive, but I'm pretty confident that you could. Check the user's guide:
http://www.dvdo.com/documents/iScanD...ULL_080912.pdf
Kilgore is online now
post #3845 of 3849 Old 12-07-2014, 10:48 AM
drvais's Avatar
Quoted: 45 Post(s)
Liked: 30
I checked with DVDO on Friday and they said it's not possible.
drvais is offline
post #3846 of 3849 Old 12-07-2014, 10:53 AM
Kilgore's Avatar
Quoted: 275 Post(s)
Liked: 217
Well, nevermind then.
post #3847 of 3849 Old 12-09-2014, 07:17 AM
AVS Club Gold
joerod's Avatar
Quoted: 99 Post(s)
Liked: 120
You could pick up an Hdmi splitter 1X2 that does that. You have to make sure it is listed in the features because many don't pass digital audio only stereo.
For my latest Reviews and Stuff google -> Joe Rod Home Theater .Com
Check out my Dolby Atmos/Surround first take:
http://hstrial-jrodriguez996.homeste...=1409517748063
joerod is online now
post #3848 of 3849 Old Today, 12:10 PM
mintakaX's Avatar
Hi
I've had my Duo for three years and has worked flawlessly. I use the CMS with Chromapure to calibrate my 95ES projector. I recently upgraded the firmware to 2.4.1. Since that upgrade I have had some issues with frame dropping from streamed sources (Roku 3, Oppo 93, Amazon Fire). Nothing else has changed on my system. Is this just coincidence, or is it possible that the Duo FW upgrade could be the issue ? I thought I would check before here before downgrading.
mintakaX is online now
post #3849 of 3849 Unread Today, 02:47 PM
mintakaX's Avatar
Originally Posted by mintakaX View Post
Hi
I got over my laziness and bypassed the Duo and still had the same problems.
Reply Video Processors
