New DVDO iScan Duo [2.0 firmware released] - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #361 of 3919 Old 11-05-2009, 07:29 PM
Franin's Avatar
Quoted: 2393 Post(s)
Liked: 1488
Haven't done the update yet as I'm at work but has anyone noticed any difference in performance? Has it created any issues?
_________________________
Franin is offline
post #362 of 3919 Old 11-05-2009, 08:16 PM
UHD Addict
aaronwt's Avatar
Quoted: 6181 Post(s)
Liked: 3839
Originally Posted by Q of BanditZ View Post
^^ I've definitely been enjoying all of my PS3 games at 1080p 36 bits, that's for sure. And everything else for that matter.
The PS3 games take advantage of deep color and shows a higher color palette?
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #363 of 3919 Old 11-06-2009, 04:12 AM
Super Moderator
markrubin's Avatar
Quoted: 1267 Post(s)
Liked: 2767
anyone using serial control?
I tried it for input change and it works fine: but no faster than IR command:
trying to decide how to control it
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
post #364 of 3919 Old 11-06-2009, 04:12 AM
Franin's Avatar
Liked: 1488
Im impressed on how the Duo is know able to update without having to pull the whole unit out. Especially in my case where its hard to get too. Thats is a definitely a big plus, well done Anchor Bay
Franin is offline
post #365 of 3919 Old 11-06-2009, 04:17 AM
Super Moderator
markrubin's Avatar
Liked: 2767
Originally Posted by RichB View Post
What do you like better?
Rich
- it is rack mountable and has a classic box shape: never did like the Edge cabinet design
- seems more responsive to me [esp since update]
- test patterns can be brought up directly rather than having to go into menu layers
post #366 of 3919 Old 11-06-2009, 04:18 AM
Franin's Avatar
Liked: 1488
Im doing it IR. Works well
Franin is offline
post #367 of 3919 Old 11-06-2009, 04:21 AM
Super Moderator
markrubin's Avatar
Liked: 2767
and we can now throw away the bent out paper clip
post #368 of 3919 Old 11-06-2009, 04:22 AM
Franin's Avatar
Liked: 1488
exactly
Franin is offline
post #369 of 3919 Old 11-06-2009, 05:40 AM
UHD Addict
aaronwt's Avatar
Liked: 3839
I still have my EDGEs.
But it is nice not having to go behind my cabinet to stick a paper clip in.
Is the DUO supposed to be unplugged after the firmware update like the EDGE was? That's how I did my DUO update but I never read the instructions first like I should have. I updated it a few days ago with no problems, and mine seems more responsive to remote commands as well.
post #370 of 3919 Old 11-06-2009, 05:43 AM
Super Moderator
markrubin's Avatar
Liked: 2767
the instructions do not require it be unplugged
post #371 of 3919 Old 11-06-2009, 05:45 AM
Super Moderator
markrubin's Avatar
Liked: 2767
question on dual HDMI outs:
I have not tried this yet but it seems like you can only select one HDMI output for a given input?
I was hoping both HDMI outputs would be active
post #372 of 3919 Old 11-06-2009, 06:32 AM
Q of BanditZ's Avatar
Apparently that's true...for now.
Firmware: You can keep your unit plugged in, everything plugged in. No paper clips or any nonsense like that. Plug the USB cable in and follow the super easy instructions.
You can't mess it up if you try.
Great ISF Job by Chad B.
Q of BanditZ is offline
post #373 of 3919 Old 11-06-2009, 07:51 AM
UHD Addict
aaronwt's Avatar
Liked: 3839
You still need to connect it to a PC. I guess the next version needs an ethernet port for upgrades over an internal network or the Internet. That would really make it better.
post #374 of 3919 Old 11-06-2009, 09:02 AM
prepress's Avatar
Quoted: 120 Post(s)
Liked: 88
I never unplugged my EDGE after updates and noticed nothing amiss.
VPI, Grado, SME, Pioneer Elite, Magnum Dynalab, Oppo, DVDO, McIntosh, JJ, Mirage, Kimber, Transparent, MIT, Pangea, Wireworld, Shunyata, PS Audio, Furman, Sanus
prepress is offline
post #375 of 3919 Old 11-06-2009, 10:04 AM
Franin's Avatar
Liked: 1488
One thing I realized tonight that I had to enable framerate 1:1 for each input. I assumed that you enable it once and would work on all inputs. i like the idea how each input can be controlled individually.
Franin is offline
post #376 of 3919 Old 11-06-2009, 08:44 PM
Franin's Avatar
Liked: 1488
Going by what the manual states it looks like the 2 of the upgrades is going to be:
Profiles:Reserved for Future use
Users: Reserved for Future use
I guess if anyone wants to know what is the difference between the Edge and the Duo these 2 future upgrades will certainly be a beneficial to the Duo.
Franin is offline
post #377 of 3919 Old 11-07-2009, 06:24 AM
http://www.avsforum.com/avs-vb/showt...=#post17443756
^^ This still holds true. 1:1 Frame Rate and the Frame Lock both need to be enabled on all inputs at all times.
I'm sure it exists, but I personally can't imagine a situation where I'd have either of those settings turned off.
post #378 of 3919 Old 11-07-2009, 06:56 AM
amt
amt's Avatar
Wondering if anyone can help me with this question: Is it possible for the Duo to detect a film source and switch from 60p output to 24p automatically? Could this automatic frame rate switching be turned on/off per input?
amt is offline
post #379 of 3919 Old 11-07-2009, 08:17 AM
Franin's Avatar
Liked: 1488
Well I didn't realize that I had to enable it for each input I thought you do it once and it's enabled for all.
But I know have it enabled for all my inputs
I also like the idea of the automatic shutdown!
Franin is offline
post #380 of 3919 Old 11-07-2009, 08:21 AM
I'm spoiled by a lot of the auto features at this point.
post #381 of 3919 Old 11-07-2009, 08:29 AM
Franin's Avatar
Liked: 1488
Same, I'm hoping they give us the profiles update soon and the users one
Franin is offline
post #382 of 3919 Old 11-07-2009, 09:30 AM
tbase1's Avatar
Quoted: 47 Post(s)
Liked: 70
Frain/ anchorbay
Is it worth it to pair the duo with a isco IIIL doing a fixed lens constant area setup. I don't want to move my lens and I want to be able to have scaling adjustments for
1080p 24 FPS before my ruby and maybe soon to be ae4000u? I don't care about the scaler handling the audio, because I want it on the back side of my AVR. I also have a scope screen so please keep this in mind.
tony4k
tbase1 is offline
post #383 of 3919 Old 11-07-2009, 05:57 PM
Franin's Avatar
Liked: 1488
Originally Posted by tbase1 View Post
Frain/ anchorbay
Hi tbase,
I think the DUO will be a great combination with the ISCOIII lens. Btw congratulation on that purchase, you cannot go wrong with the German optics
The main reason I bought the Duo I found the JVC vertical stretch not quite up to my standards I did a comparison with LOTR and found the DVDO did a better job.
I don't know how the scaling is like on the two projectors you mentioned but I also believe a seperate video processor will do a better job than what's implemented in most projectors.
The Dvdo Duo offers 1080p scaling adjustments and because you are keeping the lens in place has the 4:3 button that will accomodate for material that is 1:78/1:85:1 AR. Personally if you could remove the lens out of the path for 1:85:1/1:78:1 material it would be better. Regarding the audio (touch wood) is still going great very stable.
Btw if you have a pronto 9600 and use PEP2 I have created all the single command buttons for the DUO that were provided by anchorbay, so by keeping the lens in place you just have to press the 4:3 button.
Franin is offline
post #384 of 3919 Old 11-08-2009, 03:18 AM
marcus wood's Avatar
Is the Duo able to do 2.35 without an anamorphic lens (without any lens zooming)?
marcus wood is offline
post #385 of 3919 Old 11-08-2009, 04:04 AM
Franin's Avatar
Liked: 1488
Nope.
Franin is offline
post #386 of 3919 Old 11-08-2009, 04:24 AM
edfowler's Avatar
Quoted: 169 Post(s)
Liked: 93
the vp50 can do it.
FS: Complete theater with two large AT screens - local pick up in Indiana only
edfowler is offline
post #387 of 3919 Old 11-08-2009, 04:51 AM
Franin's Avatar
Liked: 1488
Originally Posted by edfowler View Post
the vp50 can do it.
So how does that work? The Panels in projectors are 16x9.So if you dont need a lens nor Zoom how are you able to project 2:35:1?
Franin is offline
post #388 of 3919 Old 11-08-2009, 05:16 AM
Super Moderator
markrubin's Avatar
Liked: 2767
also noticed if you plug into the IR IN on the rear panel the front panel IR eye is shut off
post #389 of 3919 Old 11-08-2009, 05:22 AM
Franin's Avatar
Liked: 1488
Yeah I noticed that also but I also found that it would not work with my extender so I just got an emitter and placed in front of IR eye and found it worked.
The back has IR in and IR out how is that meant to connect?
Franin is offline
post #390 of 3919 Old 11-08-2009, 06:34 AM
Super Moderator
markrubin's Avatar
Liked: 2767
missing serial codes
decided to control by serial
downloaded the protocols from site: there are several missing and the commands from a VP-50 do not work
missing is:
menu & navigation controls
exit
test pattern next/previous
in the VP50 the command ID for menu and exit was A2 but that does not work for the DUO
can anyone help?
Reply Video Processors
