New DVDO iScan Duo [2.0 firmware released] - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #721 of 3898 Old 02-27-2010, 08:50 AM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 486
welcome back Joe regarding the CMS awaiting for my calibrator to have a go.
Awesome. Can't wait to get your feedback.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
post #722 of 3898 Old 02-27-2010, 11:03 AM
AtlPaul's Avatar
I am considering purchasing the IScan Duo. I have read a few reviews and so far I am impressed with its capabilities for the price.
I have a Panasonic TC-P65S1 1080p plasma set. I feed it from several sources including a Directv HR-21 DVR, Sony BDP-N460 BluRay Player, Toshiba HD-A1 HD DVD player and some 480i from the net via a PC that feeds the Directv STB via DLNA. All of this routes through a Yamaha RX-V1800 receiver.
I have calibrated the set using an EyeOne Display LT and Colorimetre HCFR software and found it improved the picture considerably. The greyscale is pretty good. However, the color is still a bit off and really cannot be practically adjusted even in the service menu of the set.
Given my viewing habits I am looking to improve grayscale, color and 1080i broadcasts. I do some 480i viewing but not alot. I also watch some standard DVDs, but not alot.
So, I was wondering what others experiences are with improving grayscale, color and 1080i broadcasts using the IScan Duo.
Paul
AtlPaul is offline
post #723 of 3898 Old 02-27-2010, 11:16 AM
Gary J's Avatar
Quoted: 405 Post(s)
Liked: 213
I had a Panasonic 1080p plasma hooked up with a Edge, not a DUO, with similar sources and got no improvement or actually worse (cable TV) picture quality. I think the Panasonic plasmas already have good video processing. I would try it only on an audition basis.
Gary J is offline
post #724 of 3898 Old 02-27-2010, 03:12 PM
TG_ONE's Avatar
Paul
Hi Paul, once I heard this was capable of CMS I picked one up for my Pioneer 6020FD. I am only calibrating mine with a sypder 3 probe right now but the results are impressive. You can dial in the RGB color to match your CIE graph in HCFR which worked great for me except for the blue channel, but I think this is a limitation of the spyder 3 probe and not with the Duo. There are no adjustments for secondaries. The 11 point grayscale adjustments are simple to use with HCFR and should help you smooth out youre grayscale. These are the only advanced features for CMS that it has.
So I bought this for the CMS and as an added bonus I got a video processor. The more I watch it the more I am impressed with its processing capabilities. Especially with 1080i/720p broadcast and 480p DVD. I did not notice as much improvement with blu-ray. With my cable I used to have alot of the blocking artifacts with fast moving picture and now it looks real smooth and clean. most of my 480p veiwing nowadays is done streaming divx movies from my computer to my PS3 which if I output in 480P the Duo will use what is called PReP. I believe it stands for progressive reprocessing which I also believe it takes a 480p and converts it back to its original 480i and then correctly puts it back to 480p and then upconverts it to whatever resolution u want. So basically its best to leave you upscalling DVD player output in either 480i or 480p.
The way I have mine setup is I have my PS3, XBOX360, toshiba hda1, HD Cable PVR connected to my Duo, and one HDMI cable going to my TV and another from the audio only HDMI out going to my reciever. The component I switch is the DUO, my reciever always stays on the same input. The remote that it comes with works but it is cheap feeling and sometimes have to press a button multiple times for the Duo to recieve it. I recommend using a universal or RS-232 automation if you have it.
I hope this was helpful. I would deffinetly buy one again.
TG_ONE is offline
post #725 of 3898 Old 03-01-2010, 01:54 AM
CIH USER
Franin's Avatar
Quoted: 2189 Post(s)
Liked: 1311
One thing I like about DVDO is at least you can go back to the old firmware with no hassles. Ive noticed one thing with the new firmware Im having an ever increasing handshake issue. Im going to wait until there is that fix as clefranc mentioned.
_________________________
Franin is offline
post #726 of 3898 Old 03-01-2010, 02:13 AM
CIH USER
Franin's Avatar
Liked: 1311
Before I go and replace one of my BD players can the Duo move subtitles?
Franin is offline
post #727 of 3898 Old 03-01-2010, 05:56 AM
prepress's Avatar
Quoted: 115 Post(s)
Liked: 85
Actually, I've noticed that too. Not all the time, but more than before.
VPI, Grado, SME, Pioneer Elite, Magnum Dynalab, Oppo, DVDO, McIntosh, JJ, Mirage, Kimber, Transparent, MIT, Pangea, Wireworld, Shunyata, PS Audio, Furman, Sanus
prepress is offline
post #728 of 3898 Old 03-01-2010, 06:41 AM
CIH USER
Franin's Avatar
Liked: 1311
I found both my Denon BD to suffer from it the most.
Franin is offline
post #729 of 3898 Old 03-01-2010, 08:17 AM
Q of BanditZ's Avatar
Heh, and here my handshake issues seemed to be improved. Go figure.
Great ISF Job by Chad B.
Q of BanditZ is offline
post #730 of 3898 Old 03-01-2010, 09:34 AM
DJSloan's Avatar
When doing a Greyscale/Gamma. I start with 100% pattern, use the luminance at 100%. I then start at 10% and set appropriate levels for a Gamma of 2.3.
When I get back to 100% it no longer matches my start value. Am I doing something wrong?
How and why would you need to set 0%? (You cannot get a reading and there should not be anything visible anyway.)
DJSloan is offline
post #731 of 3898 Old 03-01-2010, 10:03 AM
CIH USER
Franin's Avatar
Liked: 1311
Well Ive just tried it tonight with the previous firmware and its all good again. Im going to wait this time before I upgrade. I can wait for the CMS.
Franin is offline
post #732 of 3898 Old 03-01-2010, 02:09 PM
Goran's Avatar
AFIK this has to be done in the player. As soon as the videostream is out of the player the subtitles are locked. I have the Philips 9100 BluRay player that does it, the Philips 9500 player does it, and the Oppo 83 can do this with latest firmware. Haven't checked the new Oppo 80 player, so not sure if that can do it.
Not sure if the Philips players are available outside of Europe, leaving only Oppo as a option for the US.
Gøran
Goran is offline
post #733 of 3898 Old 03-03-2010, 07:28 PM
CIH USER
Franin's Avatar
Liked: 1311
Gøran
Thanks Goran
Franin is offline
post #734 of 3898 Old 03-04-2010, 12:25 AM
BENN0's Avatar
Is it me or does the automatic input switching not work (on firmware 2.0)? I just moved from an EDGE to a new Duo. On the EDGE automatic input switching always worked but I can't get it to work on the Duo.
I only use HDMI devices. Two of them always have their HDMI outputs active (very annoying) so I gave them the lowest priority. But still any device with a higher priority does not automatically gets detected and switched to when I turn it on.
I also have one device that gives me an "your display does not support HDCP" error about 5 seconds after I switch to it. When I turn the Duo off and on again with that device active and it input selected the error goes away.
Is it worth reporting this to DVDO? It's a Humax iHDR-5050C HD digital cable receiver/recorder that is specific for the European market.
BENN0 is offline
post #735 of 3898 Old 03-04-2010, 07:01 AM
CIH USER
Franin's Avatar
Liked: 1311
I get that HDCP problem also but from what I've been told there should be a fIx for it soon, well hopefully soon.
Franin is offline
post #736 of 3898 Old 03-04-2010, 08:23 AM
Erik Garci's Avatar
Some people in the US have been using Philips players to do Subtitle Shift. You can order them from Hong Kong, which is Region A for Blu-ray just like the US.
Erik Garci is offline
post #737 of 3898 Old 03-04-2010, 09:20 AM
AtlPaul's Avatar
I only use HDMI devices. Two of them always have their HDMI outputs active (very annoying) so I gave them the lowest priority. But still any device with a higher priority does not automatically gets detected and switched to when I turn it on...
I just got my Duo yesterday and I noticed the same thing. It seems like the first time a device is active on an input it will disable the "AUTO" setting and select the particular input of the device. After letting the Duo "see" all of the devices then I reset the Input Select to AUTO and then it worked as expected.
AtlPaul is offline
post #738 of 3898 Old 03-04-2010, 10:35 AM
David_MSP's Avatar
I wanted to check with everyone on this thread and see if I am the only one experiencing audio dropouts with Dolby TrueHD tracks coming from my Oppo BDP-83 player. If I switch to anything else, be it lossy Dolby Digital, DTS (lossy or lossless), DSD, doesn't matter, I don't get random dropouts. The minute I use Dolby TrueHD, my audio is completely inconsistent with several dropouts by the minute. I have yet to update my Duo to the latest 2.0 firmware but will be doing so shortly. I hoped to get some feedback first before making that jump.
David_MSP is offline
post #739 of 3898 Old 03-05-2010, 12:38 AM
BENN0's Avatar
Thanks I'll have a look at that tonight.
BENN0 is offline
post #740 of 3898 Old 03-05-2010, 12:25 PM
SJHT's Avatar
Quoted: 243 Post(s)
Liked: 124
The CMS on the Duo works great! I've always had a problem with green on my JVC RS-1 projector, but not anymore! Was able to align all the colors correctly on the CIE Chart. For grayscale, I had to lower RED across all of the IRE increments with some slight tweaking of blue & green. Interface works really easy. I'm using CalmanV3.6 and a Spyder2 meter. SJ
SJHT is online now
post #741 of 3898 Old 03-05-2010, 03:31 PM
smyth22's Avatar
Hey SJ: Sounds good; I take it there was no negative impact on your secondary colours as some had with the HDP. If so what I'm not sure about if that was a function of your particular colour gamut i.e. luck or is there something in the Duo software that prevents significant negative impacts on the secondary colours.
smyth22 is offline
post #742 of 3898 Old 03-05-2010, 05:19 PM
SJHT's Avatar
Quoted: 243 Post(s)
Liked: 124
By secondary, do you mean like yellow, etc.? Magenta was small amount off (VERY little). Everthing else dead on... SJ
SJHT is online now
post #743 of 3898 Old 03-05-2010, 06:36 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 486
The CMS in the Duo is nothing short of spectacular. I amazed each time I "tweak" the colors with it.
post #744 of 3898 Old 03-05-2010, 11:21 PM
smyth22's Avatar
Yeah that's what I meant; thanks for the info.
smyth22 is offline
post #745 of 3898 Old 03-05-2010, 11:27 PM
smyth22's Avatar
So the lack of luminance and secondary controls does not interfer with generating an accurate colour gamut?
smyth22 is offline
post #746 of 3898 Old 03-06-2010, 04:06 AM
CIH USER
Franin's Avatar
Liked: 1311
Wont be able to use it until they have a fix on the handshake issue.
Franin is offline
post #747 of 3898 Old 03-06-2010, 01:31 PM
Lush78's Avatar
when will this firmware come out of BETA? I upgraded to 2.0 beta and lost all my settings... don't feel like going through all the configuration if the 2.0 final will be released soon...
also, are there plans for simultaneous HDMI output? that was the reason i bought this unit, as it advertised this feature... was severely disappointed that it does not support simultaneous output...
Lush78 is offline
post #748 of 3898 Old 03-06-2010, 03:16 PM
prepress's Avatar
Quoted: 115 Post(s)
Liked: 85
I have it mainly with the cable box. I had my third dropout last night since installing the 2.0 beta. I even had a dropout or two with my Oppo 83. Haven't seen it on the 09FD yet.
prepress is offline
post #749 of 3898 Old 03-06-2010, 07:28 PM
prepress's Avatar
Quoted: 115 Post(s)
Liked: 85
With these dropouts and handshake issues: are all these occurring with equipment connected via HDMI, with one cable carrying audio and video?
prepress is offline
post #750 of 3898 Old 03-06-2010, 07:36 PM
CIH USER
Franin's Avatar
Liked: 1311
I went back to the last update and it's all good no more handshake issue.
Franin is offline
Reply Video Processors
