I'm looking for the best disc and patterns for evaluating scaling issues coming from players ,projectors or outboard processors. Thanks in advance for any guidance.
I was recently using a test pattern on the DVE 'HD Basics' BluRay to see what level of sharpness and detail adjustments on my HD350 start to cause interferance patterns (non at all as it turns out so I left them at '0'). This is a pattern with concentric circles of black and white (not unlike the Queen's 'Jazz' ablum cover if you're familiar with that). It also helped to hightlight differences between deintelacing settings on my Lumagen HDQ. The only issue with it is that there is no 'cadence' so it is a bit like putting up a 'paused' image and may show some VPs/scalers in an unfairly bad light, compared with playing 'real' moving footage.
The pattern is in the advanced patterns section 'Luminance Zone Plate, circular slow phase'. There is also another one 'Pixel phase' which seems to show if there is any scaling occuring in the chain as it only looks 'clear' when there is no scaling involved, going progressively more 'blured' as I adjust the scaling on my Lumagen by changing the output size.
I have that disc as well thanks ! Basically I'm looking for scaling artifacts in the stretch mode I use for scope presentation with my anamorphic lens.
Thats a good idea Art, I would be interested also if they had a disc designed soley for scope which included patterns etc.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
