Official Lumagen RadianceMini 3D thread. - Page 44 - AVS Forum
 13Likes
post #1291 of 1305 Old 09-11-2014, 03:50 PM
Pres2play's Avatar
Quoted: 73 Post(s)
Liked: 68
How do I keep the Gray Window test patterns the same size in the Lumagen? When I press the 4 button on the remote and select continuous to adjust the grayscale levels, I get a white window, but when I take a single reading a smaller size white window pops up. I noticed using different size windows throws off the gamma setting at the higher end.
Edit: Nevermind. Downloaded Radiance Tech Tip 5: Using Test Patterns
Pres2play is offline
post #1292 of 1305 Old 09-11-2014, 05:01 PM
lovingdvd's Avatar
Quoted: 83 Post(s)
Liked: 45
Originally Posted by Pres2play View Post
Seems my set is not so linear, the inside color points really benefit from 5x5x5 here...
Edit: actually spent about 40 minutes calibrating the grayscale manually in the Lumagen before realizing calibration reset was still active in Auto-Cal, LOL. Had to do it all over again after the LUT calibration was finished. Didn't really mind as my calibrating skills are improving.
Wait - why are you having to do anything manually? Can't the auto cal take care of everything you need?
lovingdvd is online now
post #1293 of 1305 Old 09-11-2014, 05:49 PM
Pres2play's Avatar
Quoted: 73 Post(s)
Liked: 68
I can do better than auto-cal below 40 IRE, and auto-cal does not work at 5%.
post #1294 of 1305 Old 09-11-2014, 11:56 PM
Pres2play's Avatar
Quoted: 73 Post(s)
Liked: 68
For black and white level adjustments as well? I was using the reference PLUGE patterns for this.
For those who care, Radiance Tech Tip 5 (Rev 2.2) says to use the Reference test patterns for setting the display controls.
post #1295 of 1305 Old 09-12-2014, 01:10 AM
Pres2play's Avatar
Quoted: 73 Post(s)
Liked: 68
AV_Mike, I'm having the same problem as before, namely trying to use the Lumagen controls while the signal generator in ChromaPure is still active. How do you run auto-cal and still make manual adjustments with the Lumagen controls? Do you run 21-point grayscale calibration first? Then activate the signal generator in ChromaPure for auto-cal and 125-point lut?
post #1296 of 1305 Old 09-12-2014, 11:06 AM
AV_mike's Avatar
Quoted: 22 Post(s)
Liked: 39
Yes, I disable Pattern Generator support within ChromaPure, then perform Greyscale and Gamma (21-point) manually - I find this gives me the best results. Once I am happy with those aspects, I re-enable ChromaPure control, and start the 125-point CMS Auto-Cal.
As has been said before, once you get comfortable with the Lumagen menus, etc, it is quite quick and easy.
Regards, Mike.
AV_mike is offline
post #1297 of 1305 Old 09-12-2014, 01:21 PM
Pres2play's Avatar
Quoted: 73 Post(s)
Liked: 68
Thanks, Mike. I guess as long as you save the LUT calibration it's okay to disable the pattern generator at any time in the session.
post #1298 of 1305 Old 09-15-2014, 05:00 PM
Pres2play's Avatar
Quoted: 73 Post(s)
Liked: 68
WRT the User Color Window test patterns in the Lumagen, will this feature allow me to make changes to the "Gray: Small 50 APL" and "Gray: Medium 50 APL" patterns?
Also, when you make a change, how do you save it?
post #1299 of 1305 Old 09-16-2014, 12:44 PM
Pres2play's Avatar
Quoted: 73 Post(s)
Liked: 68
Question: how do I correct the response taken from the APL measurement? I tried the grayscale/gamma controls on the Lumagen, but the APL patterns are not there; I see only the Window test patterns with white window and black border. When I use the Window patterns, the gamma response changes back to the old reading. I'll post this in the Radiance Mini3 thread as well.
post #1300 of 1305 Old 09-21-2014, 12:25 PM
Pres2play's Avatar
Quoted: 73 Post(s)
Liked: 68
Why are the internal APL patterns not available when I try to use it with the Lumagen controls? Works fine with a disc.
post #1301 of 1305 Old 09-22-2014, 11:31 PM
ConnecTEDDD's Avatar
Quoted: 102 Post(s)
Liked: 484
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 091114 Firmware Update
Release Notes
Fix for a bug which under rare circumstances could give strange colors in grayscale that a user may have remedied by turning off and back on. (Update time ~9 minutes @57k)
Download Link
AVfile likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS + CalMAN ColorChecker
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, CalPC, ControlCAL
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #1302 of 1305 Old 09-22-2014, 11:55 PM
AVfile's Avatar
Quoted: 35 Post(s)
Liked: 57
Originally Posted by AV_mike View Post
I would be interested in a Mini3D form factor containing the larger FPGA, that would allow for larger LUT calibrations...................................... ...........
I would be interested in a revised firmware that swapped some of the (unused) CMS memories for one larger CMS memory. I mean do we really need 8 memories? I only use one (two if you count no CMS).
- AVStefan
If you like someone's post, just use the Like button to give thanks.
AVfile is online now
post #1303 of 1305 Old 09-23-2014, 03:13 AM
Pres2play's Avatar
Quoted: 73 Post(s)
Liked: 68
Found my mistake. In Chromapure, the pattern type should be set to Windows. I had it on Medium_Windows. This will make the pattern size the same (11%) whether I use the Lumagen controls or CP.
post #1304 of 1305 Old 09-23-2014, 03:09 PM
Pres2play's Avatar
Quoted: 73 Post(s)
Liked: 68
Pleasantly surprised to find APL in CP in the Options menu under Signal Generators, Pattern Type as well
post #1305 of 1305 Old 09-28-2014, 08:57 AM
Socio's Avatar
Quick question; How to I get different memory settings to use different styles?
For example, I have MemA set to style 0 and it has a check beside it, I go to MemC -settings-styles and select style 2 and customize the settings for style 2 then save.
However MemC is still defaulted to style 0, how do I get it to use 2?
EDIT: never mind I figured it out have to set it in output setup.
Socio is offline
Reply Video Processors
User Tag List
