Adding PIP to a TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-13-2011, 02:46 PM - Thread Starter
duffman33's Avatar
Hello everyone. I'm admittedly a bit of a noob in this area which is why I was hoping to get some good advice from you folks here. Basically, my dad recently purchased a new HDTV and loves it. The only issue is he really misses his old PIP function. With father's day coming up, I was hoping to be able to give that feature back to him. He has Comcast and none of their cable boxes have PIP, so I guess I will need a stand alone unit.
Ideally, I'd like it to be relatively cheap for the setup and relatively simple to use. Installation can be as hard or easy as necessary since I will take care of that for him, but I want him to be able to use it without calling me all the time.
As far as what I prefer, I would like a unit that can take the HD signal from the cable box and under normal viewing, just pass that image to the TV. However, when he wants PIP, then I would like it to be able to display a secondary box. I don't know much about video processors, so I might have to connect an external tuner to the vp in order to have a source for the PIP. That's all fine but like I said, getting the PIP function is number one.
Hopefully I explained everything but please do not hesitate to ask for clarification if I missed something. Thanks in advance guys, I know my dad will appreciate it as well. :-)
65JS9500
Sony STR-DN1030
Pioneer SP-C22 Andrew Jones Designed Center Channel Speaker
Pioneer SP-FS52-LR Andrew Jones Designed Floor standing Loudspeaker - Fronts
Infinity Primus 363 6.5" Tower Speaker - Surrounds
Martin Logan Dynamo 300 8" 75 Watt Subwoofer x2
duffman33 is offline
post #2 of 5 Old 06-13-2011, 02:53 PM
Phil Tomaskovic's Avatar
Quoted: 35 Post(s)
Not sure about any external boxes that can do this. Most of the new Sony tvs have PIP/P&P where you can use 1 hdmi input and one other input (non-hdmi) internal tv-cable tuner/component/composite input. Samsungs also have P&P but can only access the tv tuner in one box.
Might be easier to exchange tv if possible.
Phil Tomaskovic
Phil Tomaskovic is offline
post #3 of 5 Old 06-13-2011, 02:56 PM - Thread Starter
duffman33's Avatar
Thanks but this is a father's day gift. The TV is about 6 months old and he loves it. Besides, for the price no other tv has PIP function. Just doing a quick search I can find units for PIP but they are quite expensive which is why I'm asking here. Since I don't know what is needed I'm not even sure which cheap model would work for me, so I thought I'd ask.
65JS9500
Sony STR-DN1030
post #4 of 5 Old 06-14-2011, 09:17 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
The InstantHQV by CYP can show a composite and s-video PiP window over a HDMI source. The Radiance XD/XE can do PiP with any sources (e.g. 2x HDMI or Component over HDMI).
Those are the only two processors I can think of and both aren't exactly cheap.
Fudoh is offline
post #5 of 5 Old 11-26-2013, 10:23 PM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
These options would work?? I have new vizio 80" that doesn't have PIP and want to use it to see a coax cable connection I have to a camera.
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
Reply Video Processors
