No HDMI audio when using custom timings w/VP50 pro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-07-2011, 06:02 PM - Thread Starter
flyingvee's Avatar
Top post - I know. Using a DVDO VP-50 pro with my Runco CRT pj. Its been working fine, passing HDMI audio and video when working with standard HD resolutions - 1080i, 1080p, and 720p.
Today, got bored, figured I'd try something different - so I ran a quick setup for 960p. Looked GREAT. But no sound via HDMI, no matter what I did.
Has anyone else run into this; has it been addressed already? Just curious - I imagine I can go back to spdif audio, via toslink or coax, but I've been enjoying HDMI, so if there is a way to use non-standard resolutions I'd appreciate it.
thanks
Jon
Denon DVP - everyone else loves it.
flyingvee is offline
post #2 of 3 Old 08-07-2011, 06:06 PM
JoshA's Avatar
I'd guess the problem is that your AVR doesn't recognize the signal with custom resolutions and not that the audio isn't there.
My opinions are my own, and do not necessarily reflect those of my previous or current employers.
JoshA is offline
post #3 of 3 Old 08-08-2011, 01:04 PM - Thread Starter
flyingvee's Avatar
ok - guess I can go with that. It still passes the video fine - its just a Yamaha AVR - it shows HDMI audio in on the front panel, but there's no sound.
Will try some other options, I guess. fwiw, I ran up to 1080i/72 - that worked. But no matter how I snuck into it, I couldn't get the 1440 to work.
Jon
Reply Video Processors
