Radiance XS+ 3D sync box - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-22-2011, 04:26 PM - Thread Starter
nidi's Avatar
Hello guys,
I was wondering what type of box is needed for the XS+ 3D
I've looked on thir website for it and can't find it.
is that a 3rd party product not offered by Lumagen?
Thanks for any help
Michael
nidi is offline
post #2 of 3 Old 08-23-2011, 11:10 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Michael You need to contact Lumagen Directly, the CRT sync box for 3D is A moded lumagen HDMI exender..see pic
cinema mad is offline
post #3 of 3 Old 08-23-2011, 02:38 PM
patrick harkin's Avatar
As "cinema mad" says, the CRT-3D 3D glasses sync box is based on the Lumagen HDMI-HDMI extender with the addition of a PC spec 3D glasses driver output on a 3-pin Mini-DIN receptacle. The 3-pin Mini-DIN output has the 3D glasses signal, +5 VDC and ground as called out in the PC spec. We'll be adding it to our website soon.
A separate wired-to-wireless 3D glasses converter is needed to drive your wireless 3D glasses. There are of these available in the market. One type we like is the JVC PKEM1P, with the PKAG1BP companion 3D glasses. Note: The JVC is specified to use a 12 VDC power supply, but appears to work well with the 5 VDC supplied by the Lumagen CRT-3D sync box when we tested it.
Please contact Lumagen at support@lumagen.com for more information. The CRT-3D sync box is available from your Lumagen dealer.
Patrick Harkin, Lumagen Inc. engineer
patrick harkin is offline
Reply Video Processors
