Best 4x4 HDMI Matrix - AVS Forum | Home Theater Discussions And Reviews
Old 08-29-2011, 03:09 PM - Thread Starter
rmlinnovator's Avatar
Anyone have a recommendation on a 4x4 HDMI Matrix that will allow me to simultaneously watch the same thing on 4 displays at varying resolutions? It also needs to support HDMI audio.
rmlinnovator is offline
Old 08-29-2011, 03:52 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
I've got this one: http://www.ebay.com/itm/140454429933
Works very nice (also 3D compatible), with two tiny caveats and one big plus. The two caveats are: it can't be switched off using the remote and it's a bit sensitive to random IR fire from other Taiwan stuff (e.g. from my Dune player's remote). The big plus is that is enables HDCP-encrypted output from devices even if the display does not support HDCP.
The link above is from a german dealer, but you should be able to find the same one stateside.
Fudoh is offline
Old 08-29-2011, 06:49 PM
fastl's Avatar
Quoted: 22 Post(s)
If I remember correctly, our illustrious web site moderator Mark Rubin had a real good writeup of a quality HDMI switching product awhile back - one that actually works!
fastl is offline
