wich scaler dvdo 50 or edge - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-19-2011, 06:51 PM - Thread Starter
rindfisch's Avatar
hi there,
i got a question....i could get a scaler from a friend pretty cheap he got 2. i can buy one....but i dont know wich one fits better for my equipment,
i can choose from dvdo 50 (not pro) and dvdo edge
i am watching on a epson tw3000 1080p projector
80% of the time i use it for tv (mostly 80% 1080i / 20% pal)
15% gaming or watching movies via ps3
5% gaming on wii
wich one would be a better choice?
thanks for help!
rindfisch is offline
post #2 of 3 Old 09-27-2011, 08:12 PM
CRGINC's Avatar
Let us know what you expect from the VP. I own a VP50 which I use in my HT with a 2.37:1 ratio screen. The VP does the signal processing and scaling. The edge is newer and supported but until you tell us what your needs are we can't make a suggestion.
CRGINC is offline
post #3 of 3 Old 12-08-2011, 09:19 PM
blee0120's Avatar
Quoted: 619 Post(s)
Liked: 312
How do the upscaling from 720p/1080i to 1080p look on these two VPs compared to the duo?
blee0120 is offline
Reply Video Processors
