HDMI Passthrough - AVS Forum | Home Theater Discussions And Reviews
Old 10-05-2011, 01:25 AM - Thread Starter
Eagleshadow's Avatar
What processors will pass HDMI through to the output of the AVR/P with the unit turned off (standby). I want to be able to watch Tv without turning on the processor. I could use an HDMI splitter if I need to, running one output to TV and the other to the AVP. It would be simpler if I can do what I suggest. Do Integra or Marantz pass through. I will be using HDMI exclusively as I have ditched all mu devices that to not have HDMI output, except for and onld VCR.
PS How do you create an AVS forum avatar?
Eagleshadow is offline
Old 10-16-2011, 09:22 AM
CCCB's Avatar
I would use the HDMI splitter personally. It allows you to maintain a good signal path. Trying to run it through something else as a pass through will most likely create some visual artifacts or other issues.
CCCB is offline
Old 10-16-2011, 01:07 PM
Glimmie's Avatar
Quoted: 752 Post(s)
Liked: 619
Not likely. In order to alter the image, the device would need to have an image processor engine in line. There is not image quality loss through simple switches with HDMI like there can be with analog switchers.
The only question is will the receiver pass a signal with the power off? Note that it would have to be a soft power off if any hope of working. A hard power off like the AC plug pulled would surely not pass the signal through.
Glimmie is offline
