Best option for 480p -> 1280x800 DVI scaler? - AVS Forum | Home Theater Discussions And Reviews
Old 11-05-2011, 06:53 PM - Thread Starter
jtsmith581's Avatar
I'd like to play my Wii on my HP LP3065 monitor, which only accepts 1280x800 DVI and 2560x1600 DL-DVI inputs. What are my best options for a scaler? So far, the only device I've found that appears to be a sure thing is the Extron RGB-DVI 300, which goes for about $500. Do I have better options?
Jeff
jtsmith581 is offline
Old 11-06-2011, 02:52 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
You can use any processor which supports custom resolutions. You could probably find a 2nd hand iScan HD (or HD+) for about $100. Or an iScan VP30 for roughly $250.
Fudoh is offline
