Can I borrow your remote for a FAROUDJA Picture Plus NR Series VP? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-21-2011, 07:52 AM - Thread Starter
jgk1971's Avatar
I aquired this VP for almost nothing but of course being a Faroudja almost all adjustments can only be made using a remote control and this one didn't come with one. Anyone in the Nothern Virginia area have one I can borrow long enough to program the codes into my Sony learning remote. I could do the programming in 5 minutes at a location chosed by you. The remote will not have to leave your sight.
Alternately, anybody have a spare remote to sell? I'm willing to spend around $10-$15 plus shipping. I'm pretty sure this is the correct remote:
jgk1971 is offline
post #2 of 6 Old 11-21-2011, 09:30 AM
sideswiper's Avatar
If you cant find one why dont you buy a cheap Harmony remote i am sure it will do the job as i have not found anything that it doesnt work with yet. Love my Harmony 890 it controls everthing i have in my setup.
sideswiper is offline
post #3 of 6 Old 11-21-2011, 02:20 PM - Thread Starter
jgk1971's Avatar
Unfortunately all of the 890's that actually work are north of $100, which is several times what the actual processor cost me.
Does anyone know if there are any codes for a Sony RM-AV3000 that will work with the processor?
jgk1971 is offline
post #4 of 6 Old 11-21-2011, 05:50 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Re post this in the "Remote Control" section. I'm sure one of those JP1 experts have the codes you need.
Dropkick Murphy is offline
post #5 of 6 Old 11-23-2011, 10:32 AM
sideswiper's Avatar
there are cheaper Harmony remotes than the 890 seen some on ebay around $25-$30
post #6 of 6 Old 12-16-2011, 02:15 PM - Thread Starter
jgk1971's Avatar
I actually ended up just using the serial port on the back to change the settings to what I need. Since I'm only running my LD player through it and don't play on changing anything, it's "set it and forget it" and I can power it on with the button on the front.
jgk1971 is offline
Reply Video Processors
