Best Video Scaler for Pio KRP600A - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-13-2011, 03:57 AM - Thread Starter
perrin21's Avatar
Hi, i am considering purchasing a video scaler for my system. My components are:
Pioneer KRP600A UK version
Denon AVPA1HDA AV Processor
PS3
Sky HD
Apple TV
Media PC
I also have a little calibration equipment
Calman Software V4.2
Xrite i1Pro Display 3
I have been considering the Iscan Duo as it has compatibility with the calman software for auto calibration and i was just wondering if anyone could tell me any reason why i should consider something else instead.
I dont want to spend more then $999 .
Is the Iscan Duo still considered a good scaler or should i wait for a replacement? Is the duo being replaced soon as it seems to be a few years old now and i was wondering how futurproof it is. I see it does not have HDMI 1.4 and although my current display does not have this i wouldnt want a processor thats already due for replacement with something often better.
Are there any others i should consider?
Thanks for all help
Mark
AVP-A1HD Owners Wiki http://avppoaowners.wetpaint.com/
Please feel welcome to contribute :-)
perrin21 is offline
post #2 of 4 Old 12-13-2011, 04:29 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
If your limit is $999 and you obviously want a full Color Management System, then you've got no choice. Get the Duo. Next one would the Radiance Mini-3D for $1400.
Fudoh is offline
post #3 of 4 Old 12-13-2011, 05:43 AM - Thread Starter
perrin21's Avatar
ok so lets assume i did stretch my budget a little to the Lumagen, it appears to only have one input. How can i colour manage multiple sources? and why is it better?
perrin21 is offline
post #4 of 4 Old 12-13-2011, 07:21 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
The Radiance Mini-3D has two physical inputs and a number of virtual ones, so you can easily add any cheap switch and apply different settings to all of your sources. Digital inputs really aren't a problem. It's just not your system if you still need analogue inputs.
The Mini has 3D processing, while the Duo has just 3D passthrough. I know not important on your current plasma, but maybe in the future. The Mini has advanced NR functions, while the Duo has just a mediocre Mosquito noise function. I like both machines for their deinterlacing. The Radiance's scaling engine is better, but the Duo's is sharper. The Radiance is better suited for low-quality sources, while both are great on good sources. The Duo is very easy to setup and control. The Radiance is more complicated, but has more available options after all.
Fudoh is offline
Reply Video Processors
