XRGB-Mini Framemeister review is up ! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-18-2011, 06:58 AM - Thread Starter
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Micomsoft's newest toy. Equipped with a Marvell QDEO Kyoto G2 processor the Mini takes it's place as the new king for 240p processing !
Read the full review here: http://retrogaming.hazard-city.de/
Fudoh is offline
post #2 of 13 Old 12-18-2011, 12:21 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 486
Nice Review!
I'd like to check one of these out someday.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
post #3 of 13 Old 12-18-2011, 12:23 PM
joerod's Avatar
Quoted: 607 Post(s)
Liked: 486
I wonder how it would do with a Sony 95ES or 1000ES?
post #4 of 13 Old 01-25-2012, 02:33 PM
forin's Avatar
nice!
Awesome review fudoh! Now I wonder if anyone would like to buy 2 slightly used holo3d cards.
Now the big question, do I pay to mod my consoles for rgb and buy a xrgb-mini, or transfer to emulation........ So many choices.
forin is offline
post #5 of 13 Old 01-26-2012, 01:01 AM
jd213's Avatar
Hmm, no VGA output is somewhat disappointing since I sometimes use a CRT monitor. I guess I could use an HDFury2 or something, those don't introduce any delays, do they?
jd213 is offline
post #6 of 13 Old 01-26-2012, 03:31 AM - Thread Starter
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Fudoh is offline
post #7 of 13 Old 02-24-2012, 10:55 AM
forin's Avatar
Picked one of these up yesterday. Totally worth the cash, all retro consoles and the Wii greatly benefit from it. Hopefully micomsoft will fix some of the minor bugs. fudo's review was spot on.
Forin
forin is offline
post #8 of 13 Old 02-26-2012, 11:23 PM
HDgaming42's Avatar
Quoted: 163 Post(s)
no, they don't and yes, you can.
I thought there was a polarity issue with the Fury2? Or am I not paying close enough attention?...
HDgaming42 is offline
post #9 of 13 Old 02-27-2012, 05:50 AM - Thread Starter
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
The Fury 2 can't be used to feed a SLG3000 scanline emulator. Other than that it's perfectly fine. I had one for quite some time.
PopeParty likes this.
Fudoh is offline
post #10 of 13 Old 02-27-2012, 08:12 AM
HDgaming42's Avatar
Quoted: 163 Post(s)
That's what I was thinking of. Thanks for clarifying.
post #11 of 13 Old 07-14-2012, 02:22 PM
godaikin's Avatar
hi i have a xrgb-3 and a sony led tv i can't use b1 is just not compatible on the other tv i have works's but is to small is a samsumg by the way
im planning on sale the xrgb3 and get the mini frame meister that will help ? please let me know
regards
john
godaikin is offline
post #12 of 13 Old 07-14-2012, 02:36 PM - Thread Starter
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Hey John,
if you want to upgrade to the Mini, then yes, it will solve your problem.
With the XRGB-3 I had the same problem when I replaced my Sony XBR5 with a HX900. Adding a RGB interface in between (I have an Extron RGB 203 Rxi) did the trick and the XRGB-3 worked fine on the HX900 in B1. I would suspect that it would work on your setup as well. Cheaper Extron RGB interfaces like the 190 are available for $25-30 on ebay.com, so if you want to keep your XRGB-3 for now, give it a try.
Fudoh is offline
post #13 of 13 Old 07-14-2012, 04:10 PM
godaikin's Avatar
thank you dude.
godaikin is offline
Reply Video Processors
