Dilema, receiver has a QDEO processor, projector has Reon HQV... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-28-2011, 12:24 AM - Thread Starter
EJ
EJ's Avatar
I have not used either, as the Onkyo is new, and I just ordered the Epson projector with the Reon processor. I had planned to have the Onkyo scale everything to 1080p to the projector. Does anyone know if the processor in the Epson can be turned off?
My first thought is to try it with both on. Any ideas would be appreciated.
Former USSB uplink operator.
EJ is offline
post #2 of 5 Old 12-28-2011, 09:11 AM
Josh Z's Avatar
Quoted: 2137 Post(s)
Liked: 1434
If you scale to 1080p in the receiver, there will be nothing for the projector to scale. This will effectively bypass the processing in the projector. It will only kick in if you feed the projector something less than the native resolution.
Both QDEO and Reon are good scaling solutions. You should get good results no matter which you decide to use.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #3 of 5 Old 12-28-2011, 02:45 PM
rovingtravler's Avatar
Very true as stated above.
You cannot turn off the processor. This is because of many things. If you use keystone, guess what you are using, the video processor. Depending on the machine when you adjust the brightness or contrast that to can be the video processor, etc etc.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #4 of 5 Old 12-29-2011, 12:58 AM
Kilian.ca's Avatar
Liked: 37
If you turn off (or remove) the video processor there will be no video, sounds reasonable?
Even when you feed the display 1080p, you might still need the vp to do colour space conversion, chroma upsampling, frame rate duplication (for 24p) and of course the usual picture adjustments. There might also be background non-defeatable video processing going on and some degree of overscan unless there is a way to disable that.
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #5 of 5 Old 01-05-2012, 02:27 AM - Thread Starter
EJ
EJ's Avatar
Thanks everyone. I'll use both and give it a try.
EJ is offline
Reply Video Processors
