HDMI audio in...to LPCM audio out converter - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-10-2012, 12:28 PM - Thread Starter
comtech5's Avatar
I need to strip out 7.1 LPCM data from an HDMI source. Don't want 8ch analog audio out, I need 4 pair of LPCM data. I guess stated correctly that would be 4 X AES. Is there a converter box that does that?
Pioneer KRP-500M
OPPO BDP-83
DirecTV HR24
comtech5 is offline
post #2 of 13 Old 01-10-2012, 11:25 PM
XrstalLens's Avatar
Such a box would violate the HDCP (copy protection) specification, so they don't exist. The best you will get is 2 channel 44.1 kHz digital output.
Lyle Corbin
www.crystalclearhometheater.com
THX Video, ISF, and HAA Level II calibrator
XrstalLens is offline
post #3 of 13 Old 01-11-2012, 11:49 AM
Flimber's Avatar
Someone brewed up some modded DVDO Edges once upon a time with 7.1 LPCM put out via four extra sp/dif sockets on the rear and they change hands occasionally, mainly on the 'meridian unplugged' forums.
Or search for CYP CLUX-11SA to see a standalone audio stripper.
Flimber is offline
post #4 of 13 Old 01-11-2012, 12:31 PM
fatjulio's Avatar
Quoted: 17 Post(s)
There's possibly this www.gefen.com/kvm/dproduct.jsp?prod_id=9164
I don't know if it will actually convert the signal on the HDMI out, or just change the EDID. I'd like to find out if this will do the conversion too.
fatjulio is online now
post #5 of 13 Old 01-11-2012, 04:30 PM
obie_fl's Avatar
Liked: 33
Don't think the Gefen will do what the OP wants as he specifically said he didn't want 8ch analog and the TOSLINK isn't going to give him 8channels of LPCM either.
obie_fl is offline
post #6 of 13 Old 01-11-2012, 06:23 PM
fatjulio's Avatar
Quoted: 17 Post(s)
But I think the HDMI output will be converted to LPCM when the switch on the front is set to LPCM5.1/7.1. I did ask Gefen and they said this would happen, but now I'm not too sure they meant it just changed the EDID as far as the HDMI output goes.
I've found one on eBay, and the seller had a 30 day money back guarantee.
post #7 of 13 Old 01-11-2012, 07:01 PM - Thread Starter
comtech5's Avatar
I found some definitive answers by contacting Gefen and Cypress.
Both units output analog only.
According to them, it is in fact an HDCP violation to strip out unconverted LPCM from HDMI.
So that's the end of that I guess.
Pioneer KRP-500M
OPPO BDP-83
DirecTV HR24
comtech5 is offline
post #8 of 13 Old 01-11-2012, 07:44 PM
obie_fl's Avatar
Liked: 33
I'm unclear on what you are trying to do. Converted to LPCM from what? HDMI is already LPCM (assuming you are decoding at the source) they are just tricking the source into outputting stereo or multichannel with the EDID. If you are trying to go from one of the Dolby or DTS codecs to LCPM this isn't the box you need, it doesn't have a decoder. The HDMI is basically a pass-thru with EDID twiddling.
obie_fl is offline
post #9 of 13 Old 01-11-2012, 07:52 PM
obie_fl's Avatar
Liked: 33
I wouldn't be surprised if someone hasn't done it out of Hong Kong but I've personally never seen one. I'm aware of some HDMI to single S/PDIF convertors but I suspect you are looking for 8 channels of High resolution audio. What are you trying to feed? A Meridian?
obie_fl is offline
post #10 of 13 Old 01-21-2012, 06:49 PM
locomo's Avatar
Quoted: 84 Post(s)
Liked: 54
locomo is offline
post #11 of 13 Old 01-21-2012, 08:17 PM - Thread Starter
comtech5's Avatar
Atlona's description of their own product is grossly misleading at best, and false advertising at worst. Although it claims to "strip" or "dis-embed" 7.1 LPCM (aka AES3) from HDMI, it doesn't give you access to the actual LPCM. It only gives you access to the 7.1 analog signals/channels that have already been D/A converted from LPCM. I think the problem was whoever did the translation was unfamiliar with the subtleties of the English language. All receivers do exactly that (convert LPCM to analog), so I believe this product is aimed at a PC user with an HDMI output that would want 7.1 sound on their desktop.
Pioneer KRP-500M
OPPO BDP-83
DirecTV HR24
comtech5 is offline
post #12 of 13 Old 01-22-2012, 08:11 AM
raneil's Avatar
I agree. I purchased this product and never got anything more than stereo and even called the company and got a replacement unit to wit, same problem again. Even used Geffen HDMI detective to precede the unit.
raneil is offline
post #13 of 13 Old 01-22-2012, 09:50 AM
Kal Rubinson's Avatar
Quoted: 805 Post(s)
Liked: 571
There are "unofficial" mods which can accomplish this. See: http://www.jvbdigital.nl/jvb.asp?cur...g=SPDIFupgrade
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Reply Video Processors
