Whole house audio and video controller - AVS Forum | Home Theater Discussions And Reviews
Old 01-20-2012, 07:16 AM - Thread Starter
JP2701's Avatar
Hello,
I am new to your site but have browsed thru it and would appreciate any help on designing a mid size audio video system for whole house.
Here is what I would like to accomplish.
All audio video equipment in one location for entire house.
hd video via cat5 and baluns to each tv location. Approximatly 10 to 12 locations. 1 pair inwall speakers in each of these rooms that I can get the music from any component at headend but also I need to have that pair of speakers also provide the audio for whatever video source I am cuurently using in that room. Also need the ability to watch/listen to different sources in each room.
Also what seems to maybe be an issue is that while I want the inwall speakers to be used for whatever video channel/source I am watching I would also like to have the availability to get the sound ou of the tv speakers if I would want to.
Would like to possibly have the ability to use iphone/ipad for control at later date but probably just use harmony 1100 for control for now.
Right now I am considering the following equipment:
Niles zr6 receiver
niles vs-6 video switcher
cat 5 to waalplate video baluns
usuall source components dvd, blue-ray, cd player , 1 0r 2 hd cable boxes
and would like some sort of steaming video
I am not stuck on Niles but seemed to be in price range and do what I need except it appears it may have been discontinued but is still on their website. I would appreciate any help, tips advice you may have .
JP2701 is offline
Old 01-21-2012, 07:26 AM
ccotenj's Avatar
Liked: 101
welcome...
you are in the wrong subforum... try posting your question here:
click me
and you will get some responses...
good luck...
- chris
ccotenj is offline
