Multiple Xbox 360s + single projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-23-2012, 03:55 PM - Thread Starter
djshorty's Avatar
Hi there,
I would like to be able to project 2 Xbox 360's using a single projector. Some searching indicates that some sort of video processor would suit this application.
I found products by vistasystems, tvone, and networktechinc (sorry I can't post URLs yet)
Has anyone else done this?
Would you please share your experiences?
Do these sorts of processors introduce any sort of latency that might affect gaming?
Are there other relevant products out there?
Kevin
djshorty is offline
post #2 of 3 Old 01-23-2012, 07:49 PM
XrstalLens's Avatar
The Lumagen Radiance XE (not the XS or Mini) supports PiP and PoP (side-by-side) of two input sources.
Lyle Corbin
www.crystalclearhometheater.com
THX Video, ISF, and HAA Level II calibrator
XrstalLens is offline
post #3 of 3 Old 01-23-2012, 09:06 PM - Thread Starter
djshorty's Avatar
Thanks for the quick reply.
I wonder if there is something that mixes audio from 2 sources.
djshorty is offline
Reply Video Processors
