Darbee vision darblet - Page 136 - AVS Forum | Home Theater Discussions And Reviews
 240Likes
post #4051 of 9432 Old 10-05-2012, 02:12 PM
PrinceLH's Avatar
It looks like an interesting little enhancer. I wish that I could try one and make my own judgements.
I own a Samsung BD UP5000 with over a 1000 Blu Ray Movies
I also own a Toshiba D3 & Toshiba A30 plus 175 HD DVD Movies
PrinceLH is offline
post #4052 of 9432 Old 10-05-2012, 02:25 PM
beaglehead12's Avatar
Is there any beta testers
beaglehead12 is offline
post #4053 of 9432 Old 10-05-2012, 02:27 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
Originally Posted by Roxme View Post
I'd rather not use my AVR all the time. So, is anyone using the "pass-through" option successfully on their AVR with a chain such as this? Source => AVR => Darblet = > Display
If so, what AVR do you use and did you have any issues enabling pass-through to work once the Darblet in the chain? I sent my Darblet back for this and other problems. I anticipate receiving its replacement soon. Any advice would be appreciated.smile.gif
I ALWAYS have used 'passthrough' on my Integra DHC-40.1 pre pro, and it works like a champ with the Darblet. My only hope is that it will work with future projectors with a different HDMI protocol? PS3 - Integra - Darblet - JVC RS20 BTW.......
KBMAN is offline
post #4054 of 9432 Old 10-05-2012, 02:28 PM
Sonisame's Avatar
I have darbee sitting between my mits 3800 projector and htpc, I use media player classic with madvr/lav video decoder. Will I notice any difference If I dial down the madvr chroma and luma upscaling (currently I have Lanczos 3 Taps for both)?
Sonisame
Sonisame is offline
post #4055 of 9432 Old 10-05-2012, 02:37 PM
scottd327's Avatar
General impressions after using the Darblet for about 2 months:
1) Using it in the following chain without a single issue or HDMI handshake problem: Source (Sony 3d BD player, Oppo BD player, XBOX 360, Tosh HD DVD and Fios HD DVR) - switched through Onkyo 5009 - out to Darbet - out to Sony VPL-VW95ES projector.
2) No issues learning and using the Darblet remote codes with my Harmony
3) Usually set it at HD 50-75 regardless of source. I have tried the others but the HD mode pops without introducing any obvious exagerrations in the picture. Looks fantastic on most material except grainy 70s films on blu-ray (such as French Connection, Mean Streets, etc) when the Darblet makes the grain look like it is raining hard, in which case I just turn the processing off.
Scott
scottd327 is offline
post #4056 of 9432 Old 10-05-2012, 02:41 PM
Ironpeddler's Avatar
Consensus is this works best with projectors and marginally with Plasma & LCD? I'm trying to figure out if this would help my Samsung 58" plasma with a Comcast signal.
Trying to sift through 136 pages is almost impossible at this point and I've been at it for 2 hours! eek.gif
I guess the 'try it to see if you like it' method has been the most popular answer.
Thoughts?
Ironpeddler is offline
post #4057 of 9432 Old 10-05-2012, 02:48 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6519 Post(s)
Liked: 3613
Thoughts?
The Darblet improves the pictures on my LED and my LCD flat panels, both 52", enough that I consider them a good value for the money.
AustinJerry is offline
post #4058 of 9432 Old 10-05-2012, 03:04 PM
vector1818's Avatar
This looks interesting. I would love to try it out and give my review!
vector1818 is offline
post #4059 of 9432 Old 10-05-2012, 03:13 PM
greaser's Avatar
Quoted: 100 Post(s)
Liked: 61
^^^ Same here. I'd love to take this little gizmo for a ride. I'm all for an enhancer that really,really works! smile.gifcool.gif
greaser is offline
post #4060 of 9432 Old 10-05-2012, 03:21 PM
Rashid81's Avatar
Originally Posted by irfan View Post
Got my Darbee a week ago. It sits between my Pioneer Elite VSX-21 AVR and my Kuro (600m).. I had high hopes for this thing.
It doesnt seem to do anything that DRE doesnt do, I didnt notice anything spectacular. I tried HD and game settings, 0-110, and when the enhancements were noticeable it looked less natural. I ended up preferring the non-enhanced look for most things.
some scenes looked much better with the Darbee, but I noticed that I could accomplish the same thing with DRE controls and Sharpness.
What is DOES offer is a very very fast way of making those changes... its very cumbersome to make the adjustments by hand.
Whether or not that convenience is worth $300, im not sure.
I tried the Darblet with my VT50, and my findings were similar. Definitely not the magnitude of difference I was expecting. To make matters worse, I am getting a fatal handshake issue with my DTR-80.3, hence I am returning the Darbee. I e-mailed Larry from Darbee Vision, and he suggested using longer HDMI cables which I did. Alternatively, he suggested using a different source. I, hence, took the Integra out of the chain and connected it to the BD player. The unit worked fine with the switch, however the effect wasn't as remarkable as I had hoped for. I am intrigued, however, with the poster who is using the darblet successfully with the Onkyo 5009 - since that is a clone of my AVR.
I think its a nifty device, however its effect for me is mitigated by the excellent video processing built in the Integra. The handshake issue makes the Integra and the Darblet mutually exclusive, unfortunately.
Rashid81 is offline
post #4061 of 9432 Old 10-05-2012, 03:21 PM
UHD Addict
aaronwt's Avatar
Quoted: 5196 Post(s)
Liked: 3104
I don't even know if I get an AVS newsletter. I guess I need to check. I have been enjoying both of my Darblets the last couple of days while I was home from work while I was sick. It would certainly be nice to win a third one. smile.gif
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #4062 of 9432 Old 10-05-2012, 03:28 PM
thrang's Avatar
Quoted: 1605 Post(s)
Liked: 1381
I use a darblet with an 80.3 with no issues. I use a lumagen mini in between them, but I've tested without the lumagen and have not experienced a handshake problem
thrang is offline
post #4063 of 9432 Old 10-05-2012, 03:31 PM
Rashid81's Avatar
Really? Then should I request a replacement? I am confused. Thanks for the input. Larry was nice enough to offer a replacement, so that can work.
Rashid81 is offline
post #4064 of 9432 Old 10-05-2012, 03:35 PM
SteveRutledge's Avatar
It sounds like a great tool, I just would like to see one up-close and operating..
Has anyone on this thread used one before..
SteveRutledge is offline
post #4065 of 9432 Old 10-05-2012, 03:40 PM
MCaugusto's Avatar
Quoted: 320 Post(s)
Liked: 201
www.hometheaterhifi.com has just published a rather comprehensive review of the Darblet and the author did not seem all that impressed by it.
He mentioned that he noticed some worthwhile improvement when connected to his projector but when connected to his Pioneer Kuro he hardly noticed any improvement, and he surmised it is due to the Kuro's more limited "inherent contrast enhancing abilities".
I wonder if plasma displays do not show as much improvement with the Darblet connected in line as other displays do ?
MCaugusto is offline
post #4066 of 9432 Old 10-05-2012, 04:04 PM
jkalsaria's Avatar
IMO, yes, I was also confused when i return mine b/c of random reboot issue and later after two days i ask for replacement before i shipped it back and i'm happy that i got replacement unit which works better than before with zero issue.
jkalsaria is offline
post #4067 of 9432 Old 10-05-2012, 05:59 PM
ginolee859's Avatar
Frankly, I'm a bit skeptical. I don't see how the Darblet could really enhance the image that much. The best you can do is to reproduce with perfect fidelity whatever was recorded onto the disc.
Once you start changing the resulting image, even if it might look "better" in some cases, you're actually departing from the fidelity of the original image. And it's hard to imagine any algorithm that always improves on perfect fidelity in a consistent manner.
In terms of having received patents, I think that doesn't mean a whole lot. My understanding is that the US Patent Office grants patents to applicants irrespective of how significant/insignificant it may be. Basically, they assume that if there are patent conflicts the parties involved will hash it out in court.
Many years ago, when Windows was fairly new, there was a product that purported to make your Windows machine run faster and it sold for $50 or so. It actually got numerous good reviews and some customers raved about. Then, I think someone decompiled it and found it didn't do anything ! smile.gif.
Just my two cents..
ginolee859 is offline
post #4068 of 9432 Old 10-05-2012, 06:09 PM
subavision212's Avatar
Quoted: 62 Post(s)
Liked: 38
Originally Posted by audiophill72 View Post
Is anyone using the new Oppo bdp 103 with their darblet yet? My 103 comes in Tuesday and am hoping it works with it as it did with the 93 i sold.
Been using it with mine. I get a brief magenta flash when turning on the 103 that lasts a second or two then it's perfect. Haven't tried a different turn on sequence to see if that might eliminate it (103 to pre/pro to Darblett to display is how I am connected). I always turn on my display first then 103 then pre/pro.
subavision212 is offline
post #4069 of 9432 Old 10-05-2012, 06:28 PM
gurkey's Avatar
Quoted: 113 Post(s)
Liked: 89
I read the review and had the impression, that a device like the Darblet is more or less superfluous following his comments and reading between the (printed) lines of the review. He even preferred a different unit for those actions the Darbee was supposed to do and shine..
The real beauty is probably more in the minds of those, who spent the money on it already, than in its real specs and parameters.
gurkey is online now
post #4070 of 9432 Old 10-05-2012, 07:07 PM
jmschnur's Avatar
I have a kurov151 and see some good effects with the Darblet some of the time but not all. Sports is great. Some he shows yes some not. I have Fios HD.
jmschnur is offline
post #4071 of 9432 Old 10-05-2012, 07:09 PM
Andy Lammer's Avatar
It costs nothing to try one out and formulate your own verdict.
You are aware it costs a measely $280 ???
Comparing the Darblet to a Lumagen XE is like comparing a VW GTI to an M3, no wait, an M3 is still too punk - make the comparo to a GT3-RS
Saying we Darbee owners are biased merely because we shelled out some $280 chump-change is rather silly.
- Andy
Andy Lammer is offline
post #4072 of 9432 Old 10-05-2012, 07:28 PM
CeliaD's Avatar
Will it work with a Tivo HD?
Celia
CeliaD is offline
post #4073 of 9432 Old 10-05-2012, 07:41 PM
ginolee859's Avatar
(my bad). self deleting my post because it was misinformed..
post #4074 of 9432 Old 10-05-2012, 07:47 PM
jetnc's Avatar
I'm curious if I would have any handshake issues with this and my Sony NSZ GT-1-1? It looks interesting.....
jetnc is offline
post #4075 of 9432 Old 10-05-2012, 08:15 PM
dannybenz's Avatar
Quoted: 13 Post(s)
The reviews in the Google search are for the Amazon site itself, not for the product. This so that people can know whether or not they can trust buying from them. When you search a single product, you get a list of stores who sell it and reviews for each store. If all the reviews were for the product, they wouldn't separate the number of reviews by store. This is obvious and does not seem like false advertiaing at all.
Sent from my Nexus 7 using Tapatalk 2
dannybenz is offline
post #4076 of 9432 Old 10-05-2012, 08:28 PM
ginolee859's Avatar
dannybenz, thanks for correcting me. You're absolutely right. I've essentially deleted my misinformed post..
post #4077 of 9432 Old 10-05-2012, 08:36 PM
RBFilms's Avatar
Agreed regarding fidelity...
"Fidelity" is what matters...in most cases....or at least with good source material....smile.gif
Richard J. Casey
Disney WOW - World of Wonder
Producers Guild of America, New Media Council
(BD Industry Insider)
RBFilms is offline
post #4078 of 9432 Old 10-05-2012, 09:26 PM
AndyN's Avatar
Quoted: 23 Post(s)
Yes, always read between lines of a single persons comments and ignore those of actual owners. That's how we should all do things. Makes things more interesting. I stupidly ignored my eyes and the money back guarantee from AVS because I wanted to do what the cool kids do.
AndyN is offline
post #4079 of 9432 Old 10-05-2012, 10:36 PM
Liked: 3613
What do you mean?
post #4080 of 9432 Old 10-05-2012, 11:25 PM
AndyN's Avatar
Quoted: 23 Post(s)
Just being sarcastic after Darbee owners were accused of just imagining the benefits it provides.
AndyN is offline
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
