Darbee vision darblet - Page 187 - AVS Forum | Home Theater Discussions And Reviews
 239Likes
post #5581 of 9432 Old 02-19-2013, 10:05 AM
grizimes's Avatar
Liked: 29
Loving my Darbee, had it for a few months now, use it with a Yamaha RXV-671. I run all my components ((XBOX 360, Panny Blu Ray, and Pace DVR from Insight) into the Yammy ARC output to a Sony XBR4. I have never had issues with the Darblet. ARC seems to work fine with my unit. Only issue I've had is on occasion when I switch inputs, audio may not come out instantly, I have to switch back to the input for it to work. Not a real issue for me...
grizimes is offline
post #5582 of 9432 Old 02-19-2013, 03:04 PM
trailblazer's Avatar
Quoted: 21 Post(s)
Originally Posted by kiwi2000 View Post
Review February 2013
1.+ Re calibration,(long overdue anyway) has solved this issue and Darbee at any but the highest setting does not affect the whites blooming but only improves the image.
2.- Yes agree, more of what is present within the image with Darbee engaged is presented and enhanced for better or worse.
3.+ Big yes.
4. Neither + or - I still concur with my first reaction. Still images are strikingly different and better via Darbee, I do not see that same striking in your face difference on moving images.
5. Neither + or - Same no 3D. I do not know what that gushing editor Gary Reber of widescreen review was doing prior to his review of this product that day but there is no 3D effect with this product .
6.+ I am now positively sure that the Darbee treated images are more satisfying to view, deep and richer than untreated images. Easily seen.
7.Neither + or - True.
8. Neither + or - Although this is again true.
But that is just for two pair of glasses. Also the 3D hardware purchase is restricted to 3D material only and 3D sources are pricey compared to their non 3D counterparts.
Only two people are included in this scenario, extra glasses $100.00 a pop. Batteries are $$$ that do not last long.
So 3D delivers more bang but less accessibility and versatility as the Darbee improves all images presented for all viewers. You cant have a 3D movie on for 8 and have two pair of glasses handy.
Out of my eight initial observations, 3 are positive.
For the increase in perception alone #3 supplied by this product is worth the price.
I am pleased with the purchase although there have been unforeseen HDMI compatibility issues that unfortunately will remain unresolved.
The HDMI compatibility issues with Darbee apparently only affect Marantz product.
I have a Marantz AV8003 outputting to the Darbee which outputs to an Epson 1080 Pro Projector and have not had any issues with the Marantz.
What kind of issues are you experiencing?
trailblazer is offline
post #5583 of 9432 Old 02-19-2013, 04:41 PM
kiwi2000's Avatar
Quoted: 13 Post(s)
Posted by buckley44
Hi, just picked up the Darbee today and connected and will not sync or handshake properly, I have a problem with my comcast box handshake with the Darbee i believe, It is working properly with the blu ray player although the handshake seems to take longer than usual.With the comcast the screen keeps flashing and has a message that my display is compromised.Using the Darbee with a Marantz, sony 50es projector and my comcast box. Can anyone offer some advice.
What is the Marantz product you are using in your system?
I had the exact same issue when attempting to run HDMI switching through the Marantz Av-8003. Same message as well.
Cable company came switched out the box, same problem, reset, same problem.
It is not the cable box it is how the Darbee and Marantz do not mesh via HDMI.
After much fussing around I ended up with a compromise. No Darbee on Blu ray.
I run straight from the Oppo to the main display via HDMI.
The cable box goes through Darbee then a splitter to the TV's in the home, all Darbee'd.
No HDMI switching is performed by the Marantz now unfortunately.
It wont work routed through the Marantz. I am still awaiting a reply from Marantz on this issue however.
I think I will be waiting a while.
What HDMI sources are routed through the Marantz then to Darbee?
I and others are only experiencing an issue with HD cable routed through the Marantz.
kiwi2000 is offline
post #5584 of 9432 Old 02-19-2013, 04:58 PM
UHD Addict
aaronwt's Avatar
Quoted: 5194 Post(s)
Liked: 3102
3.+ Big yes.
The second pair of active shutter glasses(Samsung) I bought was under $20. The first pair of active shutter glasses(Xpand) I bought was $70, but they also included the Bluetooth emitter. I plan on getting a second Xpand pair of BT glasses. They are only $30 right now on Amazon. The passive glasses I use on my secondary TV are even less expensive, around $4 each when bought in a pack of six.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #5585 of 9432 Old 02-19-2013, 07:18 PM
wattheF's Avatar
Quoted: 96 Post(s)
Liked: 152
Originally Posted by wattheF View Post
Can anyone out there using a Darbee with either a ST/GT/VT-50 comment on the PQ improvements? In particular does it help with the somewhat soft look of certain (lower quality) HD Cable content? and does it do so at the cost of an even more grainy picture than it can sometimes already have?
Anyone else???
wattheF is offline
post #5586 of 9432 Old 02-20-2013, 06:21 AM
buckley44's Avatar
Quoted: 56 Post(s)
Liked: 33
Still have the same issue with mine,so for now I'm just using it for blu ray.
buckley44 is offline
post #5587 of 9432 Old 02-20-2013, 03:34 PM
chad473's Avatar
Quoted: 113 Post(s)
Liked: 121
Got my darblet yesterday. Have to echo a lot of the impressions on here. I have a pretty mild prescription, but it's akin to slipping my glasses on and off when the darbee is engaged. Details in faces/hair/landscapes snap into focus with it on. I think anywhere from a 5-15/20% increase in quality depending on the content is fair. That's what I'm noticing so far on my 50" panasonic S1 (modest 2009 plasma). CGI sources like Avatar and Wreck it Ralph really saw impressive results. If nothing else, it's breathed a bit of new life into this set since I'm not looking at upgrading anytime in the near future.
I didn't think I'd ever touch full pop mode, but I can see myself using it sparingly on some sports. I haven't cared about the NBA in almost 20 years, but I just watched most of the first half of this Celtics/Lakers game on ESPN because of the effect on perceived contrast and depth. It's fairly striking.
tampa8 likes this.
Vizio P50-C1 - My Calibration Settings
Xbox One S 2TB
PS4 Pro 2TB
chad473 is online now
post #5588 of 9432 Old 02-20-2013, 10:31 PM
nikolausp's Avatar
3.+ Big yes.
Regarding #3.... what are you referring to when you say, "black image"?
I'm not sure what a black image is, in regards to TV content.
nikolausp is offline
post #5589 of 9432 Old 02-21-2013, 07:15 AM
kiwi2000's Avatar
Quoted: 13 Post(s)
Better deeper richer blacks.
Make the rest of the image pop.
kiwi2000 is offline
post #5590 of 9432 Old 02-21-2013, 09:31 AM
RickAVManiac's Avatar
Quoted: 166 Post(s)
Liked: 153
Just bought a Darbee. Last night I was trying to install the device and never been able to make it working. Iv'e got the red led on the power supply, the green led is flashing but no blue led and of course no image on my projector.
I think I have try everything from changing HDMI cable, put the darbee before the my Denon receiver, put the darbee after the Denon, bypass the Denon and put the Darbee with just my blu ray player and the projector... All that test with no luck...
Any ideas?
RickAVManiac is offline
post #5591 of 9432 Old 02-21-2013, 09:42 AM
cdnscg's Avatar
Quoted: 299 Post(s)
Liked: 50
Any ideas?
Try shutting off the deep color, and set to 4:2:2 on your blu-ray player. Also, what length of cable are you using between the darbee and other units? Apparently there could be an issue with smaller than 6'
cdnscg is offline
post #5592 of 9432 Old 02-21-2013, 11:58 AM
Quoted: 166 Post(s)
Liked: 153
Any ideas?
Thanks for the tip.
I will try that tonigh. My calbles are about 3 feets long.
post #5593 of 9432 Old 02-21-2013, 04:27 PM
fpr
fpr's Avatar
Quoted: 12 Post(s)
I have the following questions:
- What version of software and firmware of Darbee is the latest ?
I have the next version:
Software version: 2.8.2214
Firmware version: 1.3.21
Do I have the latest version?
- What options has the "fine adjustement" of the advanced menu?
- When I turn off my sources and TV the blue led of the Darbee remaining on and blinking. It's normal?
My Lumagen videoprocesor sending signal through the HDMI output even when is in standby (keeps it's "Standby power" active), Could this be the explanation of the blue led?
fpr is offline
post #5594 of 9432 Old 02-21-2013, 05:11 PM
p5browne's Avatar
Quoted: 2794 Post(s)
Liked: 2117
Thanks for the tip.
3 feet on each side gives you your 6 feet. This is what I have on mine with no issues.
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is online now
post #5595 of 9432 Old 02-22-2013, 07:10 AM
rczarne's Avatar
What HD setting have you found works best ? I also have a 50" S1 .
rczarne is offline
post #5596 of 9432 Old 02-22-2013, 08:36 AM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
Just got my darbee last night...I wanted to make sure I have it setup properly. I'm not at home and i'm going off memory:) My projector is connected to Output and I have another HDMI cable going from Input connected into the output HDMI connector on the Receiver. Is this correct.?
JoeBoy73 is offline
post #5597 of 9432 Old 02-22-2013, 08:38 AM
avswilier's Avatar
Correct!
avswilier is offline
post #5598 of 9432 Old 02-22-2013, 08:46 AM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
Thanks avswiller! I was kinda nervous...lol! It's really a great device. I'm going to spend some time dialing the settings on my HTPC this weekend. Curious....is it better to turn off all the AMD picture inhancing and let the Darbee do its thing?
JoeBoy73 is offline
post #5599 of 9432 Old 02-22-2013, 01:18 PM
ferbal's Avatar
Thanks avswiller! I kinda nervous...lol! it's really a great device. I'm going to spend some time dialing the settings on my HTPC this weekend. Curious....is it better to turn off all the AMD picture inhancing and let the Darbee do its thing?
try both and keep the one you like most
ferbal is offline
post #5600 of 9432 Old 02-22-2013, 08:11 PM
musicalfox's Avatar
Quoted: 16 Post(s)
Quick question to all you Darbee experts (as I am planning to purchase a unit this week): I have a 30ft Monoprice Redmere HDMI running from my Integra pre-amp to an Epson 6010 PJ. If I slot in the Darbee just before the projector with a 24AWG 1ft extension HDMI, I shouldn't have any problems, right? I only ask because Monoprice Live Chat said that sometimes video will not pass when an already-long HDMI is extended. I have no experience of this, so wondered if I need to be prepared for any eventualities? Many thanks in advance for any replies...
musicalfox is offline
post #5601 of 9432 Old 02-22-2013, 09:00 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
I tried using a Monoprice 60ft Redmere from my HDMI switcher to the Darblet and then run a 1ft QED Qunex cable with no problem at all. running it the other way round also yields no problem.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #5602 of 9432 Old 02-22-2013, 11:52 PM
musicalfox's Avatar
Quoted: 16 Post(s)
Thanks, David. I approve of the THX certification! (I actually worked for the company for many years in sales and marketing out in Nicasio.)
David Susilo likes this.
post #5603 of 9432 Old 02-24-2013, 12:37 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
I also have a 'redmere' cable coming in the mail in a few days. A 40ft ultra-slim to be exact. My older 22AWG HDMI 35 footer cannot handle blurays very nice, but the Darblet did not introduce any more problems, just more solutions wink.gif
I'm going to have a high-speed passive cable coming out of the PS3 to my Integra PreAmp, then out to Darblet, then the 40ft monoprice medmere cable going to the projector. I will of course test it in the theater room before going up in the attic wink.gif This should all work, if my calculations are correct..... eek.gif
KBMAN is offline
post #5604 of 9432 Old 02-24-2013, 01:45 PM
Quoted: 612 Post(s)
Liked: 584
Cool! For the past 4 years or so I've been using THX as part of my lectures that I do worldwide (17 countries not including US and Canada so far).
RedMere, to me, is a godsend. 60ft with no repeater and I only need to use 28AWG is just amazing, considering HDMI LLC recommends 30ft max when using 22AWG cable.
my home theatre
post #5605 of 9432 Old 02-24-2013, 09:11 PM
chad473's Avatar
Quoted: 113 Post(s)
Liked: 121
So far, around 60%
Xbox One S 2TB
PS4 Pro 2TB
post #5606 of 9432 Old 02-25-2013, 09:40 AM
CheYC's Avatar
Quoted: 35 Post(s)
Liked: 56
Will this effect the ARC if put in that chain? i.e. I have PS3 and cable going into a Denon receiver and the output of the receiver going into the ARC HDMI input in my TV, would putting the Darbee in the output chain effect the ARC?
CheYC is offline
post #5607 of 9432 Old 02-25-2013, 11:38 AM
kevin_mahaney's Avatar
Liked: 26
Yes, it disables ARC.
kevin_mahaney is offline
post #5608 of 9432 Old 02-25-2013, 10:21 PM
Latinoheat's Avatar
Quoted: 1079 Post(s)
Liked: 826
I have it hooked up to my GT50 and it definitely improves the image " what some say soft looking" the most improvement is on close facial shots you can see every wrinkle and hair incredibly detailed. I never experienced any grainy ness on HD channels on my GT50 unless the movie was filmed that way. But if the movie was filmed grainy it will expose it more. Overall I love my Darbee it does a great job with HD, Bluray and PS3 games. With SD cable channels there isn't much improvement since its crap anyways. The only problem I wish they fixed was the compatibility with ARC. I have all my components HDMI to my Onkyo 1080p up scaling -Hdmi-Darbee-Hdmi to GT50. All good.
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is online now
post #5609 of 9432 Old 02-25-2013, 11:26 PM
xplorar's Avatar
Quoted: 37 Post(s)
A question for Darblet users -
I am using Darblet at HD 60% with Epson 5010 projector. When I view 3D material, the picture contrast and sharpness nosedives (this is inherent 3D weakness and can't be helped) and therefore I temporarily tweak-up Darblet levels for 3D. My dilemma here is - whether to set setting at 75-80% HD or just shift to 60% Gaming/Full Pop. What do you recommend?
xplorar is offline
post #5610 of 9432 Old 02-26-2013, 05:02 AM
LBJ2's Avatar
Hello: I have listed my very lightly used Darbee vision darblet for sale. Please see
http://www.avsforum.com/t/1460289/darbee-darblet-model-dvp-5000 if interested.
I really enjoyed the Darbee effect on my Sony LX900 LCD/LED -- however I ended up replacing my Sony with a new Panasonic Plasma which I am able to calibrate more extensively to the PQ I prefer therefore no need for the Darbee with my Plasma.
LB
LBJ2 is offline
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
