Darbee vision darblet - Page 190 - AVS Forum | Home Theater Discussions And Reviews
 261Likes
post #5671 of 9498 Old 03-10-2013, 04:32 AM
bkazepis's Avatar
Get a receiver...then the Darbee...IMHO... :-)
Exitus acta probat...
bkazepis is offline
post #5672 of 9498 Old 03-10-2013, 04:50 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 746
2 Data points for darblet un-wanted re-set and display logo:
Turned on the HT, nothing unusual to the sequence, saw the logo....This happened last week (these photos) and again last night (no photos taken for that)
I have my darblet at the end of the signal chain, sitting atop my PJ as shown, the HDMI goes into it from my Denon 4520CI, then I use a 6' HDMI cable into my Sony VW60
This is an annoyance, and every time it happens I will post here and recommend others do so as data points for the manuf to study.
I work for an Auto OE and do realize the amount of HW/SW debugging needed for a robust product....for whatever reason the darblet is resetting itself w/o command from user, that is simply a bug in it and needs to be fixed.
mtbdudex is online now
post #5673 of 9498 Old 03-10-2013, 06:16 AM
David Susilo's Avatar
Quoted: 619 Post(s)
Liked: 586
Originally Posted by rightintel View Post
Thanx for all the replies. I don't have a receiver(no surround), so what do you all recommend for the switcher? Wouldn't going thru a switcher negate the improvements?
Any powered switcher will do. But at the same time the price of a powered switcher is the same as an entry level receiver. I'd get a receiver if I were you.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #5674 of 9498 Old 03-10-2013, 11:45 AM
johng's Avatar
Quoted: 23 Post(s)
Liked: 30
Originally Posted by David Susilo View Post
1. Yes
2. Yes
3. Works like a charm
4. You'll need either a receiver or a switcher to consolidate all your inputs as one input.
To amplify on #4, I would recommend that you insert the Darblet between your receiver and your projector. That allows your receiver to act as a switcher
cemo62 likes this.
Good Viewing,John G  JVC DLA-RS4810 Projector, Vutec 110" (16x9) Bright White Screen, Oppo UDP-203 disc player, Darbee Darblet, Onkyo TX-NR708 Receiver/Processor, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,  Adcom & Yamaha Amps
johng is offline
post #5675 of 9498 Old 03-10-2013, 02:27 PM
johng's Avatar
Quoted: 23 Post(s)
Liked: 30
Keep and eye on the Darblet. Mind starting showing the 100% randomly and fried soon after. They are good people to work with and stand behind their product.
johng is offline
post #5676 of 9498 Old 03-10-2013, 04:52 PM
rightintel's Avatar
Quoted: 568 Post(s)
Liked: 203
I suppose I could go that route, but it does seem weird buying a receiver w/ no surround just for an HD processor...
Xbox Live: General PATT0N
rightintel is offline
post #5677 of 9498 Old 03-10-2013, 04:58 PM
Quoted: 619 Post(s)
Liked: 586
or as mentioned earlier, if you don't need more than 4 inputs, you can get Monoprice powered switcher for about $80 shipped.
my home theatre
post #5678 of 9498 Old 03-10-2013, 05:02 PM
rightintel's Avatar
Quoted: 568 Post(s)
Liked: 203
When you mentioned entry level receivers being the same cost as the switcher, I mistakenly figured about triple that. $80 is no sweat though.
post #5679 of 9498 Old 03-10-2013, 05:27 PM
johng's Avatar
Quoted: 23 Post(s)
Liked: 30
Pardon. I didn't realize you are in the buying stage. It'll be difficult to find a receiver with HDMI switching and no surround functions/amps. IMHO, the Darblet should be between your video display and source component(s), whether it is a direct feed from a blu-ray player or an AVR. As others have pointed out, there are HDMI switchers and Monoprice is a good source for inexpensive ones. Check user reports before ordering one. Some seem to work better than others. Make sure the one you look at is HDMI 1.4a compliant.
Good Luck,
johng is offline
post #5680 of 9498 Old 03-10-2013, 06:28 PM
p5browne's Avatar
Quoted: 2894 Post(s)
Liked: 2207
Might I ask - How much heat is there on top of that projector? I have my Darbee heat sinked top and bottom to keep it cool!
The heat up the near to the ceiling, add what the Darbee creates, plus what the projector is producing must make it a bad scenario re cooling!
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is offline
post #5681 of 9498 Old 03-11-2013, 03:25 AM
jnabq's Avatar
Liked: 39
Doesn't negate the process, but may introduce a handshake issue that may require some cable swapping/replacement. Adding another connection in the chain can degrade the strength of the signal slightly, more so if you have a long run of cheap cable. I'm using a monoprice 3X1 enhanced, but if you search the thread, a few different ones have been reported to work just fine.
jnabq is offline
post #5682 of 9498 Old 03-11-2013, 09:05 AM
nakenergy's Avatar
I have a calibration scheduled for tomorrow. Wanted to know if I should leave the darbee in the chain when calibration is done or remove it and re-install after the calibration? This is not a professional calibration but a Best Buy ISF calibration - do not want to go in to positives and negatives of BB based calibration since it is free and my display is Pioneer Plasma, 3 years old.
nakenergy is offline
post #5683 of 9498 Old 03-11-2013, 09:15 AM
Texas steve's Avatar
personally I would leave it out.   after all you are calibrating the projector/tv, not the darbee.
Texas Steve
Texas steve is offline
post #5684 of 9498 Old 03-11-2013, 09:37 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 746
A good question, as can be seen my PJ is open, not in a hush box, the PJ heat vents are on the front, the darblet is at the rear,
There is no "bad scenario" for cooling at all, however being fact based I'll use my IR therometer and post those for sharing.
The better question is:
What are the darblet's DFMEA and DVP&R related to thermal loads, heat cycle testing, etc.
How is it designed for "normal" usage in peoples HT?
What assumptions went into the relability of the design? What thermal values does it expect to see?
On the re-set issue:
What software DFMEA and DVP&R and debugging was done to ensure the re-set did not happen?
What fix can be pushed to people in the field?
post #5685 of 9498 Old 03-11-2013, 12:57 PM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
Chad B. told me he leaves it out...
hodges69 is offline
post #5686 of 9498 Old 03-11-2013, 01:26 PM
p5browne's Avatar
Liked: 2207
Did a before and after reading with the Darbee in and out. Found it did affect the Red somewhat on my system. So, I leave it in so the calibration is also taking into account with what Darbee is doing to the signal. Also - the best setting - 55 MAX HD before, 70 MAX HD after. So definitely Darbee is affecting the signal, so you might as well account for it in the calibration.
p5browne is offline
post #5687 of 9498 Old 03-11-2013, 05:31 PM
alternety's Avatar
I bought a powered HDMI cable from Monoprice to see if the regeneration of the signals would make things work. Unfortunately, after I got the system set up so the receiver used the fiber link for audio, I inadvertently changed something and the receiver is no longer outputting menus on the composite interface. Now I can't see receiver menus to experiment. Oh how I love this experience! And I really don't feel like a factory reset on the receiver at this point.
alternety is offline
post #5688 of 9498 Old 03-11-2013, 07:44 PM
WynsWrld98's Avatar
Quoted: 281 Post(s)
Liked: 109
Originally Posted by WynsWrld98 View Post
I've experienced the exact same thing a few times, have not figured out a pattern to when it happened (and no I didn't have a power outage when it happened).
This was regarding Darbee by itself going to Full Pop and onscreen display coming on and staying on by itself (same as pic mtbdudex posted above). I had it happen last night when I switched from watching a 3D Bluray (movie was over) to 2D DVR. I have the Darbee between the output of my Denon 4311 and the input of my Epson 6010 projector. Pretty annoying since I had to adjust the setting back to the way it was and also go into the menu to get rid of the onscreen display. Ugh.
WynsWrld98 is offline
post #5689 of 9498 Old 03-11-2013, 08:35 PM
fookoo_2010's Avatar
Quoted: 236 Post(s)
Liked: 82
I had a professional calibration, not Best Buy, done some months ago, the calibrator wanted it left out. And that's what happened. Someone suggesting leaving in the loop, has to wonder what would happen to his calibration should the Darbee go kaput. A lot safer to leave it out.
fookoo_2010 is offline
post #5690 of 9498 Old 03-11-2013, 09:05 PM
p5browne's Avatar
Liked: 2207
A lot of other factors factor into the final PQ you're going to get. Humidity, furniture being moved, voltage swings, electronic values changing in all the equipment from turning off and on, and how long it's been on. No calibration stays static: the Darbee going kaput is the least of my worries. Mr Blackburn states that the Darbee is affecting the signal from what the director of the film intended, so my reply was then to leave the Darbee in, so it's part of meeting calibration criteria, and therefore should be affecting the end result less.
p5browne is offline
post #5691 of 9498 Old 03-11-2013, 11:38 PM
Quoted: 236 Post(s)
Liked: 82
Of course, you are entitled to your own opinion. If your calibration is changing that much, then good luck, with all those variables you list and have to be concerned about.
post #5692 of 9498 Old 03-12-2013, 05:53 AM
praz's Avatar
Liked: 26
It has been shown several times now that the Darblet has no effect on calibration. Also, the images used for calibration have no content for the Darblet to act upon. However, you are calibrating the display so there should be nothing else in the chain between the pattern generator and the display. Like has been written above leave it out.
praz is offline
post #5693 of 9498 Old 03-12-2013, 06:15 AM
tampa8's Avatar
Quoted: 221 Post(s)
Liked: 152
Very true about all those factors. I bet calibrations show a slight change after just a few months. Even if the Darbee should die and you don't get another one, it's effect on calibrating is minimal at best, as has been demonstrated by others than Dr. Darbee.
That said, if you have a pro calibrator that feels it should be out, no big deal I would do it his way. He may or may not be familiar with the Darbee.
tampa8 is offline
post #5694 of 9498 Old 03-13-2013, 11:04 AM
RickAVManiac's Avatar
Quoted: 184 Post(s)
Liked: 166
So my current DarbeeVision is for sale... If someone is looking for a Darbee at a very good price please send me a personal message.
RickAVManiac is online now
post #5695 of 9498 Old 03-13-2013, 03:51 PM
noah katz's Avatar
Quoted: 945 Post(s)
Liked: 321
Anyone sent a Darblet in for f/w update recently?
If so, how'd you go about it?
I emailed Larry at Darbee on 3/5 and haven't heard back.
Noah
noah katz is offline
post #5696 of 9498 Old 03-13-2013, 05:41 PM
tampa8's Avatar
Quoted: 221 Post(s)
Liked: 152
Originally Posted by RickAVManiac View Post
Very jealous. Let us know how you like it.
tampa8 is offline
post #5697 of 9498 Old 03-13-2013, 07:11 PM
musicalfox's Avatar
Quoted: 16 Post(s)
I just received my Darbee, made all the connections, and I have a faint red light and a blue intermittent light for video processing, but no pulsing green light (for micro-controller running 'normally'). And no picture obviously. Can anyone help me troubleshoot?
Chain is Panasonic DMP BD-30 - Integra DTC 9.8 - Darbee - Epson 6010
The green light is only showing when the power cord is attached, but then ceases to show at one-second intervals as specified.
musicalfox is offline
post #5698 of 9498 Old 03-13-2013, 07:51 PM
Quoted: 184 Post(s)
Liked: 166
I will for sure...
post #5699 of 9498 Old 03-14-2013, 06:40 AM
tampa8's Avatar
Quoted: 221 Post(s)
Liked: 152
You will need all new equipment.
Just kidding...
Make sure you are going into and out of the Darbee on the correct sides.
Make sure you do not have Deep Color turned on.
If you have other HDMI cables try them
If one or both are short, (4' or less) try a longer one. (I have personally seen how too short does not work sometimes in applications)
If the Player has the settings for RGB and YCBCR, if RGB try changing it.
tampa8 is offline
post #5700 of 9498 Old 03-14-2013, 01:58 PM
musicalfox's Avatar
Quoted: 16 Post(s)
Just kidding...
Many thanks, Tampa8. Double-checked all the things on your list. Unfortunately the only way I can it to work is to slot the Darbee in between my BD player and the Integra, it just won't play ball when it's located outbound from the Integra. Anyway, it works, and as I only use my theater for movies (and not TV or gaming), it's a satisfactory resolution, if not ideal.
tampa8 likes this.
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
