Darbee vision darblet - Page 226 - AVS Forum | Home Theater Discussions And Reviews
 241Likes
post #6751 of 9440 Old 08-28-2013, 09:41 AM
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 43
Originally Posted by jdonigan View Post
My Darblet has begun to reset to default every once in a while for no reason. Any suggestions?
Nope, there is nothing that seems to fix that bug. It seems the less you play around with it the more stable it is. I hardly ever change the settings and I have only had two resets over the last year and it has been plugged in the entire time.
tampa8 likes this.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #6752 of 9440 Old 08-28-2013, 10:27 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
Could be caused by power outages. If your Darblet is not connect to a battery backup, that is something to try.
JRWalker is offline
post #6753 of 9440 Old 08-28-2013, 10:54 AM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
Doubt it...it just seems to be the nature of the beast....a lot of posts have been dedicated to this problem with no cure as yet..if ever....you never know when it will happen,so you can either return it or live with the random problem....for what the Darbee brings,it is worth the occasional re-set IMOThat is .beyond question.
tampa8 likes this.
hodges69 is offline
post #6754 of 9440 Old 09-03-2013, 03:47 AM
soundsgoodrecord's Avatar
hi guys,
just got a darblet but need a hdmi cable from av receiver to the darblet. from darblet to projector is 20'. what is the recommended length from av receiver to the darblet?
sony vpl-vw320es/screen innovation black diamond 108", Denon avrx7200wa, Audiolab 8200P,
oppo udp-203, ps4, apple tv, goldenear triton three, supercenter xl, invisa htr7000, invisa 525, aon 3 & 2, forcefield 5 x 2, wireworld ultraviolet 7, wireworld chroma 7 hdmi, qed revelation speaker cable.
soundsgoodrecord is offline
post #6755 of 9440 Old 09-03-2013, 04:46 AM
Webbj's Avatar
6 feet pretty much guarantees no hdmi handshake problems.
Webbj is offline
post #6756 of 9440 Old 09-03-2013, 10:27 AM
erkq's Avatar
Quoted: 601 Post(s)
Liked: 433
Yes, and just for clarity... that's a minimum.
erkq is offline
post #6757 of 9440 Old 09-03-2013, 11:14 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
I have done a lot of cable testing with my Darblet 5000.
For my Darblet it is a minimum for BOTH the input and output connections.
That is 12' of HDMI cable and the Darblet replaced my 4' pre-Darblet cable.
Tried every combination of 2', 4', and 6' for input and output and only 6' + 6' worked.
Clarification:
1) By worked I mean produced a picture from my Darblet 5000 on my Samsung PN60F8500 .
2) In addition to cables lengths also tried all length combinations on my cable DVR, blu-ray, and av receiver.
Again, regardless of source only 6+6 produced a picture on my Samsung PN60F8500.
3) Just for the heck of it, I also tried replacing my PN60F8500 with a computer monitor with HDMI input and you guessed it only 6+6 produced a picture on the monitor.
JRWalker is offline
post #6758 of 9440 Old 09-03-2013, 11:24 AM
erkq's Avatar
Quoted: 601 Post(s)
Liked: 433
+1, glad you pointed that out!
erkq is offline
post #6759 of 9440 Old 09-03-2013, 02:01 PM
vagos1103gr1's Avatar
Quoted: 34 Post(s)
To me with 3 feet on input and 10 feet output I don't have any problem.
vagos1103gr1 is offline
post #6760 of 9440 Old 09-04-2013, 02:46 AM
tks for replying guys. I'm a newbie in the HT world, what does handshake mean?
i have an extra 5' hdmi would that work? if not i will have to buy a 6' hdmi.
post #6761 of 9440 Old 09-04-2013, 04:07 AM
Apgood's Avatar
Quoted: 77 Post(s)
Liked: 44
I have a 1/2 metre cable from my avr to darblet and then 7 metre cable from darblet to TV and it works fine.
Apgood is offline
post #6762 of 9440 Old 09-04-2013, 04:14 AM
migraine24-7's Avatar
Liked: 191
In a nutshell "handshake" means that two devices (in your case Darbee and tv) won't connect well. Picture could be missing completely or drop in and out. Like a handshake the connection between the two needs to come from both sides. You know how you hate the guys who either give you the "dead fish" or "grip too soon" handshake? mad.gif So do devices using HDMI cables. smile.gif
As far as your 5ft cable, try it! It won't hurt anything and if you're one of the lucky few it might work. Let us know your results. Good luck.biggrin.gif
GO BLUE
migraine24-7 is offline
post #6763 of 9440 Old 09-04-2013, 04:46 AM
hahaha! understood. will be trying it out tonite n let u guys know.......
tks migraine24-7
post #6764 of 9440 Old 09-04-2013, 07:11 PM
changboy's Avatar
Liked: 53
Hello its my first post here and i wanna ask you if someone in here use the darbee with 65ZT60 and what about the result on the picture ?
changboy is offline
post #6765 of 9440 Old 09-04-2013, 07:17 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
It works great. The Darbee Darblet literally works with ANY display I have tested/calibrated/installed (more than 50 of them)
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #6766 of 9440 Old 09-04-2013, 07:21 PM
changboy's Avatar
Liked: 53
Ok thank you for the info. What is ur setting then ? 50 % ?
changboy is offline
post #6767 of 9440 Old 09-04-2013, 09:09 PM
Quoted: 612 Post(s)
Liked: 584
Depending on the display size vs viewing distance ratio, it runs between 45% to 55%. For me personally, since I always sit at THX recommended viewing distance, 55% is my subjective ideal.
my home theatre
post #6768 of 9440 Old 09-04-2013, 09:13 PM
changboy's Avatar
Liked: 53
I have a 65ZT60 and iam at 7.4 feet
changboy is offline
post #6769 of 9440 Old 09-04-2013, 09:45 PM
Latinoheat's Avatar
Quoted: 1088 Post(s)
Liked: 830
You will play with the settings once you get it, most people prefer anywhere from 45-65% HD, other prefer 45-75%Gaming setting. It does make a difference .
Media room- LG 4K OLED EG9600, Pioneer Elite VSX-90, Samsung 4K K8500, Klipsch Gallery G28's, Klipsch Sub 12, Klipsch RS-52 II, Optik HD cable
Living room- Sony 4K 79XBRX900B, Onkyo RC-360,HTPC, Klipsch Reference R-62II, Rc52II,PS4
Gaming room -Panasonic ST60, PS3, Wii
Latinoheat is offline
post #6770 of 9440 Old 09-04-2013, 11:21 PM
Liked: 191
Hello fellas,
I'm getting ready to install my Darbee. I've seen people say to install it closer to the display and others say it doesn't matter. It wouldn't be difficult for me to do it either way. But making adjustments to it would be easier if it were in my AV rack and not in the ceiling next to my projector. I'm using a Harmony 900 so I could run a really long ir blaster if in ceiling is the preferable location. Adam Darbee told me it should be fine either way.
So what are your opinions? Thanks
GO BLUE
post #6771 of 9440 Old 09-05-2013, 12:31 AM
changboy's Avatar
Liked: 53
i just buy it and now i wait for delivery hehehe, hope i will like it. Thanks for all info
changboy is offline
post #6772 of 9440 Old 09-05-2013, 12:35 AM
hi guys,
use 5' to input and 20' to output hdmi woks just fine. the result was satisfying. i like hi-def setting at 85% can tell the improved detail on the skin tones on samuel's face on the avengers. more sharp images without any artifacts and no over sharpening. i dont know its me or motion blur got better to, is smoother. now my projectors calibration is back to default, almost everything is back to zero after using darblet. another satisfy darbee user, tks DD.
sorry if my explanation is not so accurate as im a newbie. can i just leave the darbee on 24/7? unplugging it everyday is a hassle.
post #6773 of 9440 Old 09-05-2013, 08:06 AM
GatorJZ's Avatar
Quoted: 54 Post(s)
Liked: 61
hi guys,
You can leave it plugged in...it draws very little current. A better solution, and one that will save you money, is to use one of the new "green" surge protectors. Plug your TV into the master outlet, your Darblet, HT receiver, Btu-ray player and powered subwoofer into the controlled outlets. When you turn off the TV, ALL power is shut off to the controlled outlet saving you the devices' standby power consumption.
Samsung UN50HU8550, Vizio P602ui-B3 & Vizio M43‑C1.
GatorJZ is offline
post #6774 of 9440 Old 09-05-2013, 09:07 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
As I have posted before http://www.avsforum.com/t/1399154/darbee-vision-darblet/6600_100#post_23580238, plugging Darblet into switched outlets on "green" surge protectors does not work for me because the Darblet's several second boot time interfers with TV / source HDMI handshaking, which results in a magenta picture on my PN60F8500.
It does, of course, work if plugged into unswitched outlets on a "green" surge protectors.
Italic added for clarification.
JRWalker is offline
post #6775 of 9440 Old 09-05-2013, 11:46 AM
changboy's Avatar
Liked: 53
I buy it from solid signal, open box so its 259 but coz iam in Canada i have shipping cost of 34.56, lol all is more expensive in Canada the USA, like my 65ZT60 i pay 5500 tax in
changboy is offline
post #6776 of 9440 Old 09-05-2013, 02:18 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
Thunder storm turned the power off for about 5 seconds. Storm went away, so that evening I fired up my projector and the darbee was acting funny.....I thought it was toast. The next day I unplugged the darbee for a few minutes and 'wallaa', it was back! It didn't even reset itself (to my surprise), and the darbee is (knocking on wood) working flawlessly for now...... cool.gif
migraine24-7 likes this.
KBMAN is offline
post #6777 of 9440 Old 09-05-2013, 07:03 PM
muffinmcfluffin's Avatar
Quoted: 223 Post(s)
Liked: 130
Originally Posted by migraine24-7 View Post
Hello fellas,
If it helps, I've had it last in the chain in the past, but then I wanted to start capturing footage with it with my HD-PVR, so I've put it before that as well. There's no visual difference and there are no handshake issues when it's earlier, so you should be fine with whatever you're doing. It does not need to be last in the chain.
Living Room: Samsung PN60F8500 PDP / Anthem MRX 720 / Klipsch RC-62 II / Klipsch RF-82 II (x2) / SVS PC13-Ultra / Sony MDR-7506 Professional / Sony PS3 / DirecTV HR44-500 / DarbeeVision DVP-5000 Darblet / Panamax M5400-PM / miniDSP UMIK‑1 USB
Bedroom: Samsung PN59D7000 PDP / Energy Power Bar Elite Soundbar & SW / Astro A50 / Sony PS4 / DirecTV C41W-500 / DarbeeVision DVP-5000 Darblet / Hauppauge HD PVR 2
Classroom: SMART Board X800 / Yamaha RX-V667 / Insignia NS-B2111 (x2) / SVS SB-2000
muffinmcfluffin is offline
post #6778 of 9440 Old 09-05-2013, 07:08 PM
Quoted: 223 Post(s)
Liked: 130
When you get it and finally get it running (sometimes it takes a few times figuring out how it wants to turn on in sync with your TV), it's going to default at Full Pop 100%.
The first things you'll want to do are:
1) Change from Full Pop to HD (or Gaming, but most use/prefer HD).
2) Lower the Darbee effect (start at 50%, then play with it a whole lot... you'll see yourself A/B'ing all the time haha it's really addicting).
3) Go to the Menu and Settings, and probably dim the LED lights on the Darblet as well as take off the Darbee effect display (if you don't, it's going to show how much Darbee you're giving it all the time, and you'll want to take that off).
post #6779 of 9440 Old 09-05-2013, 08:27 PM
subavision212's Avatar
Quoted: 62 Post(s)
Liked: 38
Just in case you can't get rid of those darn HDMI handshake issues in your setups:
http://www.widescreenreview.com/news_detail.php?id=19959
subavision212 is offline
post #6780 of 9440 Old 09-05-2013, 10:40 PM
Apgood's Avatar
Quoted: 77 Post(s)
Liked: 44
As I have posted before http://www.avsforum.com/t/1399154/darbee-vision-darblet/6600_100#post_23580238, plugging Darblet into "green" surge protectors does not work because the Darblet's several second boot time will interfere with TV / source HDMI handshaking.
I have mine plugged into a slave plug in my powerboard with av receiver as the master and it works just fine. Mind you the avr does take a few seconds to boot up....
Apgood is offline
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
