Darbee vision darblet - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 284Likes
post #721 of 9650 Old 06-20-2012, 05:10 PM
millerwill's Avatar
Quoted: 484 Post(s)
Liked: 278
I have a 3' HDMI cable from a Radiance to the Darblet (and a 25' HDMI from it to the projector).    No problems.
millerwill is offline
post #722 of 9650 Old 06-20-2012, 11:34 PM
Hello, World!
Mark_H's Avatar
Quoted: 297 Post(s)
Liked: 205
Yup, cable length really isn't an issue here - it's the fact that the Darblet outputs the wrong colourspace/EDID combination.
My cinema: The Cave!
My kit: 15' 2.35:1 Screen Research CP2 4-way mask, JVC Z1, Lumagen Pro, Meridian 861/621/7x5500/2xSW5500
Mark_H is offline
post #723 of 9650 Old 06-21-2012, 06:19 AM
nickbuol's Avatar
Quoted: 644 Post(s)
Liked: 676
So if the Darblet is RGB only, wouldn't we be losing out, potentially, on some of the signal values vs. YCrCb (4:4:4 or 4:2:2)?
The following is taken from:
Color Conversion
Digital coding in the form of YCrCb signals can represent a substantially greater gamut of signal values than can be supported by the corresponding ranges of RGB signals. Therefore, it is possible to produce YCrCb signals which would result in out-of-range values when converted to RGB. To prevent overflowing conditions, clipping is applied to the YCrCb signals before performing the RGB conversion. Clipping can be applied in a way that maintains the luminance and hue values and minimize the subjective impairment by sacrificing only saturation.
To me, sort of like going from an LP to CD, or a CD to MP3. Maybe not overly noticeable without an A/B comparison, but still forcing some data loss (compression in the essence of MP3 where they chop the really high and really low signal).
Or does it really not matter as long as all of the equipment "in line" from source to display are set to the same input/output mode?
Maybe I am way off on this, and I am not griping. I just am wondering.
nickbuol is offline
post #724 of 9650 Old 06-21-2012, 07:31 AM
Hello, World!
Mark_H's Avatar
Quoted: 297 Post(s)
Liked: 205
YCbCr is what we want...
Mark_H is offline
post #725 of 9650 Old 06-21-2012, 08:00 AM
fishinbob's Avatar
With plasma displays it should be better with RGB afaik. That is what I'm currently using for my KURO so there will be no issue here.
fishinbob is offline
post #726 of 9650 Old 06-21-2012, 08:04 AM
Hello, World!
Mark_H's Avatar
Quoted: 297 Post(s)
Liked: 205
Yes, depends on the hardware, but YCbCr is the native format, has higher bitrate and is preferred overall.
Mark_H is offline
post #727 of 9650 Old 06-21-2012, 08:28 AM
NABCS's Avatar
Hello,
I am thinking to buy the Darbee Darblet.
I am from Portugal and I have to buy a power supply 220V DC5V 1000mA.
But I am thinking to use a high quality linear power supply from TeddyPardo.
They have one for Logitech Sqeezebox Touch and the spec are:
Mains Supply: 110-120V or 220-240V
Power output: 5V 3A
Do you think I can use it on the Darbee Darblet ?
Thank you for your help,
Nuno
NABCS is offline
post #728 of 9650 Old 06-21-2012, 08:40 AM
dholmes54's Avatar
Quoted: 482 Post(s)
Liked: 140
I just received my Darbee & was wondering which way it should be pointed at me for the remote to work,the side with the buttons or the other side? Also why is people having trouble with the power supply? thanks
dholmes54 is offline
post #729 of 9650 Old 06-21-2012, 09:47 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
For the Pioneer RGB is the best but The newer plasmas from Panasonic/Samsung are native YcBcR422.. Just like the Lum Radiance & DVDO VP perform there internal processing in the 422 colorspace,
So As MarK-H has said YCBCR is in most cases the prefered colorspace given the current gen Displays,
But even so I think its safe to say The Darblet's Plus's still out way the current colorspace issue but will only get better..
cinema mad is offline
post #730 of 9650 Old 06-21-2012, 09:54 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Originally Posted by NABCS View Post
Hello,
Power output: 5V 3A
Nuno
Hi Nuno the power supply shiped with the Darblet is 110-240Vac so why not just get an adaptor to change the plug type from usa to Portugals type it would be cheaper, Like the world wide travel charger adapter plug..
post #731 of 9650 Old 06-21-2012, 10:27 AM
BFI6603's Avatar
Problems with power supplies are like anything else....sometimes you get a bad one. Forum members have not indicated that this is a specific issue with the Darbee. Mine appears to be fine....I would't sweat it.
To answer your remote question...just point it directly at the leds at the front of the Darbee. Pete
BFI6603 is offline
post #732 of 9650 Old 06-21-2012, 11:04 AM
TDiMura's Avatar
I have no problems with 4-4-4 output my tv is getting 4-4-4 color space without a doubt I do not know why everyone has trouble with this
TDiMura is offline
post #733 of 9650 Old 06-21-2012, 11:05 AM
wmassie's Avatar
don't know either but I am
wmassie is offline
post #734 of 9650 Old 06-21-2012, 11:07 AM
dholmes54's Avatar
Quoted: 482 Post(s)
Liked: 140
Thanks Pete!
post #735 of 9650 Old 06-21-2012, 12:32 PM
DarbeeDr's Avatar
Hello,
Power output: 5V 3A
Nuno
The power supply is rated 110-260V, use a plug adapter and you should be fine.
-DD
DarbeeDr is offline
post #736 of 9650 Old 06-21-2012, 12:34 PM
DarbeeDr's Avatar
The IR receiver is on the side that the buttons are on.
-DD
DarbeeDr is offline
post #737 of 9650 Old 06-21-2012, 07:53 PM
william06's Avatar
Quoted: 168 Post(s)
Liked: 84
I just received my darblet today. I set it up using a 4ft cable in a 35ft to my jvc hd350 p;j. Watched a show on comcast all worked well. I switche the imput to my sonybd player to rent a movie onvudu. it was a disaster. handshake issues speckles etc. I unplugged and reset everything still no go. took out the darblet all was well. Its a shame any suggestions befor I decide to return it. I liked the effect on cable and was anxious to see what happens with a movie. Any suggestions would be appreciatedl I am running everything through a onkyo txnr 3009. the pj output is hdmi 2 to hdmi 2 on the projector. setting on the onkyo is through. Also the pj is showing 8bit not 12 which it normally does. I have no other processor like a luma inthe chain or a dvdo. thanks,
william06 is online now
post #738 of 9650 Old 06-21-2012, 08:04 PM
millerwill's Avatar
Quoted: 484 Post(s)
Liked: 278
Others will know more than I, but it sounds like it might be a 'color space' issue.    You might want to set the BD player to output RGB.
post #739 of 9650 Old 06-21-2012, 08:08 PM
ajglass's Avatar
What settings are you using?
Sent from my iPad
- Andy
ajglass is offline
post #740 of 9650 Old 06-21-2012, 08:14 PM
william06's Avatar
Quoted: 168 Post(s)
Liked: 84
I do not have the bd set at rgb will give it a try tommorow. My pj is set on auto. I will have to re check all in the morning. I am sure it has to be in the settings as the comcast picture was great. I will re check and reset it all tommorow and report back . Thanks I appreciat the suggestions. Just as a footnote what worked well a great little item.
post #741 of 9650 Old 06-21-2012, 08:28 PM
henrich3's Avatar
Quoted: 576 Post(s)
Liked: 497
William - Try swapping out the 4' HDMI cable for a high speed rated cable at least 6' long.
henrich3 is offline
post #742 of 9650 Old 06-22-2012, 07:21 AM
william06's Avatar
Quoted: 168 Post(s)
Liked: 84
Well guys all is well I got it working. I first switched the cable and set it to rgb it was set at 4.4.4 no good still bad. Than I tried setting the sony to 4,2,2, and all is well still shows up on the pj as 8 bit not its lususal 12 bit but pic is fine and a real noticable on the darblet. runnig now at hi drf 85% did try full pop 100% on some baseball I really like it. amazing how much depth it adds.
Thanks for the help.
post #743 of 9650 Old 06-22-2012, 08:05 AM
william06's Avatar
Quoted: 168 Post(s)
Liked: 84
Not sure thoought I would ask why does adding the darblet or even a splitter drob the bits from 12 to 8 is it because of setting the sony on 4.2.2. ?
post #744 of 9650 Old 06-22-2012, 09:09 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Well I know The Darblets native internal processing is YcBcR 4.4.4 10 bit according to the Specs, RGB is only 8 bit so it may have something to do with the 10 Bit limitation or the RGB color space bug (EDID) as to why its not uping to 12 bit on its output..
post #745 of 9650 Old 06-22-2012, 09:39 AM
cinema mad's Avatar
Quoted: 18 Post(s)
Liked: 38
Just wanted to Pass on my appreciation to the AVS folks & especially Mike Garret for Your responsive/ excellent customer service & Shipping A Darblet DownUnder.. It Was extremely well Boxed so thanks for that Jason R..
Thanks Mike!!...
PS: Even the Mrs likes the Darblet wink.gif
post #746 of 9650 Old 06-22-2012, 10:35 AM
michael knights's Avatar
-DD
Sorry. I'm living in Spain and voltage European is (220v 50 Hz) and United States (110v 60 Hz). Does it work the Darbee in Europe?
It seems a very interesting and several friends of Spain would like to buy it.
michael knights is offline
post #747 of 9650 Old 06-22-2012, 12:10 PM
dholmes54's Avatar
Quoted: 482 Post(s)
Liked: 140
How do you set the blu-ray players output to 444 or 442? I have a older Pioneer 51 blu-ray & for sound you have hdmi ,pcm,also I can set it at 24 fsp or 60i which mine is set at 24 fps.Havnt conn. my Darbee yet but am I going to have a problem with a older player? thanks
post #748 of 9650 Old 06-22-2012, 12:20 PM
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
The Setup Instructions on the Darbee website say to connect the "source" component directly to the Darblet and then the Darblet to the display device. I have multiple sources and I run them all through my Integra 80.2 pre/pro. I assume I can I put the Darbee in the video chain *after* the pre/pro, so it processes all the sources after they leave the pre/pro. That should not cause any "handshake" issues, correct?
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #749 of 9650 Old 06-22-2012, 12:56 PM
millerwill's Avatar
Quoted: 484 Post(s)
Liked: 278
Craig
Yes.   And mine is even after a Radiance that my AVR (Onk 3008) goes into   (BD and Comcast DVR => Onk 3008 => RadianceMini => Darblet => Sony1000).
post #750 of 9650 Old 06-22-2012, 01:28 PM
william06's Avatar
Quoted: 168 Post(s)
Liked: 84
I just found out the rgb setting is also a bit wacky on the sony 790 this probably had some cause as to why I had to use the 4.2.2. there is eventually a firmware comming to fix that.
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
