Darbee vision darblet - Page 253 - AVS Forum | Home Theater Discussions And Reviews
 303Likes
post #7561 of 9707 Old 01-13-2014, 06:07 PM
hometheatergeek's Avatar
Quoted: 41 Post(s)
Liked: 44
Originally Posted by EndersShadow View Post
Does anyone know if the Darblet can be controlled via a Logitech Harmony One? I only ask because that the main remote in my system and it would be AWESOME if I wanted to use diff settings per input to be able to control that as I switch them (for instance say Xbox @ 75%, Bluray player at 45% and Uverse at 75%).
Yes I have my Harmony One setup to operate the Darbee. Here are the steps. In the software on your computer for the Harmony....
Add new device...under amplifier....audio/video switch....select darbeevision...and type in DVP-5000 for the model. Then you can add any buttons to any activity. On most of my activities I just added More Darbee and Less Darbee. on the touchscreen part of the Harmony One.
Hometheatergeek
aka AL
My Current System
hometheatergeek is online now
post #7562 of 9707 Old 01-13-2014, 07:20 PM
EndersShadow's Avatar
Quoted: 632 Post(s)
Liked: 959
Thanks, thats EXACTLY what I was looking to know. Their software (while awesome) can be a PITA to figure out how they categorize or name components lol...
I think I will probably do what you are doing if I end up snagging one (still on the fence).
My Setup | FS: Salamander Synergy 303, Outlaw LFM-1 sub, Sanus UF22 Speaker Stands, Nintendo Wii, 5 channel Polk LSi system (all threads here)
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
post #7563 of 9707 Old 01-14-2014, 06:11 AM
tjgar's Avatar
I purchased the 5000 17 months ago. Loved it, rewatched all my fav movies ect. then after a few months i had an issue with it not giving me any video output. someone told me to unplug and retry----Success. Then it started happening a little more often, and I had to unplug power and HDMI, but it worked.
I should have known that this should not be necessary to do but I did not want to send it back and wait for repair ( I would miss it too much?) or I was too lazy. Then It happened again when I wanted to watch a stanley cup game on TV and it would not reset. I left it out of the chain to watch the game and give it more time. I recently tried it again but no luck. Dumb-Dumb=Dumb. No it is out of warrantee-Dumb
Moral of this story= you can use bandaids as long as you have warrantee left, but if it is not healng, send it back while you can. as a matter of fact don't use the band aid more than ounce!!!
The dumb Guy
Tony:eek:
tjgar is offline
post #7564 of 9707 Old 01-14-2014, 09:45 AM
STEVE MORRILL's Avatar
I have an OPPO 103 plugged into a Sony HX850 LED. I am told that by setting the sharpness in the OPPO at +1 you will get the same effect as a Darbee. At +1 it does give the picture more depth.
STEVE MORRILL is offline
post #7565 of 9707 Old 01-14-2014, 09:47 AM
David Susilo's Avatar
Quoted: 637 Post(s)
Liked: 593
Absolutely not. It's a different approach. Sharpness is adding distortion on the edges of the object. Darbee is de-blurring the image (not adding "stuff" to the image)
barrelbelly likes this.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #7566 of 9707 Old 01-15-2014, 12:15 PM
CheYC's Avatar
Quoted: 58 Post(s)
Liked: 61
Well, it's on Solid Signal for $224 and I finally bit the bullet. I'm pumped to get it and try it. I've read a ton in this thread, and just to be sure, it is best putting it closest to the projector correct? i.e. 30' Redmere cable out of receiver and into darblet, and 6' cable from darblet to projector?
Basement: BenQ W1070 on 110" Elite Screen, Denon AVR-1913, JBL LC1 (C), JBL L880 (FL/FR), JBL 810 (BR/BL), Rhythmik LV12R Sub, PS3 and Roku 3
Living Room: Vizio M65-E0, Vizio SB3651-e6 Soundbar, PS4, Roku Premier+, and X Box One X coming soon
CheYC is offline
post #7567 of 9707 Old 01-15-2014, 12:48 PM
Randomcreek's Avatar
No , the Darbee Dr guy says to give it best chance to work it goes closer to the source. Remember that short 18" cables however may be too close because of HDMI handshake issues. I wish you woudl have posted htis 2 dayus ago. I just paid $40 more 35 more on Amazon. Mine was free shipping. Did you have to pay for shipping?
Randomcreek is offline
post #7568 of 9707 Old 01-15-2014, 12:57 PM
CheYC's Avatar
Quoted: 58 Post(s)
Liked: 61
I paid $8.49 for two day shipping. The deal is just today AFIAK. So wait, you're saying the darblet should actually go closer to the receiver?
CheYC is offline
post #7569 of 9707 Old 01-15-2014, 01:15 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7737 Post(s)
Liked: 4332
It should not make any difference.
AustinJerry is offline
post #7570 of 9707 Old 01-15-2014, 01:22 PM
Question for Darbee Dr.- Is it generally better to 1) Darbeeize the native signal (480i, 720P, 1080i or 1080P) first and then let my display scale to the screen resolution (1080P) OR 2) since I am running all my sources through a receiver that can upconvert everything to 1080P, upconvert everything to 1080P, then darbeeize the 1080P signal whcih would be passed to the TV where it woudl not have to be scaled to the display resolution (1080P)?
Also, the TV has scanning choices of overscan or native. Which option is better?
post #7571 of 9707 Old 01-15-2014, 01:26 PM
Well if you go back to one of the early posts by DarbeeDr. that's what he wrote. I had to read it twice because I would have thought intuitively that it was the other way around or like you say it shouldn't matter, but sometimes these things are counter intuitive. I don't know the answer from first hand experience. Others here may. Or maybe it was a mistake or I interpreted what he said wrong.
post #7572 of 9707 Old 01-15-2014, 01:31 PM
here is the question and post by Dr. Darbee:
Originally Posted by flint350 View Post
I ordered one last week, before they switched to distributors. I got a Fedex email notification today (Saturday) that it was being shipped from California, so I guess the 6 week delay is over for now.
One question I have is about installation position in the video chain. I have a long hidden ceiling run of 50' of high quality HDMI 1.4a cable from the equipment room AVR to the projector. Any guesses on whether it would be best to connect the Darbee at the AVR via a short cable and then to the long 50' cable to the projector - vs - connect right at the projector at the end of the 50' cable and then a short connect directly to the projector? In other words, closer to the source or closer to the projector (based on the effect of the long cable).
The Darblet appreciates the best signal and will not degrade the signal. So put it at the end closest to the source to give it the best chance of doing the most good. We have tested with long "active" cables that have built in signal processing for maintaining quality, and we are perfectly compatible.
-DD
I guess I paid about $25 too much two days ago. Ouch- I thought I found the best deal
post #7573 of 9707 Old 01-15-2014, 04:30 PM
humbland's Avatar
Quoted: 459 Post(s)
Liked: 96
My $.02.
The Darbee/HDMI cable length interaction thing is not "one size fits all". We tried several ways and found that the most stable set up was with the short (6 ft.) HDMI cable going from the Darbee to the projector. The reasoning is that the Darbee does not have the "boost" to drive the long (50 ft.) inwall run from the AVR to the Projector. I could not get that one to work well... YRMV.
Enjoy your new toy.
CheYC likes this.
humbland is offline
post #7574 of 9707 Old 01-16-2014, 09:09 AM
CheYC's Avatar
Quoted: 58 Post(s)
Liked: 61
Originally Posted by humbland View Post
My $.02.
Enjoy your new toy.
This is what I thought I had remembered reading at some point in this post. I'll likely try this first and see how it works out. Thanks guys.
CheYC is offline
post #7575 of 9707 Old 01-17-2014, 06:09 PM
Skrill's Avatar
Quoted: 255 Post(s)
Liked: 76
My $.02.
Enjoy your new toy.
What about Darblet + a long MonoPrice Redmere cable? The two should compatible ... right?
Skrill is offline
post #7576 of 9707 Old 01-17-2014, 06:46 PM
Steven414's Avatar
Quoted: 71 Post(s)
Liked: 31
I'm running 6' HDMI out to darbee from AVR, and 35 foot redmere to projector. No issues, works great!
Steven J
Steven414 is offline
post #7577 of 9707 Old 01-18-2014, 07:44 AM
humbland's Avatar
Quoted: 459 Post(s)
Liked: 96
The bottom line is "that one size does not fit all".
Try it and see...
This thread has many posts of people fooling around with different configurations to try and get the Darbee to work reliably. smile.gif
It's a testement to how good the final effect is that people put up with the quirks of the device.
In fairness to the Darbee, HDMI issues have been with us for awhile now. eek.gif
The darbee is just a +1 on a long standing problem.
humbland is offline
post #7578 of 9707 Old 01-18-2014, 08:26 AM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
Try it and see...
For example, I have had no trouble ever with Pioneer BPD-51 -> HDMI switch -> Lumagen -> Darbee -> JVC RS20.
erkq is offline
post #7579 of 9707 Old 01-18-2014, 10:05 AM
Quoted: 637 Post(s)
Liked: 593
In all fairness, after installing (so far) 80+ Darblets, I have yet to encounter a single HDMI handshake issue with the Darblets.
I use long cables to Darbee and 1ft HDMI from Darbee to display.
my home theatre
post #7580 of 9707 Old 01-18-2014, 12:05 PM
CheYC's Avatar
Quoted: 58 Post(s)
Liked: 61
Just got it and hooked it up, 6 ft HDMI from receiver out to darbee, then 30 foot redmere from darbee to projector, seems to work just fine, and I like it better in my equipment closet rather than sitting on top of my projector. This thing really does make a pretty dramatic difference imo just at first glance. I was even surprised that it seems to slightly improve contrast as well. I haven't seen too many praise full pop mode here, I know most like HD at about 55% or so, but I was really liking full pop at 55%. Anyway, I'm going to mess around with it some more tonight when I have more time.
CheYC is offline
post #7581 of 9707 Old 01-20-2014, 11:01 AM
We are a little late to the party CheYC, but mine should be here tomorrow. My excuse is I had to get divorced. What's your's? smile.gif I will be running on a new 60" LG plasma that I have tweaked to the nth degree over the last 3 weeks to get a really great picture that already is color saturated and pops nicely. I've used the picture wizard (how sweet is that blue screen mode?) and my critical eye to squeeze every last drop of quality out of it (for my room and liking). It will be interesting to see if darbeeizing it will add anything or not (i.e. The Acid Test). We'll see.
post #7582 of 9707 Old 01-20-2014, 05:19 PM
milacqua's Avatar
Quoted: 78 Post(s)
Liked: 27
I have several smaller tvs and the Darbee does help - some. However, not enough to justify its cost. If you have a projector shooting on a large screen (mine is an Epson 1080P shooting on a 106" Carada screen), then yes, you will notice a difference that justifies a $300 expenditure. I would not buy a Darbee for a tv.
shortspark
milacqua is offline
post #7583 of 9707 Old 01-20-2014, 05:49 PM
UHD Addict
aaronwt's Avatar
Quoted: 6417 Post(s)
Liked: 3966
I see the difference easily on my 47" set and easily on my 82" set. For only $250 to $300 it is a steal. I remember paying many times that for each of many devices over the last twelve years that didn't come anywhere close to what the Darbee can do. People are spoiled when they say the darbee is expensive. They should have been around when devices similar to that were really expensive.
The Darbee easily gives the most bang for the buck of the devices I've purchased over the last twelve years or so. My Algolith Flea I bought in 2007 used to be one of my best bang for the buck devices. But that cost over $900. And that was an excellent deal back then. Which is why a say $250 to $300 in 2014 is easily a great bargain for the Darblet.
GGG and migraine24-7 like this.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #7584 of 9707 Old 01-21-2014, 05:32 AM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
^ +1
dsinger is offline
post #7585 of 9707 Old 01-21-2014, 05:35 AM
CheYC's Avatar
Quoted: 58 Post(s)
Liked: 61
I watched Toy Story 3 on full pop 55% the other night, holy smokes...
CheYC is offline
post #7586 of 9707 Old 01-21-2014, 06:38 AM
praz's Avatar
Liked: 26
I purchased mine on Feb 1, 2012 and received it a couple of months later. First used it with a 55" display then moved to a 70". I don't think there has been a single person that after watching for a bit and then turning the Darblet off hasn't commented that the picture looks blurry or out of focus with it disabled.
praz is offline
post #7587 of 9707 Old 01-21-2014, 08:02 AM
Skrill's Avatar
Quoted: 255 Post(s)
Liked: 76
Well -- I have decided I want a DVP-5000 (judging by the post further up -- apparently 6 days too late). Any idea when they will go back on special in the $225 - $230 range?
EDIT: Never mind -- the Solid Signal deal appears to be live. Just ordered. Looking forward to receiving.
Skrill is offline
post #7588 of 9707 Old 01-21-2014, 08:14 AM
kwok lau's Avatar
Quoted: 257 Post(s)
Liked: 77
I fully agree!. It is easier to notice the enhancement on big screen. The bigger the better.
New buyer should also not have "night and day" improvement with the device.
I have a 120" diagonal Carada Screen (1.3 gain) with Panasonic PTU-2000 Projector. I start noticing the minor difference when set the device at 55% HD and it gradually increase enhancement till 75% HD setting. I do not see further enhancement after 75% HD setting. Enhancement can be seen more easily on still picture, but not video. I keep the device just because it help a little and I paid $249, not $349.
kwok lau is offline
post #7589 of 9707 Old 01-21-2014, 10:44 AM
Josh Z's Avatar
Quoted: 2476 Post(s)
Liked: 1628
The reason most people stick with "Hi-Def" mode is that both "Game" and "Full Pop" will crush shadow detail in the image.
Josh Z
Writer/Editor, High-Def Digest (Blog updated daily!)
Curator, Laserdisc Forever
My opinions are my own, and do not necessarily reflect those of my employers.
Josh Z is offline
post #7590 of 9707 Old 01-22-2014, 11:46 AM
CheYC's Avatar
Quoted: 58 Post(s)
Liked: 61
Ah OK, makes sense; I definitely seen this when comparing all modes on a paused "dark" scene. I almost don't mind too much because it seems to locally improve contrast (if that makes sense), I have a BenQ 1070 and contrast is its main weak point imo, so this seems to help a little even though I am losing some shadow detail. I also do notice some artifacts in full pop that I don't see in Hi Def or even gaming mode, though they aren't bad enough to be detrimental imo.
CheYC is offline
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
