Darbee vision darblet - Page 259 - AVS Forum | Home Theater Discussions And Reviews
 247Likes
post #7741 of 9459 Old 02-25-2014, 04:11 PM
VBB
VBB's Avatar
Quoted: 1011 Post(s)
Liked: 862
In the short time that I've had the Darblet, I've noticed a few things when using it with the AVS HD 709 test patterns:
1. In the Black Clipping pattern, setting the Darblet any higher than 35% will create vertical lines in at least the lowest visible bar (17).
2. In the Sharpness & Overscan pattern, setting the Darblet to Game or Full Pop will create artifacts. We already knew about this one...
3. In the Grayscale Ramp pattern, sending a 10-bit or 12-bit signal to the Darblet will result in some form of banding, even with the Darblet at 0%.
I realize this might be unique to my setup, but I'm curious if others are seeing similar things.
VBB is offline
post #7742 of 9459 Old 02-25-2014, 05:53 PM
erkq's Avatar
Quoted: 622 Post(s)
Liked: 442
Originally Posted by dsinger View Post
The original release firmware had a bug in that it output RGB color space no matter what the color space input (e.g. 422, 444). It was supposed to output the same color space as input after processing. If your display has no problems with RGB then there is no reason to go thru the hassle of getting it updated.
Yeah... I think there hasn't been a fw upgrade since August of last year.
erkq is online now
post #7743 of 9459 Old 02-25-2014, 06:33 PM
njfoses's Avatar
Quoted: 76 Post(s)
Liked: 63
Originally Posted by VBB View Post
I just emailed them as well. Will let you know if and when they respond. Which number did you try? The 657 or the 714 area code?
I tried the 657 area code, no luck.
I recently bought my unit off ebay. It has the most recent fw of 1.3.21 but it has an older sw version of 2.6.2137 that i cant find any info about. My unit does not have the advanced settings menu for 1% increments.
njfoses is online now
post #7744 of 9459 Old 02-26-2014, 06:31 AM
dsinger's Avatar
Quoted: 316 Post(s)
Liked: 320
Using both the S&M 1 and 2 releases I have not seen any of those problems with the Darbee in HD mode at 50%. None of the professional reviews to my knowledge have identified those kind of problems.
dsinger is offline
post #7745 of 9459 Old 02-26-2014, 08:26 AM
Mr.G's Avatar
Quoted: 608 Post(s)
Liked: 315
You're right, I think it is unique to your setup. I use the AVS HD 709 test patterns every 500 hours to check the light output on my projector. I've never seen any lines or artifacts at HD 40%.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #7746 of 9459 Old 02-26-2014, 03:03 PM
VBB
VBB's Avatar
Liked: 862
Thanks for the replies, guys. My issues with the patterns are most likely related to the xvYCC color space mismatch I wrote about on the previous page. Seems to be unique to Realtek-based media players. I emailed Darbee support but haven't gotten a response yet.
VBB is offline
post #7747 of 9459 Old 02-27-2014, 02:34 PM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
Originally Posted by R Harkness View Post
giomania,
I've only experimented briefly with the Lumagen picture enhancements, and only with the adaptive contrast. It "works" but I'm not yet sure about my opinion on it and whether I"ll use it at all. With this new projector I've already got a lot of new picture settings to juggle and evaluate, so I've yet to get a handle on the Lumagen picture controls. I'll certainly report back (in the Lumagen thread) when I have more time to do so.
The adaptive contrast function in the Lumagen is only there because it is included in the Genum processing chip they are using for some of the functions. I like it when watching hockey or basketball set to 1 because it seems to make the ice look brighter and the basketball court cleaner. makes it look more like what I see when I go to an actual game.
mark haflich is offline
post #7748 of 9459 Old 02-27-2014, 04:08 PM
VBB
VBB's Avatar
Liked: 862
Good news directly from the source:
A new firmware update will most likely be ready within a month. The only fix I know of at this time is the disabling of xvYCC support in the Darblet, which will force devices that output that color space to output YCC only.
VBB is offline
post #7749 of 9459 Old 02-27-2014, 05:26 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6686 Post(s)
Liked: 3686
OK, translate that into layman's terms.  Does that fix a problem that I might not be experiencing, or is it an enhancement to performance that is a "must-have"?  Keep in mind that to get a firmware update, you need to return the device to Darbee, and there would likely be a fee involved as well as shipping charges.
AustinJerry is online now
post #7750 of 9459 Old 02-27-2014, 05:37 PM
VBB
VBB's Avatar
Liked: 862
It fixes, or rather works around a problem that someone with xvYCC in their video chain would experience. You would see extremely elevated black levels (brightness) and everything would look washed out.
Now, again, that is the only fix I was told of, because it relates directly to an issue I have with the Darblet. That does not necessarily mean it will be the only fix or change in the firmware. We will all have to wait and see what's going to be announced. I just wanted to give people a heads up that there will actually be a new firmware after almost two years wink.gif
VBB is offline
post #7751 of 9459 Old 02-27-2014, 06:00 PM
Liked: 3686
Thanks for clarifying. I am not experiencing those issue. I hope the fix resolves your issues.
post #7752 of 9459 Old 02-27-2014, 06:38 PM
flinchn's Avatar
Quoted: 138 Post(s)
Liked: 202
I realize things may have changed since the writing of this article but what component do you have in your chain that outputs xvYCC? PC graphics card? Just curious.
http://www.audioholics.com/home-theater-calibration/hdmi-black-levels-xvycc-rgb
flinchn is offline
post #7753 of 9459 Old 02-27-2014, 06:54 PM
VBB
VBB's Avatar
Liked: 862
It's a Realtek RTD1186-based Mede8er MED600X3D media player. Unfortunately, there is no option to toggle xvYCC on or off in the Mede8er or the TV. Without the Darblet, everything works fine and levels are exactly where they're supposed to be. With the Darblet, though, there's a huge shift. I guess the Darbee guys already knew about this before I even contacted them, because they told me about the fix being in their soon to be released firmware update.
VBB is offline
post #7754 of 9459 Old 02-28-2014, 10:15 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
Interesting. I have a MED1000X3D, which I believe has the same Realtek RTD1186 chip. Is this something that would be really noticeable, because I have not noticed a huge shift. I do have a Lumagen XS3D between the Darblet and the display, so maybe that makes a difference?
Mark
giomania is offline
post #7755 of 9459 Old 02-28-2014, 10:48 AM
VBB
VBB's Avatar
Liked: 862
Mark
You would only notice it if your display also supports and accepts an xvYCC signal. It's also possible that the Lumagen doesn't output in xvYCC and converts the Mede8er signal to YCC. In my setup, there's currently no way to turn xvYCC off. The Mede8er sees xvYCC as its best output option and will always send that out if the next EDID device in the chain supports it. That's the Darblet, in my case. With the new firmware, the Darblet's EDID will tell the Mede8er that it only accepts YCC. Problem solved, hopefully.
VBB is offline
post #7756 of 9459 Old 02-28-2014, 11:18 AM
VBB
VBB's Avatar
Liked: 862
Your JVC projector also is way more sophisticated than my Sharp TV. Even though yours doesn't seem to support xvYCC, it has options for input signal and color space.
VBB is offline
post #7757 of 9459 Old 02-28-2014, 12:18 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 14 Post(s)
Liked: 35
Thanks for the explanation. I usually turn off deep color, if possible, in the settings of any given device. So I think this is the second time that Darbee Vision has had to update the firmware to correct for HDMI-related issues with other equipment. My system was affected by the first firmware anomaly, but glad to see this time I am not.
Mark
giomania is offline
post #7758 of 9459 Old 02-28-2014, 12:45 PM
gadgtfreek's Avatar
Quoted: 632 Post(s)
Liked: 3108
Just wanted to pop in.
Using the 103D Oppo for awhile but just started tinkering with Darbee. So far I find that Hi-Def and 40% on my VT50 offers some "sharpness" to parts of the image, but I havent been able to find any negatives, yet.
Using it for Blu-ray, OTA and Directv.
65E6P / UBP-X800
AV7702II / Outlaw 7125
RF7II's / RC64II / Dual FV15HP's
gadgtfreek is offline
post #7759 of 9459 Old 02-28-2014, 03:19 PM
VBB
VBB's Avatar
Liked: 862
Mark
There could of course be other fixes and improvements in this new firmware that everyone would benefit from. We just don't know that yet biggrin.gif
Don't confuse xvYCC with Deep Color, though. They are two different things. Deep Color is and has always been supported and working with the Darblet. It simply increases the bit depth of the color gamut from 8-bit to either 10-bit or 12-bit. There should be no visible difference in actual content, simply because nothing commercially available supports it at this time. It might eliminate some banding, though, so it doesn't hurt to turn it on.
xvYCC, on the other hand, extends the existing YCbCr color space. In theory, this is all good, but until recently, there hasn't been any content encoded in xvYCC either.
I would prefer Darbee fix the issue rather than turn xvYCC off completely, but I'll take the workaround over the level issue any day smile.gif
VBB is offline
post #7760 of 9459 Old 03-02-2014, 12:52 PM
bekindrewind's Avatar
Quoted: 132 Post(s)
Liked: 58
Originally Posted by mattg3 View Post
Thanks.Im about to set up a new Yamaha 673 with oppo and darbee and a Roku.Ill try the first way that gave you issues in order to get my roku into the darbee mix but if it causes issues Ill go with your other way and forget about the Roku using Darbee processing.This is my first time running HDMI through a receiver since I always felt direct connection between oppo and screen was way to go but I missed out on the blue ray sound bump up.Even with direct connection from oppo to Darbee to screen I sometimes would get a brief pink screen when I ejected a dvd but only for a second.
Some AVR have a pass thru. If your Yamaha does, then it will not affect the Oppo's pq.
Depending on which Oppo you have, it may have two hdmi outs. If yours does, like the 103 I have, then you can run one hmdi to your monitor for picture and the other hdmi out of the Oppo to your Yamaha for digital sound.
PRO-70X5FD, McIntosh MC205, Marrantz MM8077, Marantz AV7702MKII (7.1.4), Oppo UDP-203, Oppo BDP-93, JL Audio f113, B&W Nautilus, Richard Gray 400S, Harmony One
bekindrewind is offline
post #7761 of 9459 Old 03-02-2014, 01:38 PM
mattg3's Avatar
Quoted: 266 Post(s)
Liked: 169
Im using oppo 83 but everything is going great.Using 10 ft HDMI cables into and out of yamaha through the darbee and no sign of a pink screen.
Matt
mattg3 is offline
post #7762 of 9459 Old 03-02-2014, 01:57 PM
ingersol1211's Avatar
I also get a pink screen when I turn on my oppo 103 and my denon 4520 switches to the bd input,I have the
Pass through set on the avr and 1080p forced on the oppo, I not sure if the darblet has anything to do with it.sometimes it will flash pink several times before things seem to lock in.
ingersol1211 is offline
post #7763 of 9459 Old 03-06-2014, 10:57 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 2052 Post(s)
Liked: 2216
Originally Posted by bigjoexxl View Post
What about the new model coming out. The Darbee DVP-5100... Wouldn't it be better off to go with the newer model?
Will be the same device in a fancy rack mounted case.
Originally Posted by njfoses View Post
I am joining the darbee club. Just picked up a new unit on Ebay for a great deal!
Cleveland Plasma is offline
post #7764 of 9459 Old 03-10-2014, 02:45 AM
knot_m3's Avatar
I have been using Darbee Darblet DVP-5000 for over a year now and it's been working just fine, until recently when I unplugged it and move it form my home theater room to my bedroom and it just doesn't work anymore.
It seems like no power is going in to the darblet at all. Does anyone have this issue? and how can I fix this?
Panasonic PT-AE8000|Magnum Screen Microfine 4K 110"|XLO HTPro 10m.|Oppo95|XLO HTPro 1m.x2|Darbee Darblet|WireWorld Silver Starlight 6 1m.|Anthem MRX500|KEF LS50 x 6|MIT Magnum S3 bw(FL/FR)|MIT AVT1s(Center)|MIT 14/2(Surround)|SVS SB13-Ultra
knot_m3 is offline
post #7765 of 9459 Old 03-10-2014, 03:31 AM
Apgood's Avatar
Quoted: 77 Post(s)
Liked: 44
First off get a multimeter and check the voltage and amps coming from the power supply to make sure proper power is getting to the darbee.
Apgood is offline
post #7766 of 9459 Old 03-10-2014, 09:39 PM
knot_m3's Avatar
This power supply came in the box with darbee, do I still need to check it?
knot_m3 is offline
post #7767 of 9459 Old 03-10-2014, 09:50 PM
Apgood's Avatar
Quoted: 77 Post(s)
Liked: 44
Yes. It's to check that there is nothing wrong with the power supply. Basically it the power supply is fine, but your Darbee isn't turning on then you know the Darbee has a problem, while if the amps from the power supply are too low or the voltage is incorrect by more than +/- 0.5 volts it might be the power supply and I would get a new power supply to check if that is the problem.
Apgood is offline
post #7768 of 9459 Old 03-15-2014, 11:40 AM
carp's Avatar
Quoted: 2534 Post(s)
Liked: 1809
Will this work for me since I have a 50 foot cable run to my projector? I assume I would put it close to my projector and then have a very short HDMI cord running from the darbee to my projector.
carp is offline
post #7769 of 9459 Old 03-15-2014, 11:57 AM
Type A's Avatar
I wouldnt be surprised if it worked fine. I run my Darblet first to a monoprice amp/splitter and then that goes to a 25' DVI-HDMI cable and a 35' HDMI cable. Zero issues.
JVC DLA-RS60U3D & DaLite High Power 106". Secondary: Panasonic Viera TC-P65ST30.
Paradigm Studio V.5: 20 (5) & ADP-590 (2). Hsu: VTF-2 MK3 (2) & MBM-12 MK2 (2).
Yamaha RX-A3010 & Emotiva XPA-5. Oppo BDP-93 & DarbeeVision DVP 5000.
Type A is offline
post #7770 of 9459 Old 03-15-2014, 11:59 AM
carp's Avatar
Liked: 1809
Cool, thanks Type A.
I didn't get a chance to read much of the thread but did read the reviews on Amazon.
Is the consensus that this makes a pretty obvious difference and is worth the money? Should I wait for this firmware upgrade I read about on recent posts before ordering?
carp is offline
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
