Darbee vision darblet - Page 268 - AVS Forum | Home Theater Discussions And Reviews
 240Likes
post #8011 of 9439 Old 06-18-2014, 12:59 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
Originally Posted by Ben Music View Post
My remote has worked fine for almost 2 years, but I've never seen a bulb light up since day one.
Ben Music
you need to look through a digital camera to see the remote sender light up.
vega509 is offline
post #8012 of 9439 Old 06-18-2014, 01:02 PM
vega509's Avatar
Quoted: 185 Post(s)
Liked: 55
Originally Posted by IMRIZZO View Post
Thx for the quick response, the problem I'm having started as the up function wasn't responding now other functions are failing. I recently (6mos) replaced battery I contacted CS at Darbee they suggested try another battery she explained the sml bulb in remote should light (indicating transmission of signal) I then noticed bulb was not igniting. Mine is set at HD/47 unit works well ....remote sux. I post results of battery repl purchased at Radio Shack ??? will try to locate a duracell or other high quality battery.
mine did that right out of the box. a new battery made no difference. when I took a bright light and looked inside the battery holder I found a film of grease. Cleaning it off with a q-tip and alcohol solved the problem. it couldn't hurt to have a look.
vega509 is offline
post #8013 of 9439 Old 06-18-2014, 04:22 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
Thx for the reply, but mine worked fine for almost 2 yrs, with the exception to resetting it self a few times ( which i attributed to possible power interruptions. But when trying to reset the spec's the function buttons were not functioning I repl'd the battery and it work for a short time but then failed again. I just replaced battery again with no change, so I shall return it to Darbee for a replacement, I'll update post if and when this is resolved. Thx for all the responses.
LG OLED 55B6P~Oppo UDP203~SonyXBR929~Denon 3311~Mirage V2 SPK-SYS w/ S10 SW~ DVP5000~Harmony1100
Optimum via SA8300-HDDVR
IMRIZZO is offline
post #8014 of 9439 Old 06-18-2014, 04:27 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
I noticed that when I use the functional features like on/off and down etc the bulb also never ignites ?? remote being sent back to Darbee for svc/replacement.
Ben Music
IMRIZZO is offline
post #8015 of 9439 Old 06-18-2014, 05:42 PM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
I programmed the remote into my universal remote the day I got it, so I've never really used the remote that came with the Darbee.
fatherom likes this.
gweempose is offline
post #8016 of 9439 Old 06-19-2014, 08:41 AM
mp06011999's Avatar
Quoted: 67 Post(s)
Liked: 53
One of my Darbees always reset itself since new and the one remote never worked ALL THE TIME. However, they have gotten worse. Both problems have become much more frequent to the point of unacceptable. Looks like I will have to re-email Darbee as they have not replied. Both Darbees are less than a year old, just barely.
Fwiw, the very first Darbee I ever ordered was a Cobalt one that acted up right out of the box and was returned. It's remote never even worked. I love the tech behind these things in what they do for the image, but quality is highly suspect. In my particular case, this is a 66% failure rate. Wow!
ingersol1211 likes this.
mp06011999 is offline
post #8017 of 9439 Old 06-19-2014, 08:41 AM
mp06011999's Avatar
Quoted: 67 Post(s)
Liked: 53
Oh yea, I may try programming the remote into a universal one. Good idea.
post #8018 of 9439 Old 06-19-2014, 09:56 AM
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 43
I was also disappointed in the supplied remote but I learned that if you made the effort to press down the buttons directly in the middle of the button they do work reliably. But I did set up my Harmony One with the commands and it works much better.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #8019 of 9439 Old 06-19-2014, 10:53 AM
Paul H's Avatar
Quoted: 33 Post(s)
Liked: 30
Not for me. All 3 of the remotes I have for 3 Darbee 5000s do not work when pressed the first time, if I haven't used them the same day.
They work if I continue to press the button again around 3 times, and then they'll respond with a single press.
If I wait a couple of days, I have to repeat repeated-presses again, like I would do if I was priming an old fashioned pump that would dry out if not used often.
Paul H is offline
post #8020 of 9439 Old 06-19-2014, 11:36 AM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
Just loaded my Harmony 1100 with setting for the Darbee works fine no more need for this POS Darbee remote.
IMRIZZO is offline
post #8021 of 9439 Old 06-20-2014, 09:56 AM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
Considering how much they charge for the Darbee, there is no excuse for them to bundle it with such a crappy remote.
old corps likes this.
post #8022 of 9439 Old 06-20-2014, 10:22 AM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
Am I the only person who doesn't care about the remote? I set it to my favourite setting and leave it there. For about 2 years I never need to use the remote at all!
DIY Guy, Keenan, gulliBELL and 1 others like this.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #8023 of 9439 Old 06-20-2014, 11:53 AM
Steven414's Avatar
Quoted: 54 Post(s)
Liked: 24
I think the problem comes with some Darblets (mine included) that will randomly reset itself for no apparent reason and we have to use the remote to restore our settings. Sucks!
dsinger and mp06011999 like this.
Steven J
Steven414 is offline
post #8024 of 9439 Old 06-20-2014, 06:37 PM
IMRIZZO's Avatar
Quoted: 44 Post(s)
Liked: 125
The Darbee is inexpensive compared to other video processors but still no excuse for such a lame remote.
IMRIZZO is offline
post #8025 of 9439 Old 06-20-2014, 06:50 PM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
edit.....
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
post #8026 of 9439 Old 06-24-2014, 09:03 AM
krips's Avatar
Quoted: 140 Post(s)
Liked: 107
Unhappy
I recently purchased Darbee Vision DVP 5000. The only issue I see is a pink flash whenever I change the input from one device to another. Did anyone get this issue and how you got it fixed.
Fyi... if this is something related to bad unit, I still have ample time to refund it and get a new one from Amazon.
Sony XBR55HX929 / LG OLED55C6P
Denon x4000 / PS3 Slim / BDP-S6200 / OPPO UDP-203
Roku 3 / WD TV Live /Chromecast / Fire TV stick
Speakers - DT PM1000 / PC2000 / Sony HTNT5
Sub - Power Sound Audio S1500
krips is offline
post #8027 of 9439 Old 06-24-2014, 09:54 AM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
It's probably a brief handshake error. A screen that shows video, but the video happens to be tinted green, is a symptom of a type of handshake failure where two devices fail to agree on whether YCbCr or RGB data format is in use on the cable. If the error goes the other direction, the video is tinted pink. You should be able to do fix this by setting explicit output format selections (e.g., YCbCr 4:4:4) instead of AUTO on your various devices. Good luck.
mogrub is offline
post #8028 of 9439 Old 06-24-2014, 08:01 PM
Dave_O's Avatar
Mine has the same behavior. Agree it's an HDMI handshake issue, not a defective unit.
Dave_O is offline
post #8029 of 9439 Old 06-25-2014, 03:00 AM
Ray77085's Avatar
Quoted: 132 Post(s)
Liked: 160
Add my unit to the crowd of the brief handshake issue, whenever I change the video source in the A/V receiver !!
It's brief so it really doesn't bother me too much.
Ray77085 is offline
post #8030 of 9439 Old 06-25-2014, 04:12 AM
mattg3's Avatar
Quoted: 265 Post(s)
Liked: 169
When i learned what it was I was never bothered by the split second pink screen again.Just part of the HDMI glitch.
Matt
mattg3 is offline
post #8031 of 9439 Old 06-25-2014, 11:06 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
It's evidently a receiver issue. I use a Denon 2309CI and switch HDMI video sources frequently and never see a pink screen.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #8032 of 9439 Old 06-25-2014, 12:58 PM
hodges69's Avatar
Quoted: 60 Post(s)
Liked: 44
I use the Denon 2311 and have the pink handshake,..Darbee going straight into the tv...question....after switching activities,does the darbee maintain it's status?
hodges69 is offline
post #8033 of 9439 Old 06-25-2014, 05:12 PM
bweissman's Avatar
Quoted: 224 Post(s)
Liked: 88
Was there a resolution to the issues playing 3D?
I just installed my Darblet today. It works fine in 2D, but won't play 3D at all. I get periodic white flashes of video noise which continue throughout playback, and occasional losses of sync. This happens with Darbee processing off or on.
I have tried 2 different Blu-ray discs and several different high speed HDMI cables. Made sure cables were well seated and not jiggling around. Still no joy.
Since many of the reported 3D issues were reported here on this thread a while ago, I wonder whether there has been a definitive resolution.
Setup:
Oppo BDP-103 -> Marantz 8801 -> Darblet -> Sony VPL-VW600ES
Discs tried:
Spears & Munsil 2nd edition
Gravity 3D
Thanks in advance!
bweissman is offline
post #8034 of 9439 Old 06-25-2014, 06:48 PM
UHD Addict
aaronwt's Avatar
Quoted: 5208 Post(s)
Liked: 3114
???The Darbee is rather inexpensive. There were devices that costs many times more than the Darblet years ago. They didn't get anywhere near the results of the Darblet.
Keenan and IMRIZZO like this.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Samsung UBD-K8500--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
post #8035 of 9439 Old 06-25-2014, 07:03 PM
Ray77085's Avatar
Quoted: 132 Post(s)
Liked: 160
Well I have the Onkyo 809 and I'm sure I have it set to Through: Select this to pass video through the AV receiver at the same resolution and with no conversion.
Direct: Does not adjust picture quality (does not change resolution).When video is output from HDMI output(s), it is processed the same as “Through”.
Like I said it's not a big deal as long as it doesn't start lasting for any long length of time between the sources.
Ray77085 is offline
post #8036 of 9439 Old 06-25-2014, 10:45 PM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
I wasn't necessarily comparing the price of the Darbee to other processors. I was simply pointing out that it's kind of silly to include such a crappy remote with a device that costs $300. It's not like remotes cost a lot of money these days. Heck, even a $50 Roku comes with a nice, solid RF remote.
post #8037 of 9439 Old 06-26-2014, 01:12 AM
bweissman's Avatar
Quoted: 224 Post(s)
Liked: 88
You mean everyone on AVS doesn't use a universal remote? Get one, you'll like it. (Oh wait, the most recent one I bought did cost $300.)
The build quality of the Darblet itself is more concerning. It doesn't even weigh enough to keep my beefy HDMI cables from pulling it off the TV stand, and the 2-sided input/output is horrible, especially since the power cord prevents using a 90 degree HDMI adapter on that side to get the cable pointed in the right direction.
I was aware of the poor build ahead of time, of course. I received the Darblet as a gift. I've already demoted it from home theater to bedroom TV after 1 day. I can't keep it in the HT chain if it won't do 3D, so maybe it'll make Jimmy Kimmel look better.
post #8038 of 9439 Old 06-26-2014, 05:15 AM
Quoted: 40 Post(s)
Liked: 43
Well maybe you received a bad unit. I have watch several movies in 3D and they all looked great. Oppo 103>>Denon 4311ci>>Darbee>>Sharp 70"
Hometheatergeek
aka AL
My Current System
post #8039 of 9439 Old 06-26-2014, 07:10 AM
UHD Addict
aaronwt's Avatar
Liked: 3114
If you have the version that does 3D and it doesn't actually work with 3D you should exchange it. I've had both of my Darblets for over 1.5 years now. Neither one has an issue with 3D content.
I've had no problem with the HDMI cables going into my Darblets. I just had to make sure I placed it on a smaller flat surface to allow space for the cables attached at each end.. But there is no question it would be better if the input/output cables were in a different location.
aaronwt is offline
post #8040 of 9439 Old 06-26-2014, 09:05 AM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
That's very similar to my setup. Oppo 103 -> Denon 3313CI -> Darbee -> Sharp 70" Elite.
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
