Darbee vision darblet - Page 277 - AVS Forum | Home Theater Discussions And Reviews
 266Likes
post #8281 of 9505 Old 11-19-2014, 05:18 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Can anyone speak to how the Darbee works with streaming video, i.e Apple TV? I don'r really watch that many blu-ray movies.
mbroadus is offline
post #8282 of 9505 Old 11-19-2014, 07:02 AM
pacman9270's Avatar
Quoted: 94 Post(s)
Liked: 53
It does alright for me. You just have to find the settings that work for you. If you're asking if there is an improvement in picture, yes.
Theater Setup: 5.2.5 (10.1 Auro3D) / ~3100 cu.ft. / Vaulted Ceiling
Projector:JVC DLA-X570R Screen:SI Performance Series 16:9 100" Source Player:Oppo BDP-103D/UDP-203 Pre/Pro:Marantz AV8802A Amps:Emotiva XPA-5(Fronts/Surrounds) and BasX A500(Heights) Fronts/Surrounds:Sonus Faber Venere 2.0 Center:Sonus Faber Venere Center Front/Rear Heights:Definitive Technology PM1000 / ProCenter1000(VOG) Subwoofer:Dual SVS SB-2000 Speaker Wire:Monoprice CL2 12-AWG w/Bananas ICs:BlueJeanCables/Mediabridge
pacman9270 is offline
post #8283 of 9505 Old 11-19-2014, 07:10 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Thanks...went ahead and ordered a once used one through Cleveland Plasma.
mbroadus is offline
post #8284 of 9505 Old 11-19-2014, 10:56 AM
pacman9270's Avatar
Quoted: 94 Post(s)
Liked: 53
Great move! I was impatient and paid full price. Have fun and post your thoughts!
post #8285 of 9505 Old 11-19-2014, 01:56 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
Smarthome.com has them on sale as overstock (25% off)... I think mine was $257 shipped including tax. Just click add to cart to see sale price.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
post #8286 of 9505 Old 11-20-2014, 04:03 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Anyone know if the Darbee can be controlled by a Harmony 880?
Panasonic P60VT60 Calibrated by Chad B
Marantz NR-1504
GoldenEar SuperSat 50s
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #8287 of 9505 Old 11-20-2014, 04:14 PM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
Yes. The Darblet is in the Harmony database. I control mine from a 900. I assume with the 880 you'd need line of sight for the IR, but that would be your only limitation.
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
post #8288 of 9505 Old 11-20-2014, 05:07 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Thanks...do you need line of sight with the Darby remote? I curious where I'm going to place the darblet so that its hidden but still be able to control it.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #8289 of 9505 Old 11-21-2014, 05:59 AM
mecmec's Avatar
Quoted: 417 Post(s)
Liked: 169
yes, you do need a direct line of site for the IR remote to work.
mecmec is offline
post #8290 of 9505 Old 11-21-2014, 06:51 AM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
The Darblet has only an IR receiver (no RF or Wifi), so it needs line of sight to whatever IR emitter it is "listening to".
But you can use an IR repeater, like this one, so that the Darblet can be hidden out of sight -- tucked behind something, or in a closed cabinet. The only thing your remote has to be able to "see" is the repeater receiver, and a little wire snakes down from that to the IR blaster that you'd seat next to the Darblet.
There are also Harmony devices that operate with RF and IR, allowing you to send the command signal via RF to a paired IR "blaster" that is not in line of sight to the remote.
mogrub is offline
post #8291 of 9505 Old 11-21-2014, 07:13 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #8292 of 9505 Old 11-21-2014, 08:09 AM
Paul H's Avatar
Quoted: 36 Post(s)
Liked: 30
Per the Darblet DVP-5000 Installation FAQ:
What kind of IR Extender should I use?
This is the validated IR Extender we recommend: http://infrared-resources.com/Infrar...B002JSDHCY.htm
mbroadus likes this.
LG 65" 4K/UHD E6P (Direct-view OLED Full HD Passive-3D)
Oppo UDP-203
Avatar: IMAX Header
BD 3D, BD, HD DVD, DVD collection
Paul H is offline
post #8293 of 9505 Old 11-21-2014, 09:25 AM
hometheatergeek's Avatar
Quoted: 40 Post(s)
Liked: 44
I use a Harmony one with my Darblet. The Darblet is actually behind my 70" Sharp display with the IR facing the front wall and I am able to operate it without using a emitter or trigger wire. I was pleasantly surprised it works. I have been using it this way for over a year now.
Hometheatergeek
aka AL
My Current System
hometheatergeek is offline
post #8294 of 9505 Old 11-21-2014, 12:16 PM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
And it's priced right, too.
mogrub is offline
post #8295 of 9505 Old 11-21-2014, 07:57 PM
Schwa's Avatar
Quoted: 1088 Post(s)
Liked: 1144
My Darblet is mounted on the back wall of my theater room just behind my projector and it works fine with my Harmony Touch. I aim the remote at the screen and the Darblet (which is above and behind me) picks up the IR signal just fine.
Schwa is offline
post #8296 of 9505 Old 11-21-2014, 08:05 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
same goes for me.
NODES is offline
post #8297 of 9505 Old 11-21-2014, 11:16 PM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
For readers confused by the mixed messages on this, IR signals are straight line, but they can reflect. How much (if at all) depends on distances, geometry, surface textures, etc. Can't count on it, but fun when you get the bounce.
mogrub is offline
post #8298 of 9505 Old 11-22-2014, 01:29 PM
pipe dreams's Avatar
I've had the Darbee Darblet for about 6 months. Yesterday for some reason a rectangular box appeared on the lower right of my screen with "Darbee 55%" or whatever it's set it to. It will not go away and is very distracting as I finally had to disconnect it. Does anyone know how to make it go away.
pipe dreams is offline
post #8299 of 9505 Old 11-22-2014, 01:48 PM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
I think it's in the Menu under Settings/Logo Properties. Set it to not persistent.
Kilgore is offline
post #8300 of 9505 Old 11-22-2014, 02:44 PM
Yes, that worked. Thanks much!
post #8301 of 9505 Old 11-22-2014, 02:56 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Not finding the Darbee listed in the device selection, anyone remember where it's located?
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #8302 of 9505 Old 11-22-2014, 04:34 PM
NODES's Avatar
Quoted: 653 Post(s)
Liked: 273
I wonder if your Darbee had reset itself...
NODES is offline
post #8303 of 9505 Old 11-22-2014, 05:11 PM
jgourlie's Avatar
Quoted: 26 Post(s)
Originally Posted by ellisr63 View Post
Smarthome.com has them on sale in the closeouts... I think mine was $257 shipped including tax.
Can't seem to find the closeouts on their website.
Any help is appreciated….or if anyone knows of a darblet on sale for Black Friday??
jgourlie is offline
post #8304 of 9505 Old 11-22-2014, 05:34 PM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
I'm sorry it's not closeouts but overstock. Here is the link (just click on add it to cart to get the discounted price).
http://www.smarthome.com/darbee-visu...r-premium.html
ellisr63 is offline
post #8305 of 9505 Old 11-22-2014, 05:41 PM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Bought a once used one from Chris @Cleveland Plasma Wednesday for a good price.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #8306 of 9505 Old 11-23-2014, 07:06 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Received my darblet yesterday and connected it last night and watched a couple movies on HBO using the HD & Full Pop settings between 55-75% and cannot see much of a difference. Even using the demo mode were if does the wipe, there only a razor thin difference. I'm hoping it's the source, comcast. Suggestions?
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #8307 of 9505 Old 11-23-2014, 07:08 AM
David Susilo's Avatar
Quoted: 619 Post(s)
Liked: 586
TV size? Viewing distance? TV picture mode?
David Susilo is offline
post #8308 of 9505 Old 11-23-2014, 07:11 AM
mbroadus's Avatar
Quoted: 506 Post(s)
Liked: 147
Panasonic 60VT60 calibrated by Chad B using Professional 1 (Day) & 2 (Night). Viewing distance 9-10 ft.
Marantz NR-1504
SVS PC-2000
AppleTV 3
Sony PS4
mbroadus is offline
post #8309 of 9505 Old 11-23-2014, 07:14 AM
Quoted: 619 Post(s)
Liked: 586
Try just leaving it on for several days using HiDef at 70%. After several days, turn off the Darbee... You'll clearly see what you're missing after you get used to Darbee processing.
post #8310 of 9505 Old 11-23-2014, 07:15 AM
badgerpilot's Avatar
Quoted: 75 Post(s)
Liked: 45
My suggestion is keep watching! And playing with the settings. I leave mine set to around 35 most of the time. When I got mine on an Oppo 103D, I thought the same as you, this thing is doing nothing! But after a few days, it became clear(pun intended) that Darbee indeed was working. For me, the biggest difference is in watching normal TV via DISH. The picture has more depth, richer blacks, and more clarity. The detail is excellent but not noticeable if that makes sense. What Darbee does it does without putting attention on itself. Just keep watching, I think you will have an "ah ha" moment.
badgerpilot is offline
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
