Darbee vision darblet - Page 288 - AVS | Home Theater Discussions And Reviews
 109Likes
post #8611 of 8625 Old 03-19-2015, 12:48 PM
j.woodhouse's Avatar
Thank's to everyone who gave an opinion to my original post all of which are positive.
Had you all wrote that the Darbee was garbage I'd have £199 more in my pocket now.
j.woodhouse is online now
post #8612 of 8625 Old 03-19-2015, 03:25 PM
momswgn's Avatar
Quoted: 20 Post(s)
TL;DR
The DVP5000 would be the better way to go as one could install it between the AVR and the TV/PJ vs getting a oppo 103d, right? Thanks.
momswgn is online now
post #8613 of 8625 Old 03-22-2015, 02:20 AM
Peterpack's Avatar
Quoted: 44 Post(s)
im thinking of getting a darblet for use with a BenQ W1070
Are these a good match ?
Peterpack is online now
post #8614 of 8625 Old 03-22-2015, 06:59 AM
Bachelor's Avatar
Quoted: 14 Post(s)
I'm using a w1070. My initial reaction i wasn't blown away but it has grown on me. I'm running hd mode at 50.
old corps likes this.
Bachelor is offline
post #8615 of 8625 Old 03-22-2015, 08:34 AM
Ricoflashback's Avatar
Quoted: 118 Post(s)
Liked: 105
I have the BenQ W1080ST (virtually same model as W1070 except for short throw distance) - - and the Darblet is absolutely fantastic with the projector. Night and day. It's like putting a pair of glasses on - - the image is much sharper with the Darblet on. Colors are great, too!
Not sure what folks say/see when they comment that the Darblet doesn't make much difference for a projector. Not my experience. A profound, positive difference.
Mr.G and fredxr2d2 like this.
Home Theater Setup
Samsung UN65ES8000 LCD/LED
BenQ W1080ST Projector
Pioneer SC65 (Pre-Amp)
Wyred4Sound MMC-7 Channel Amplifier, 221wpc
OPPO 103, Directv GENIE
Darbee Darblet
ALL Paradigm - 7.1 - Studio 60's, V.2 (FL/FR)
CC-690, V.5 (C)
ADP 590 V.5 (SS)
MilleniaOne 2.0 (BS) - Velodyne 810 Sub
Ricoflashback is offline
post #8616 of 8625 Old 03-23-2015, 04:49 AM
mogrub's Avatar
Quoted: 183 Post(s)
Liked: 159
Yes definitely, the Darblet can be installed between the AVR and the TV/PJ. Most do it that way, and with good results. As for "better way to go", that's a closer call. It's definitely the less expensive way to go. For many, that will be the end of the analysis. But the Oppo 103D also offers the ability to route multiple sources through it for Darbee processing, thus producing similar functionality to the Darblet's end-of-chain installation. The UI is different between the two devices. Some will prefer one over the other. The 103D allows for SACD playback obviously, which may be an added bonus for some. But one important nuance is that this Darblet thread has dozens of reports from users that have encountered HDCP "handshake" issues of mixed severity (usually correctable, albeit with varying levels of effort and expense) with their Darblet. In contrast, there are virtually no such reports on the 103D thread. So there is that.
I've owned both devices, and really like both of em, and my experience follows those thread tendencies exactly -- I had fairly persistent handshake headaches with the Darblet, but have never had any with the 103D. That said, I think both devices are terrific because the Darbee effect on my projected image is a must have. Overall, there is no single "better way to go" answer that fits everybody. If a user has longer than usual HDMI runs (one factor that significantly increases the risk of handshake issues), and dislikes tinkering and trouble-shooting, the 103D may be the way to go. If a user is more budget conscious, enjoys tinkering, and has done the homework on how to fix HDCP issues, the Darblet is probably the way to go.
But either way, Darbee processing is killer, and is the same on both devices.
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
post #8617 of 8625 Old 03-23-2015, 10:19 AM
momswgn's Avatar
Quoted: 20 Post(s)
Thanks for the response. I'm going with the 103D. Now to figure out how to incorporate it as the last link before the plasma and projector since HMDI 2 does not get the Darbee processing. As it stands now I have a NAS to a WD Live Hub, channelmaster, oppo 83, and XBox, PS3 all going into the AVR and the out to the plasma. I'm adding a PJ and keeping the plasma in the same room. I'd like to get darbee processing to both the tv and pj. So maybe running everything into the AVR and outputting to the 103D, splitting the HDMI 1 output of the 103D and run an hdmi to each.
post #8618 of 8625 Old 03-24-2015, 03:45 PM
[quote=j.woodhouse;32726257]After reading the positive reviews on the DVP500 I'm thinking of teaming one up with my Panasonic PTAE8000 projector & 110" screen.
Originally Posted by mecmec View Post
I own the 8000, and a 126" 16x9 screen. You WILL see a difference. Just buy it. At first you will play with all the various settings, and going "ohhh, that's nice" and "Whoah..that's too much", then you will find a happy medium and set it at that and leave it alone. Then you will become so used to it, it will be second nature. Then when you think it's not working, go and turn it off and you will go "ugh, that doesn't look right" and then put it back on and be happy..
I have only had 30 short minutes to play with my new Darbee viewing HD TV on a DVR I agree with your opinion but in a reverse order.
When I fired up the Darbee I couldn't notice any change to my usual picture even when adjusting the settings I thought it wasn't working. The split screen demo proved I was wrong as the non Darbee side of the screen looked surprisingly very soft focus. I'm really looking forward to playing with this more & trying it with some decent Bluray material over the next few weeks.
post #8619 of 8625 Old Yesterday, 03:22 PM
mogrub's Avatar
Quoted: 183 Post(s)
Liked: 159
Originally Posted by j.woodhouse View Post
I have only had 30 short minutes to play with my new Darbee viewing HD TV on a DVR ... When I fired up the Darbee I couldn't notice any change to my usual picture ... The split screen demo proved I was wrong as the non Darbee side of the screen looked surprisingly very soft focus. I'm really looking forward to playing with this more & trying it with some decent Bluray material over the next few weeks.
Yes, that would be a full blow addiction already in process. Sadly, there's a very poor cure rate for that condition. Your two options are (a) seek immediate professional help, or (b) just enjoy your new Darbee.
The second option is way cheaper. Post back when you hit your Blu-Rays. Most users report the better the source, the better the Darbee effect.
mogrub is offline
post #8620 of 8625 Old Yesterday, 05:32 PM
bweissman's Avatar
Quoted: 75 Post(s)
Liked: 43
Imagine, just hypothetically, that your projector gave you a perfect picture without external processing. Then you wouldn't want to put a Darblet in the chain.
In real life, the Darblet did not improve my Sony VPL-VW600ES. The Sony has its own magic detail enhancer called Reality Creation. I tried the Darblet for a week and ended up moving it to an older Sharp LCD flat panel, which it improves considerably.
True story. This happened last year:
My wife: What do you want for your birthday?
Me: A Darbee Darblet.
Wife: What's that?
Me: A magic box which will make the home theater picture look better.
Wife: How could it look any better?
OPPO BDP-103, Comcast DVR, Sony FMP-X1 4K server
Marantz AV8801 pre/pro, Yamaha MX-A5000 amp
Sony VPL-VW600ES projector, Stewart StudioTek130 103" diag screen
7 Thiel speakers (3 SCS4, 2 PowerPoint, 2 PowerPlane), 2 JL Audio E110 subs
Harmony Ultimate remote
bweissman is online now
post #8621 of 8625 Old Today, 05:32 AM
Dreamliner's Avatar
Quoted: 84 Post(s)
Liked: 39
So you don't plan to get 4K then?
The one caveat I will give you is that Reality Creation is very good. The difference you see when turning that on is what we all see.
Regardless, you absolutely should see a difference, because it does do something, which you saw on your Sharp.
Dreamliner is online now
post #8622 of 8625 Old Today, 08:52 AM
fredxr2d2's Avatar
Quoted: 83 Post(s)
Liked: 58
It sort of stands to reason that if you have a $10,000 projector, then the $200 little box isn't going to do as much as when you apply the $200 box to a $800 projector or TV. That's my thoughts on it, anyway.
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas
Currently watching on: BenQ W1070, 82" 1.0 Gain Screen, Darbee Darblet HD 43%, PS3, with Yamaha Aventage RX-A1030, SVS PB-2000, a Def Tech CS-8040HD, 2 SM65 for L/R, and 2 SM55 for surrounds.
fredxr2d2 is online now
post #8623 of 8625 Old Today, 09:57 AM
zoro's Avatar
Quoted: 140 Post(s)
Liked: 36
Would new CI 5100 any better that current darblet?
zoro is online now
post #8624 of 8625 Old Today, 10:38 AM
bweissman's Avatar
Quoted: 75 Post(s)
Liked: 43
Got it already. The Sony PJ's upscaling is excellent.
post #8625 of 8625 Old Today, 10:58 AM
Dreamliner's Avatar
Quoted: 84 Post(s)
Liked: 39
Oh...right. Well, what did you expect!
My next projector will probably be a Sony, I do like them but they sure are spendy. My JVC is lovely.
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
