Darbee vision darblet - Page 290 - AVS | Home Theater Discussions And Reviews
 113Likes
post #8671 of 8690 Old 05-11-2015, 12:05 PM
Tin_Can's Avatar
Quoted: 186 Post(s)
Liked: 37
Is there any difference between darbee darblet and other darbee enabled units like oppo or lumagen?
Tin_Can is offline
post #8672 of 8690 Old 05-11-2015, 12:07 PM
vega509's Avatar
Quoted: 122 Post(s)
Liked: 49
Originally Posted by cdnscg View Post
My remote just stopped working properly. I changed the battery, and still it is erratic at best. The menu still works from the unit itself, but thats a pain from were I've placed it in the chain of cables. Any one have an issue with the remote with a simple fix?
if you are sure the battery is up to snuff, (these remotes are finicky), remove the battery and get a q-tip and some rubbing alcohol and clean the contacts. Mine had some type of grease in there.
One thing that helps, once your remote is working properly is to remove the battery when you are not using it.
vega509 is online now
post #8673 of 8690 Old 05-11-2015, 12:17 PM
cdnscg's Avatar
Quoted: 105 Post(s)
Thanks. Will give it a try.
cdnscg is offline
post #8674 of 8690 Old 05-11-2015, 05:50 PM
humbland's Avatar
Quoted: 67 Post(s)
Liked: 35
First try replacing the battery. I had a remote go bad. I emailed Darbee CS and they sent me a new one. They asked for the old one back to check it out. Great CS experience.
humbland is online now
post #8675 of 8690 Old 05-11-2015, 07:01 PM
Kilgore's Avatar
Quoted: 426 Post(s)
Liked: 302
Not a simple fix, but I control mine with my Harmony remote. It works WAY better than the original Darbee remote.
Kilgore is offline
post #8676 of 8690 Old 05-12-2015, 09:48 AM
mogrub's Avatar
Quoted: 192 Post(s)
Liked: 163
+1^ My remote was DOA when I bought the Darblet a couple years ago, and they immediately replaced it. Good CS for sure.
+1^ Amen on the Harmony. Our Darblet isn't in the same room as the display, so the OEM remote isn't much help anyway.
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
post #8677 of 8690 Old 05-12-2015, 09:54 AM
humbland's Avatar
Quoted: 67 Post(s)
Liked: 35
+1 on the alternative remote fix.
We took a programmable remote and "learned" the Darbee codes. They are simple and few. Up/down and Menu were the ones we used the most. Add those to your HT remote and you are good to go...
post #8678 of 8690 Old 05-17-2015, 03:57 AM
a5ian300zx's Avatar
Does anyone know if you can get better case for the Darbee as I hate the look of the plastic?
Ps. For the remote if you have smart Android phone with ir blaster then you can download smart remote by tiger which has the Darbee in their database.
I have not checked the harmony database yet.
TV: Panasonic 55" VT65 Surround: Yamaha RX1073 + Orbs Audio Mod2 7.1 + SVS SB12-NSD Stereo: Yamaha AS500 + Kef Q300 Processor: Lumagen XS3D+ Darbee Players: HDI Dune Prime 3 / Nuc i5 - KODI / VU+ Duo2 / Roku 3 NAS: Qnap 869 Pro
a5ian300zx is offline
post #8679 of 8690 Old 05-17-2015, 12:13 PM
oink's Avatar
Quoted: 1601 Post(s)
Liked: 1224
I'm beginning to suspect my Darbee is overheating.
Anyone else run into this?
Currently, I have it laying on carpet (probably not the best place).
Only girly-men push The Red Button.
oink is online now
post #8680 of 8690 Old 05-18-2015, 11:03 AM
oink's Avatar
Liked: 1224
UPDATE: Now I get a black screen and no response from the unit.
Time to call Darbee for an RA#
oink is online now
post #8681 of 8690 Old 05-18-2015, 12:21 PM
Raistlin_HT's Avatar
Quoted: 29 Post(s)
Liked: 26
I would avoid repeating this when your new one arrives.
Raistlin_HT is online now
post #8682 of 8690 Old 05-18-2015, 01:50 PM
bweissman's Avatar
Quoted: 107 Post(s)
Liked: 49
You could get the DVP-5100CIE which comes in a fancier case at a higher price.
bweissman is offline
post #8683 of 8690 Old 05-18-2015, 04:01 PM
73shark's Avatar
Quoted: 96 Post(s)
Liked: 66
I would avoid mentioning this when you request the RA number.
In space, no one can hear you scream . . .
73shark is offline
post #8684 of 8690 Old 05-19-2015, 12:22 AM
oink's Avatar
Liked: 1224
So, there is a heat problem with the Darbee....
oink is online now
post #8685 of 8690 Old 05-19-2015, 04:54 AM
JRWalker's Avatar
Quoted: 30 Post(s)
Liked: 50
My Darblet has an external 5V 1A power supply. It would take an external heat source on the Darblet, like a sunlamp, to overheat it.
JRWalker is online now
post #8686 of 8690 Old 05-19-2015, 07:35 AM
73shark's Avatar
Quoted: 96 Post(s)
Liked: 66
Don't know about that. Just wouldn't want to give them an excuse not to honor warranty.
73shark is offline
post #8687 of 8690 Old 05-19-2015, 11:12 AM
Quoted: 29 Post(s)
Liked: 26
That's like saying an amp has a heat problem if you throw it in a sealed cabinet
Basically every electronic device that generates heat has a warnings to place it on a flat surface, give clearance to vents, etc. You might as well wrap it in a blanket and then blame the manufacturer when it implodes.
Per the first item in the Care and Maintenance of Your DARBEE Product section:
  • Allow for ventilation and avoid temperatures below 32 F (0 C) or above 140 F (40 C)
Spoiler!
post #8688 of 8690 Old 05-31-2015, 07:50 PM
zoro's Avatar
Quoted: 167 Post(s)
Liked: 38
Originally Posted by BG624 View Post
I use it on my 60" Elite Plasma (professionally calibrated) and I like the detail it adds.
can u take some pictures to impress us?
zoro is offline
post #8689 of 8690 Old 06-01-2015, 07:40 AM
mattg3's Avatar
Quoted: 120 Post(s)
Liked: 136
Has anyone tried using a Darblet with an OLED tv?
Matt
mattg3 is offline
post #8690 of 8690 Unread Today, 03:44 PM
cessna1466u's Avatar
Quoted: 70 Post(s)
Liked: 187
Where to install the DVP-5000?
After asking a few questions on some of the other sections here I have decided to add a Darbee unit to my setup. I think I know where inline it should go but thought I would ask just in case. Here is my video setup.
-Xbox 360
-PS3
-DirecTV DVR
---All of these units connect to my Yamaha RX-A2030 receiver which then sends the signal unprocessed/unconverted to an HDMI switch that either sends the signal to a Mitsubishi DLP or an Optoma HD20 Projector (projector is mainly used for movies and some gaming)
So do I put the darbee right after the Yamaha and before the HDMI switch so that it can process the video before it sends it to the TV or Projector? Or should I put it after the HDMI switch and have it only process for the projector since that is what we use most for movies?
cessna1466u is online now
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
