Darbee vision darblet - Page 298 - AVS Forum | Home Theater Discussions And Reviews
 258Likes
Old 10-18-2015, 03:10 PM
oink's Avatar
Quoted: 5299 Post(s)
Liked: 3036
Originally Posted by kwok lau View Post
You shall email or phone Darbee company. They could help.
I sent it in 6 months or so back for a probably related issue.
Unfortunately, it hasn't worked properly since.
Originally Posted by vega509 View Post
have you checked your new power supply? I bought 2 that were DOA, luckily I found one that was for a cell phone, 5V 1.1a and it worked with the Darblet.
I'll see if I can find one lying around the house.
mmiles likes this.
oink is offline
Old 10-18-2015, 04:33 PM
kwok lau's Avatar
Quoted: 249 Post(s)
Liked: 76
I have sent my Darbee 5000 for checking about 3 months ago. Even they could not find out the problem I encountered, they said the power adaptor which came with the Darbee when I bought it, had a common issue of "Unstable" supply of power to the unit. They returned the unit with a new power adaptor free of charge. The warranty had been expired though. Since its return, I do not have problem so far.
I still encourage you to get with them again. No harm to do so.
kwok lau is offline
Old 10-18-2015, 05:42 PM
humbland's Avatar
Quoted: 367 Post(s)
Liked: 84
+1 on Darbee CS. My remote failed out of warranty and they sent out a new one (they wanted the old one to check out).
Great CS.
humbland is online now
Old 10-18-2015, 06:49 PM
kwok lau's Avatar
Quoted: 249 Post(s)
Liked: 76
What a co-instance, My Darbee remote is not working as well. I have put in a new battery, but no response. I am now using the buttons on the unit itself to do adjustment and testing. Not a big issue. I might get with Darbee later.
kwok lau is offline
Old 10-18-2015, 07:16 PM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
. . . I have put in a new battery, but no response. I am now using the buttons on the unit itself to do adjustment and testing. . . .
Had this problem a while ago myself. Have you tried power cycling your Darblet? Unplug power connector for a few seconds then reinsert. That worked for me.
JRWalker is offline
Old 10-18-2015, 07:24 PM
kwok lau's Avatar
Quoted: 249 Post(s)
Liked: 76
JR Walker, My darbee power connection is parallel with my blue ray player. (i.e. my darbee is powered off when I turned off my player). It is similar to power cycling as you said?! Thank for your advice after all.
kwok lau is offline
Old 10-20-2015, 11:45 AM
mogrub's Avatar
Quoted: 212 Post(s)
Liked: 180
Originally Posted by KBMAN View Post
With your guys' help I got it to un-Blink.....'solving the world's problems, one blink at a time
What did the trick???
Every once in a while, quite inexplicably, things actually go according to plan.
mogrub is offline
Old 10-20-2015, 12:11 PM
calentz's Avatar
Quoted: 61 Post(s)
Liked: 43
+1
--Carl
calentz is offline
Old 10-20-2015, 09:29 PM
KBMAN's Avatar
Quoted: 258 Post(s)
Liked: 144
Wink
I went into the menu of the Darblet....Somewhere in logo properties, I turned 'Persistent' off...Then, for the final kicker of the LED's , I went into LED Display and turned it all the way off...problem solved...(for now)....Hats off to the late Dr. Darbee...The Guy was a F*&ckn genius.....(even with the invention of the measly universal remote control )....cheers!
humbland likes this.
KBMAN is offline
Old 10-25-2015, 05:52 PM
SkOrPn's Avatar
Quoted: 71 Post(s)
Liked: 44
Chromecast + Darbee?
Has anyone tried this with a new Chromecast 2015 with the 4" extension yet? Does it even work with the Chromecast, and if so what is the best setup? Should I add a 3' cable between the Chromecast and Darbee, or a 6' cable? Then what length cable after the Darbee?
I am only concerned with Netflix and Plex playback, and maybe some Youtube here and there. Thanks
SkOrPn is offline
Old 10-28-2015, 06:35 AM
chadcj7's Avatar
Quoted: 58 Post(s)
I have noticed that the DVP5000 is sold out on the Darbee site and a lot of other sites. Is this there way of pushing the 5100 or are they looking to have a replacement model coming out soon for the 5000? I ask because I am thinking about getting one but I am willing to wait if they are coming out with a new model
chadcj7 is offline
Old 10-28-2015, 09:56 AM
SkOrPn's Avatar
Quoted: 71 Post(s)
Liked: 44
I'm thinking with all the 4K products showing up now that they might be getting ready to launch their own 4K products as well.
Sent from my SM-T700 using Tapatalk
SkOrPn is offline
Old 10-30-2015, 06:30 AM
Augmont's Avatar
Quoted: 96 Post(s)
Liked: 25
I will be starting a family room remodel that will place all my AV equip in closet about 50 ft away and will have several long HDMI runs - 65 ft, 75 ft, & 100 ft.
I will be using powered HDMI baluns over Cat 6 for these long runs.
Curious to know if Darbee works well in long runs. Should the Darbee be placed near the source (i.e. AV closet) or at the end near the projector and LCD TV?
Thanks...
Augmont is offline
Old 10-30-2015, 06:31 AM
Augmont's Avatar
Quoted: 96 Post(s)
Liked: 25
Thanks...
ellisr63 likes this.
Augmont is offline
Old 10-30-2015, 06:51 AM
pittsoccer33's Avatar
Quoted: 649 Post(s)
Liked: 430
I noticed the unit being sold out everwhere as well and thought a new product might be imminent. But CEDIA came and went without an announcement, and thats the kind of place I'd expect it to happen.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
Old 10-30-2015, 06:58 AM
humbland's Avatar
Quoted: 367 Post(s)
Liked: 84
Thanks...
I have a similar set up. I put the Darbee last in the chain, right before the front projector. I used a 6 foot HDMI cable from the Darbee to the PJ. Works great.
Old 10-30-2015, 07:01 AM
SkOrPn's Avatar
Quoted: 71 Post(s)
Liked: 44
Maybe they cant figure out how to improve upon 4K, lol. 4k already looks really good haha.
SkOrPn is offline
Old 10-30-2015, 07:15 AM
billqs's Avatar
Quoted: 291 Post(s)
Liked: 171
I was wondering, with the Darblet being HDMI 1.4 (I think) will it work with an HDMI 2.0 HDCP 2.2 Sony FMP10 4k Media Player? I think it will work with the rest of my equipment although my receiver is also HDMI 2.0a and HDCP 2.2.
billqs is offline
Old 10-30-2015, 12:11 PM
Jon S's Avatar
Quoted: 835 Post(s)
Liked: 268
You have to remember, Paul Darbee who engineered the device, passed away after the Darbee was just released. Don't know if his work was passed on to any one else who could expand upon his research... If they are not able to further work on the technology, Darbee products may be at end of life....
Hope not as I love the Darbee...
If it's not a BIG screen, it's not a theater...
Jon S is online now
Jon S's Avatar
Quoted: 835 Post(s)
Liked: 268
Jon S is online now
Old 10-30-2015, 12:43 PM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
Evidence to the contrary: http://www.darbeevision.com/4k-samples/
JRWalker is offline
Old 10-30-2015, 02:06 PM
Augmont's Avatar
Quoted: 96 Post(s)
Liked: 25
Good to hear that it plays nice with long HDMI runs. Let's hope it plays nice with the HDMI baluns I purchased.
Augmont is offline
Old 10-31-2015, 08:44 AM
ellisr63's Avatar
Quoted: 991 Post(s)
Liked: 413
Thanks...
I have mine hooked up to my Yamaha CX-A5100 with a 3' Redmere cable, and a 30' Redmere cable going to my AE8000 with zero problems. Your mileage may vary since it is so much longer.
Yamaha CX-A5100, (3) JBL 2360As/EV DHA-1s, (3) 1/4 Pie bass bins, 4 JBL 8340As, 4 JBL 8320s, PS3, XBoxOne, 2 Intel NUCs, Monoprice speaker wire, and XLR cables, Redmere HDMI cables, Monster HTPS7000, 2 Furman filters, 2 DTS-10 subs, Panasonic AE8000, SeymourAV 195" diagonal scope screen, Panamorph UH-480, Darbee Darcet, Yamaha P7000s, (2) Crest Audio CM2208s, Yamaha XM-4080, (2) MiniDSP DDRC-88.
The Ellis Family Go Big or go Home HT
ellisr63 is offline
Old 11-02-2015, 01:57 PM
Jon S's Avatar
Quoted: 835 Post(s)
Liked: 268
I have a Pioneer SC-67 with a Audioquest 1 meter cable connected to a Darbee. The Darbee is connected to a second Darbie inline with another 1 meter cable. That Darbee is connected to my JVC RS-1 projector by a 35 ft Monster Black Platinum cable. I have no issues with the connections...
Jon S is online now
Old 11-02-2015, 02:05 PM
cdnscg's Avatar
Quoted: 334 Post(s)
Liked: 65
Why 2 Darbees?
cdnscg is online now
Old 11-02-2015, 07:25 PM
Jon S's Avatar
Quoted: 835 Post(s)
Liked: 268
When the Darbees were first released, my dealer contacted Paul Darbee before he died. He said the Darbee worked best with two inline. If I remember correctly, the first Darbee was set as gaming and the second as HD. The gaming Darbee was set where the image was just slightly enhanced and then the HD Darbee was adjusted to finely adjust the image. Since I had two, I configured them that way... It did improve the image over using just one Darbee, but the difference could only be seen on a large screen, the differences was very subtle...
Jon S is online now
Old 11-02-2015, 09:40 PM
cdnscg's Avatar
Quoted: 334 Post(s)
Liked: 65
Interesting
Old 11-04-2015, 01:21 PM
chadcj7's Avatar
Quoted: 58 Post(s)
It appears that this device is going to continue to be sold as I received an email from Darbee stating that they were working on getting more in stock. I got some birthday money and I am thinking about getting one of these. I know the rack mounted 5100 is the same as this except it can be upgraded at home instead of sending it in. Do you think it is worth spending the extra money on that unit? Do you think it would be wise to wait until the first of the year after CES to see if anything else will be announced.
chadcj7 is offline
Old 11-04-2015, 01:28 PM
Quoted: 649 Post(s)
Liked: 430
How often are updates for it released?
Old 11-04-2015, 01:36 PM
oink's Avatar
Liked: 3036
I sent my Darblet in last week and it is already in transit back to me (their Service Dept. is very quick).
Hopefully, it will work now.
oink is offline
Darbeevision Darblet Hdmi Video Processor
