Darbee vision darblet - Page 316 - AVS Forum | Home Theater Discussions And Reviews
 246Likes
post #9451 of 9454 Unread 02-23-2017, 08:04 AM
wreckingball's Avatar
Quoted: 115 Post(s)
Liked: 29
Believe it or not, today is the first day I've ever seen a demo of this process, and wow...
It enhances (to my eyes) the thing that I most look for in an image, mainly, the depth of field.
Even the amatuer youtube uploads have me wanting one of these like, now.
Sure hope you guys are right about them developing a unit that will work with the 4k spec and all of it's concurrent tech, but I'm a bit skeptical.
Personally, I still watch a ton of 1080, and would settle for one of those units, if I could find one that is...
Off to the waiting lists...
Actually, I love tube amps..
I play guitars through them.
wreckingball is online now
post #9452 of 9454 Unread Today, 02:55 PM
humbland's Avatar
Quoted: 331 Post(s)
Liked: 79
Originally Posted by KK in CT View Post
Only to move it to try on another TV, but it didn't work there either. Everything does light up as it should, just does not pass a video signal to the TV. Nothing but a black screen.
Same thing just happened to me...Long time DVP-5000 user. Everything looked normal (LEDs on) from the outside. Just completely dead. As soon as I took it out of the chain, the picture worked fine.
Sad.
humbland is online now
post #9453 of 9454 Unread Today, 03:00 PM
KK in CT's Avatar
Quoted: 85 Post(s)
Liked: 55
Sad.
I actually did get mine working again. My issue happened to coincide with my new LG OLED TV. Apparently the Darbee does not like the Deep Color setting on the TV. For some reason I decided to add it back into the chain and give turning that setting off a try and sure enough the picture came right on. Not sure why, since the TV is at the end of the chain, but that did it. And I can't explain why it did't work on another TV either. The only other thing I did to the unit was tighten all of the screws - perhaps that is what really did the trick?
LG OLED65E6P | Oppo UDP-203 | Denon X5200W 7.2.4 | Darbee DVP-5000 | Emotiva XPA-3 | Sony PS4 | Xfinity X1
KK in CT is online now
post #9454 of 9454 Unread Today, 03:47 PM
calentz's Avatar
Quoted: 59 Post(s)
Liked: 42
Sad.
Aprox. the same thing happened to me. I measured the PS output voltage & it was low. (Finding a 5 volt power supply with the required wattage is a trick) I got the replacement from Darbee & all is good now.
--Carl
calentz is online now
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
