Darbee vision darblet - Page 323 - AVS Forum | Home Theater Discussions And Reviews
 292Likes
post #9661 of 9672 Old 09-14-2017, 06:43 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
My 5000 April 17, 2013 - September 12, 2017. RIP
JRWalker is offline
post #9662 of 9672 Old 09-14-2017, 07:04 AM
LastButNotLeast's Avatar
Quoted: 1793 Post(s)
Liked: 1404
What happened? Might just be the power supply.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #9663 of 9672 Old 09-14-2017, 07:39 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
Power supply is 5.25V. Died over two days. Picture started flashing to black then no picture at all. Only see Red and Green LEDs. Tried disconnecting 5000 from power for several minutes to reset. Replaced 5000 with Female to Female connector between In and Out cables and get perfect picture. Same results when input to monitor with HDMI input.
JRWalker is offline
post #9664 of 9672 Old 09-15-2017, 11:15 AM
fleaman's Avatar
Quoted: 76 Post(s)
Liked: 115
Originally Posted by bweissman View Post
I think Darbee Vision is probably done.
With UHD, HDR, WCG, Rec.2020, etc., what improvement can Darbee can bring to the table? And how can they even keep up and be compatible with all these new technologies? If they do choose to play, which I doubt, it will take them a long time to catch up.
Darbee is a sharpening 'effect'. It doesn't actually sharpen the image, it just appears that way through the pixel contrast trick they use.
This works on just about all images, from the well mastered to-disc stuff, to the crappy mastered to-disc stuff.
Even with Ultra blu ray, there will still be discs that were not shot and mastered as 'sharp' as many others. Playing that less sharp disc on your 4k UHD, HDR, etc display will not make it sharper. Those mentioned techs do not make less sharp sources appear sharper, while a Darbee does. And many of those Ultra blu rays will just be the same mastered source as the reg blu ray disc.
Also, Darbee doesn't just make things appear sharper, in many cases it makes the image a little more contrasty.
Those are my thoughts and they might not be totally (if at all) accurate.
fleaman is online now
post #9665 of 9672 Old 09-15-2017, 12:02 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7569 Post(s)
Liked: 4228
Most of us here are long-time Darblet users, so no need to explain to us how it works. We really won't know the level of noticeable improvement that can be obtained with native UHD content until (and if) a 4K Darblet is released.
rboster and a5ian300zx like this.
AustinJerry is online now
post #9666 of 9672 Old Yesterday, 12:25 AM
Macroblocker's Avatar
Quoted: 102 Post(s)
Liked: 37
any difference between the old darbee and the new-ish 5000s ?
Macroblocker is offline
post #9667 of 9672 Old Yesterday, 04:52 AM
geodon005's Avatar
Quoted: 49 Post(s)
Liked: 82
In terms of how it works, none that I can see. . . but the build quality seems to be a bit more robust.
geodon005 is offline
post #9668 of 9672 Old Yesterday, 06:31 AM
Liked: 4228
Functionally the same.
post #9669 of 9672 Old Yesterday, 10:21 AM
Quoted: 102 Post(s)
Liked: 37
oh ok , I was under the impression that the processing had improved
post #9670 of 9672 Old Yesterday, 10:39 AM
Liked: 4228
Nope, just lipstick on the pig...
post #9671 of 9672 Old Yesterday, 11:21 AM
Quoted: 102 Post(s)
Liked: 37
thanks for the info ! one review had said that full pop was usable on the newer version whereas the old 1.0 Darbee was too processed looking , honestly i keep my old Darbee at about 43% on hi deff mode , I guess I'm just wishing for a 4k Darbee and after reading through this thread that looks unlikely.
post #9672 of 9672 Old Today, 10:30 AM
Mr.G's Avatar
Quoted: 742 Post(s)
Liked: 418
I have gotten so used to my Darbee Darblet that I've often forgotten that it's working. For whatever reason it reset itself last week, the colored LED lights came on. I usually have them off but decided to leave them on since I can see them working and for me it's an easy visual confirmation. I've been running HD 40% on my Panasonic projector for years but after the reset I experimented with HD 50% and left it at the higher setting. Don't know if my tastes are changing or if my 5+ year old projector is showing its age.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
