Darbee vision darblet - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 239Likes
Old 07-31-2012, 03:11 PM
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
Originally Posted by lyris View Post
Thanks for the input, Kris. So would you say that having the device set to the low settings is like the images shown on the site, just at a greatly reduced opacity?
Why don't put your hands on one (borrow if not buy like most everyone else) and take a look for yourself. And then tell us if you can't find some setting in the HD mode at some point above ZERO that you would find enjoyable and usable. We're not all nuts here. Said with a big smile.....smile.gif
RonF is offline
Old 07-31-2012, 03:21 PM
zombie10k's Avatar
Quoted: 2805 Post(s)
Liked: 2742
I had an issue with my Darby and their support was great to replace it and also update the software at the same time.. excellent customer service. I think I have one of the first with the updated software.
@ lyris - imo, they shouldn't use those examples from the site, it could leave some with the wrong impression. I've spent time photographing the difference with the darby on/off and also with JVC's e-shift on/off from my RS55. I'll post these closeups soon so others can get a basic idea of what's going on with this device.
When used in moderation, this processor has a great impact on the perceived sharpness and depth of the image. I have a 142" 16:9 and it works especially well combined with JVC's e-shift. They both perform different kinds of image enhancement and one would think these 2 different technologies were designed for each other.
it's hard to resist for the low cost, I just ordered a 2nd one from AVS to use in a different room.
zombie10k is offline
Old 07-31-2012, 05:03 PM
Kris Deering's Avatar
Quoted: 1581 Post(s)
Liked: 2489
What I'm getting at is, is the implementation in the hardware the same as the web gallery software? (Or close enough to be visually similar?)
Even with the blend filter they are using on the website it is hard to get a good visual representation of what you'll see on a projection system. I have found that the better the source material the better the results with the Darbee, which was actually a bit surprising. The best Blu-ray transfers seem to benefit more from the processing in terms of depth and detail than softer transfers. And the fact that you can turn it on and off on the fly to see what its doing is a wonderful tool for evaluation.
My Home Theater
Kris Deering is online now
Old 07-31-2012, 05:39 PM
popalock's Avatar
Quoted: 1232 Post(s)
Liked: 1712
I can't wait to watch HTTYD on my system... It's set the benchmark on my setup and I'm looking forward to seeing what the Darblet can do!
popalock is offline
Old 07-31-2012, 05:43 PM
popalock's Avatar
Liked: 1712
Originally Posted by Jimbo85281 View Post
I finally got charged for my Darblet this morning!!! It must be shipping today! Finally the video enhancement gods have shined down on me lol
Mark, can you confirm?
I have some people coming over to demo my PJ and i'd love to show other AVS members what all the hype is about
popalock is offline
Old 07-31-2012, 06:12 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
I've also just gotten my D back for the FW upgrade--very prompt and efficient service!
However I'm not sure the 'color space problem' has been solved.   E.g., if I send it 422 or 444 from my Radiance, the pic ((on a Sony1000ES) has the usual screwed up color that is typical when the color spaces don't match.    If I output RGB from the Radiance to the D, then the colors look just right.
So it seems to me--unless I'm doing something stupid (which is still a good bet)--that the Darblet is still only able to receive RGB and pass it correctly.
millerwill is offline
Old 07-31-2012, 06:28 PM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
I can't say for certain, but I don't think Fedex delivered the units today to AVS, though this morning it showed they would be arriving this afternoon (so that's why the CC's had been charged today). I don't work for AVS, but that's my understanding
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
Old 07-31-2012, 06:59 PM
Waboman's Avatar
Quoted: 4581 Post(s)
Liked: 10686
My card hasn't been charged yet either. I'm still holding out hope it ships out tomorrow and I receive it by the weekend.
Waboman is online now
Old 07-31-2012, 07:14 PM
fookoo_2010's Avatar
Quoted: 231 Post(s)
Liked: 80
CC has a pending charge, so it should have been shipped, if not today, then tomorrow. Looking forward to it sometime next week as it gallops across the country.
fookoo_2010 is offline
Old 07-31-2012, 07:50 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Got my Darblet back today too!
Color space output is fixed in my setup! Fast service...nice! They even sent me a replacement power supply for the one that died on me.
Have not tested the power off JVC RS1 settings yet for when my 3D projector is on. It should allow my Duo to see my RS1 turned off.
Ronomy is offline
Old 07-31-2012, 07:53 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Did you set your projector back to auto color space? It should work now.
Ronomy is offline
Old 07-31-2012, 08:07 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
The Sony1000ES doesn't seem to have a setting to choose color space, presumably being able to use whichever is sent to it.
So, can you send 422 or 444 to your Darblet and have things work OK?
Old 07-31-2012, 08:20 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Yes! Every mode works perfectly and I verified the input on my JVC. The JVC auto selects the color space I send to the Darblet which passes what I send it without jumping to RGB like it was.
Ronomy is offline
Old 07-31-2012, 08:33 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
OK, tx for the info.
Old 07-31-2012, 08:45 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
I would try selecting a different HDMI input on your projector and then go back to the input with the the Darblet already passing 422 or 444.
Ronomy is offline
DarbeeDr's Avatar
You will find an additional feature in the new Darblets.
You can thank Jeff Meier for requesting 1% increments of adjustment to the Darbee Settings.
-DD
DarbeeDr is offline
Old 07-31-2012, 08:49 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
-DD
Hmmm.    I also don't have this feature in my 'up-graded' Darblet.     Seems like nothing got upgraded.
Old 07-31-2012, 08:55 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
It is in the advanced settings and is defaulted to off.
Ronomy is offline
Old 07-31-2012, 09:09 PM
tkbryant's Avatar
Quoted: 22 Post(s)
-DD
Sweet!! That's a pretty awesome feature to allow for even more personalized customization!! Can't wait to get mine!!
tkbryant is offline
Old 07-31-2012, 10:16 PM
Ronomy's Avatar
Quoted: 36 Post(s)
Liked: 25
Oh well! Dual projector setup still broken! Now when my JVC is off the darblet becomes a display device itself named HDMI TV. So my Duo doesn't auto change to output number 2 display settings. It stays on output 1 which has different cms and output settings. Bummer!
At least color space seems to be fixed.
Ronomy is offline
Old 07-31-2012, 10:23 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
Ah, yes--tx!    (Though actually I had no problem with the 5% steps.)
Old 07-31-2012, 10:28 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
Can some of you with the new Darblets, or upgraded ones, check your SW and FW (in the 'About' item in the menu).  Mine is SW:  2.8.2205, and FW:  1.3.21.
Old 07-31-2012, 10:43 PM
DarbeeDr's Avatar
I should have mentioned that you access the 1% feature in the Menu, under Advanced Settings.
If you find the 1% feature, you definitely have the new firmware.
-DD
DarbeeDr is offline
Old 07-31-2012, 11:04 PM
millerwill's Avatar
Quoted: 463 Post(s)
Liked: 261
-DD
Tx, DD; yes I have the 1% feature.   But still perplexed that things don't work when I send 422 or 444 color space from my Radiance to the Darblet (and from it to a Sony1000ES).    It does work if i send RGB out of the Radiance.
Old 07-31-2012, 11:35 PM
DarbeeDr's Avatar
We don't have a Sony1000ES in our lab, so it will be hard to quickly run this to ground.
We'll stay on it. Please return the unit for a full purchase refund, if is does not meet your needs.
-DD
DarbeeDr is offline
Old 08-01-2012, 02:03 AM
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
Oh good! So you don't have to use the 1s Ronomy? I'm perfectly happy and actually would prefer the increments of five. You can easily see those changes a click at a time rather than riding the up or down button.
On another note I think a couple people with projectors and large screens here mentioned The Art of Flying snowboarding bluray, and that prompted me to order it on Amazon 6 weeks ago but screwed up and somehow chose vendor from Italy. I finally got it today after all that time. WOW!! Everyone owes it to themselves to see the quality of this disc in their system with their favorite display. What the DVP processing can do with this s.o.t.a. camera footage throughout is jaw dropping. And there's no glasses being worn. eek.gif
RonF is offline
Old 08-01-2012, 02:32 AM
tkbryant's Avatar
Quoted: 22 Post(s)
Awwww man!!! I cannot wait!! I ordered this disc tonight after checking out a review. Really looking forward to checking it out with the Darbee!!
tkbryant is offline
Old 08-01-2012, 04:40 AM
kenny2428's Avatar
My DVP shipped yesterday, due to arrive on the 3rd. I will try to post some pictures up once it's up and running. smile.gif
Mitsubishi HC 4000 Projector
100 Inch Screen
Onkyo NR 828
HSU VTF-3 MK5 HP
kenny2428 is online now
Old 08-01-2012, 06:46 AM
zAndy12's Avatar
Quoted: 285 Post(s)
Liked: 217
Seems its quicker to ship from the US to a UK retailer and then to the customer than it is to get it to customers in the US smile.gif Mine will be with me tomorrow , arrived at UK retailer late yesterday, been sent today for delivery tomorrow, looking forward to seeing what this thing can do
zAndy12 is online now
Old 08-01-2012, 06:55 AM
henrich3's Avatar
Quoted: 573 Post(s)
Liked: 495
Configure your BD player to output 422 and verify that the Radiance's Status screen shows "Color Fmt: YCbCr 422" for the input. Reconnect the Darblet between the player & the Radiance, power cycle the Radiance, and see if the Status screen still shows "Color Fmt: YCbCr 422" for the input . If it reports "Color Fmt: RGB" then you've confirmed that the Darblet has an issue.
henrich3 is offline
Darbeevision Darblet Hdmi Video Processor
