Darbee vision darblet - Page 91 - AVS Forum | Home Theater Discussions And Reviews
 303Likes
post #2701 of 9701 Old 08-25-2012, 08:52 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Originally Posted by giomania View Post
I am going to stick with the flasher on the front.
Mark
Yep, me too although the urge to use the mini jack is there....
Geof
Geof is offline
post #2702 of 9701 Old 08-25-2012, 09:44 AM
"Don't PM Me Bro"
RandyWalters's Avatar
Quoted: 527 Post(s)
Liked: 782
I just got my Darbee and am still experimenting with it on my Panny 50GT50, but in the meantime it's awkward shape was making it impossible to integrate into my AV credenza. So i made a little stand for it out of some Monoprice 90 degree HDMI adapters and was able to place it on top my TWC Tuning Adapter below my center channel speaker and it looks ok there.
(2) #3733 90* HDMI adapters
(1) #4859 Flat 90* HDMI adapter
(1) #4860 Flat 90* HDMI adapter (opposite of the #4859)
Tivo S3 > Gefen 2x2 HDMI Splitter/Switcher > Darbee > 50GT50 Plasma (<----This chain caused magenta flash every few seconds so i removed the Gefen)
BTW when i place the Darbee between my Gefen 2x2 HDMI Splitter/Switcher and my 50GT50 i get a magenta flash a few seconds after turning the TV on and the audio also goes away, then the picture returns for a few seconds then i get another flash, and the flashes continue to repeat as long as the TV is on. Cycling the Darbee power and/or the TV's power doesn't stop this behavior so for now i've removed the Gefen Splitter from the loop and everything is syncing up just fine now. I'll fiddle with it more and try moving it around in my chain and try different HDMI cables etc when i get some time but for now i just want to enjoy it smile.gif
But so far i'm seeing a nice improvement in facial detail etc on 720p OTA and Cable channels which was my only real gripe about the GT50.
Randy
Sony 55W800B, Panasonic TC-P55ST60, TiVo Roamio Pro, TWC Arris DCX3600-M 6-Tuner DVR, Onkyo TX-SR333 AVR, URC MX-890, MX-780, MX-450, MX-500 Remotes.
Pic of My A/V setup - http://cdn.avsforum.com/f/f1/900x900..._Img_4867.jpeg
Gallery - http://www.avsforum.com/g/a/2082686/randywalter...
RandyWalters is offline
post #2703 of 9701 Old 08-25-2012, 09:55 AM
fookoo_2010's Avatar
Quoted: 245 Post(s)
Liked: 84
Looks very clever and looks really neat.
fookoo_2010 is offline
post #2704 of 9701 Old 08-25-2012, 10:14 AM
sjschaff's Avatar
Quoted: 83 Post(s)
Liked: 26
Seems you've got some sync issues but it's not clear what options you have. On the display your color space is either normal or wide which suggests Video or PC which probably isn't the problem. I'd write down all of you current settings and then start by restoring to factory defaults and moving from there. One setting, 1080p pure direct may need to be enabled for 4:4:4 enablement, since the Tivo probably puts out 4:4:4 I think. Good luck.
JVC RS500 - Stewart Firehawk - Lumagen Radiance Pro - Anthem D2V - Revel Salon speakers - SV Sound SB13 Ultra sub - Various sources
sjschaff is offline
post #2705 of 9701 Old 08-25-2012, 11:00 AM
BakeApples's Avatar
Quoted: 334 Post(s)
Liked: 179
Finally, my Darblet showed up yesterday and have spent about 4 hours with the unit today testing it out. I have it hooked up with a Oppo 93 bd player & Sony VW85 projector shooting at a white 114" Grandview 2.35:1 screen.
The setup was very easy and after changing the default "full pop" mode to the hi-def instead i started out with playing some blu-ray content. My testing disc was "3 10 to Yuma" and i set the Darblet to around 45 - 50% in Hi-Def mode which i thought looked the best. I then did a lot of On/Off switching in various scenes and the result is nothing but amazing! The picture looks so much better with more detail and pop. When turning the unit off the picture instantly looks more soft and unsharp. It really is fantastic what this little box is doing to the picture smile.gif
Thank you Darbee for this great product & AVS for the fast shipping.
Sony VPL-VW550 | DNP Supernova 08-85 116" 2.35:1 | Lumagen Radiance Pro 4440 | Pioneer SC-LX89 | AppleTV 4K | Zappiti One 4k HDR | PS4 | Audio Pro/Pioneer 5.1.4 Atmos | SVS SB-1000
BakeApples is offline
post #2706 of 9701 Old 08-25-2012, 11:09 AM
dragonbud0's Avatar
Quoted: 121 Post(s)
Liked: 64
I finally watched NFL preseason last night on Cablevision with either HD or Pop; decided to stay w/ HD since Pop really did not do much for me at HD 50%. It seems that my JVC has a DLP look (pop) w/o RBE, best of both world.
Darbee is a keeper.
Also watched Four Feathers DVD; at HD 50, it was very grainy since either the transfer was poor or grainy. GIGO applies.
I will try Last of the Mohicans tonight on BR, one of my favorites movie and soundtrack.
dragonbud0 is offline
post #2707 of 9701 Old 08-25-2012, 12:56 PM
sjschaff's Avatar
Quoted: 83 Post(s)
Liked: 26
Originally Posted by dreaux View Post
He says who he is every time he posts with the name DarbeeDr. He has been providing some great insights and tips.
Covered long, long ago in post #58
sjschaff is offline
post #2708 of 9701 Old 08-25-2012, 02:07 PM
moviegk61's Avatar
Looks like mine shipped friday! Am excited to see if this will bring my "old" Pioneer FPJ1, (re-badged JVC RS2), back to life. I will be using with sources- Panasonic DMP-BD85 bluray player, Dish 722 sat rec, Tosh HD DVD player, Sony Playstation switched in an Integra DTC-9.8 AV Controller into the Darbee then on to my Radiance XS and on to the projector. This path is easiest for now with current theatre layout. Any suggestions? Thanks, Doug G.
moviegk61 is offline
post #2709 of 9701 Old 08-25-2012, 02:19 PM
sjschaff's Avatar
Quoted: 83 Post(s)
Liked: 26
So all of your devices are going into the Integra and then you're sending video to the Radiance, via one of the two HDMI outputs. That means you've only one setting on the Radiance to control input (e.g. for color space, etc.). Guess it's AUTO for you for that piece of the puzzle. I do suggest you try using 4:4:4 on both the output of the Radiance and on the projector input (if that one allows). You still will likely see the magenta flashing issue when changing from 1080i to 720p sources or maybe other sources, unless you go RGB throughout. And at least you won't have the audio delays I experience by splitting the output of my XS between the input side of the Integra and the projector's input.
sjschaff is offline
post #2710 of 9701 Old 08-25-2012, 02:19 PM
Cliff Anckaitis's Avatar
Sorry for asking such a dumb question, but the Darbee only has one HDMI input and since i am using it in a room without an AV reveiever can i put a 2 into 1 HDMI in front of it to handle Blue and cable box signals?
Cliff Anckaitis is offline
post #2711 of 9701 Old 08-25-2012, 02:42 PM
mattg3's Avatar
Quoted: 383 Post(s)
Liked: 202
Does the darbee turn on automatically when it receives a video source and stay in a standby mode the rest of the time?Does the unit get hot, since i will be putting it on top of my Oppo 83
Matt
mattg3 is offline
post #2712 of 9701 Old 08-25-2012, 03:02 PM
sjschaff's Avatar
Quoted: 83 Post(s)
Liked: 26
Gets a bit warm but you'd be doing what I've done, putting it atop my Oppo. Seems that neither device should impact on the other. But if you're concerned separate the two with a book, or some such. And it's designed to always be "on" using about 1 amp or less. Not a vampire at all as an energy hog.
sjschaff is offline
post #2713 of 9701 Old 08-25-2012, 03:03 PM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
Just keep in mind that EACH adapter may yeild a couple or more DB drop/loss of signal.
For long HDMI runs, this could be an issue.
2016
42Plasmaman is offline
post #2714 of 9701 Old 08-25-2012, 03:40 PM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
Yes. I'm doing it.
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #2715 of 9701 Old 08-25-2012, 04:45 PM
CRAZZZY's Avatar
Quoted: 91 Post(s)
Liked: 107
Not a dumb question and yes it works. This is an oppo Hdmi switcher before the Darblet.
http://imageshack.us/photo/my-images/41/imagehhm.jpg/
My other configuration is a Key Digital hdmi switcher before the Darblet.
Hope this helps.
CRAZZZY is offline
post #2716 of 9701 Old 08-25-2012, 05:01 PM
Thunderduck's Avatar
Quoted: 54 Post(s)
Liked: 25
Earlier today when I checked, SolidSignal at Amazon was listing 2 different devices for $294. Are they both the same? If not, what are the differences? I would want the updated device so it would not have to be returned. Must admit I am not thrilled with the need to return it for updating in the future.
Thank you for help.
Steve
Thunderduck is offline
post #2717 of 9701 Old 08-25-2012, 05:28 PM
DarbeeDr's Avatar
thanks for sharing. That's cool that Paul Darbee finally got to see e-shift + the darbee on a large screen. Did he have any specific comments on the e-shift?
Sorry for the delay in giving a big thanks to Murray for hosting such a great event.
Murray's home theater set up provided an image and sound fidelity than was breathtaking. The audio was cleaner and tighter than an IMAX experience and the image quality was astonishing. Definitely a happy platform for the Darblet. We particularly like 2D version of movies that were composed and filmed with the idea of maximizing dimensionality in the scene (lots of scenes where objects are interposed in depth and textures of many sizes) were greatly appreciated (Hugo and Tin Tin).
Visual Presence + e-shift is sublime. It simply makes you happy.
-DD
DarbeeDr is offline
post #2718 of 9701 Old 08-25-2012, 05:32 PM
mattg3's Avatar
Quoted: 383 Post(s)
Liked: 202
Sending back for updates is a very strange business model.Cant imagine the confusion of these coming back to company whenever a change is provided.What would need to be updated?Perhaps only in rare situations with system problems in ones components would they need some attention.Wonder how many have already had to send their darbees back for an update?
Matt
mattg3 is offline
post #2719 of 9701 Old 08-25-2012, 05:42 PM
andy sullivan's Avatar
Quoted: 773 Post(s)
Liked: 406
Just ordered mine from AV. Curios about two things. Why is there a waiting period from AV but Amazon shows 15 in stock? Any thoughts on how much improvement I will see in my Sony 60A3000. I love the PQ right now on my Sony. I'll be up grading later this year to a Sharp 80LE632/844 or a 70LE847. Thanks.
andy sullivan is offline
post #2720 of 9701 Old 08-25-2012, 05:51 PM
sjschaff's Avatar
Quoted: 83 Post(s)
Liked: 26
If you visit the DarbeeVision site you'll see that they don't sell direct but through numerous players, one of whom is Solid Signal. They are the ones listed as the provider that Amazon is listing. Typical of Amazon to source product from others.
sjschaff is offline
post #2721 of 9701 Old 08-25-2012, 07:18 PM
We have plenty more coming this week. Please support AV Science and order from us. We are only an email or phone call away.
DaGamePimp likes this.
AV Science Sales 4 is offline
post #2722 of 9701 Old 08-25-2012, 08:51 PM
zombie10k's Avatar
Quoted: 3859 Post(s)
Liked: 3942
-DD
It's good you guys finally got to see the Darbee + the JVC e-shift. This is a perfect combo of two different technologies that looks great on my 142" screen.
zombie10k is online now
post #2723 of 9701 Old 08-25-2012, 09:21 PM
RapalloAV's Avatar
Quoted: 1644 Post(s)
Liked: 479
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is offline
post #2724 of 9701 Old 08-25-2012, 09:58 PM
pwiss's Avatar
Received my Darblet earlier today and have been running it through the paces. I have it connected between my DVDO Edge and my Panasonic 60ST50. What a fantastic device. I have ended up using the HD setting at 50. Like many others have said it brings out the detail without showing any adverse effects. I did read some reviews on the UK forums and they still seem to be taking the purist approach. I do feel however that if this chip is used in future TV/Projector models and was automatically set at somewhere around the HD 45-55 range they and everyone would be praising that display for the incredible amount of detail it has vs the competition. By the way mine was delivered with the latest firmware and it is outputting the proper colorspace and have had zero issues at all with the device.
pwiss is offline
post #2725 of 9701 Old 08-26-2012, 03:37 AM
DaGamePimp's Avatar
Quoted: 449 Post(s)
Liked: 501
On the waiting list awaiting the e-mail saying they are in and ready to ship. biggrin.gif
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #2726 of 9701 Old 08-26-2012, 09:04 AM
BFJ 96's Avatar
Quoted: 174 Post(s)
Liked: 100
Signed-up for e-mail confirmation once you have them in stock.
BFJ 96 is online now
post #2727 of 9701 Old 08-26-2012, 10:23 AM
DarbeeDr's Avatar
Originally Posted by noah katz View Post
How the heck do you get the Darbee % display at the lower right of the screen to go away?
I tried everything I could think of - change settings, turn on/off, go in and out of menus - but it always comes back.
No way was I going to watch with that distraction, so no definitive report to make.
Open Menu
Settings-->Logo Properties-->Do Not Persist
-DD
DarbeeDr is offline
post #2728 of 9701 Old 08-26-2012, 10:28 AM
DarbeeDr's Avatar
The Darblet is power up, when plugged into a power supply.
The Darbee Visual Presence processing can be toggled On/Off by using the physical button on the unit, or the Darbee On/Off on the remote.
The Darblet is designed to stay plugged in all the time. It may get warm , but should not get "hot" under normal operating conditions, even sitting on a Blu-ray player.
-DD
DarbeeDr is offline
post #2729 of 9701 Old 08-26-2012, 10:31 AM
DarbeeDr's Avatar
Thank you for help.
Steve
Their advertisement is confusing and we are working with them to correct the situation.
There is only one Darblet product/model.
-DD
DarbeeDr is offline
post #2730 of 9701 Old 08-26-2012, 11:13 AM
buzzard767's Avatar
Liked: 2439
-DD
Speaking of confusing, I recently viewed a web page showing an ee ColorBox used with Darbee tech. Do you still use the ee or has it been replaced by the Darblet?
Buzz
Reply Video Processors
Darbeevision Darblet Hdmi Video Processor
