Another HDMI Splitter thread.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-12-2012, 05:47 AM - Thread Starter
vision-master's Avatar
Liked: 24
Want to connect (2) monitors (HDMI) to windows 7. My current computer has one (1) HDMI output (desktop app) but I am in the proccess of connecting another monitor with a 25ft HDMI cable.
Sounds like most of the splitters are buggy and quit working after a spell?
vision-master is offline
post #2 of 10 Old 05-12-2012, 07:41 AM
RobertR's Avatar
Quoted: 403 Post(s)
Liked: 563
My Monoprice splitter's been working fine so far (I've had it about a week).
RobertR is online now
post #3 of 10 Old 05-12-2012, 08:00 AM - Thread Starter
Liked: 24
I've heard of them. Is it made in China?
post #4 of 10 Old 05-12-2012, 11:32 AM
gmanhdtv's Avatar
Quoted: 30 Post(s)
It is easier to keep track of what IS NOT made in China!
gmanhdtv is offline
post #5 of 10 Old 05-13-2012, 02:32 AM
RapalloAV's Avatar
Quoted: 1306 Post(s)
Liked: 292
What usually stops working after some time is not the splitter but instead is the power pack, often the ones from China are poorly manufactured.
Murray Thompson
X Owner RapalloAV
Absolutly no connection with RapalloNZ
CinemascopE Home Cinema Build & 2014 rebuild
RapalloAV is online now
post #6 of 10 Old 05-13-2012, 08:03 AM - Thread Starter
Liked: 24
How about installing another HDMI computer card and running both at the same time?
post #7 of 10 Old 05-13-2012, 08:22 AM
rovingtravler's Avatar
do you have DVI or Display port on your computer? You should be aboe to run both at the same time as long as you do not need sound. Or if you only need sound at one use the HDMI for that display and DVI or display port for the other.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #8 of 10 Old 05-13-2012, 08:25 AM
bluechunks's Avatar
Quoted: 85 Post(s)
Liked: 117
That could work, and is very common in "gaming" rigs and workstations, but you would have to be specific with your selection of a secondary video card. I'd suggest posing the question over in the HTPC section with your detailed system specs including your current card.
IMHO, a passive monoprice splitter sounds much easier to install, configure, and maintain. And it would be less expensive as a bonus. At less than $25 it borders on disposable if you have to replace it occasionally.
__________
4K madness: Visio P65-C1 (4K HDR10 & DV) / Oppo UDP-203 / Nvidia Shield / Roku Ultra / TiVo Bolt
Yamaha RX-A2060 5.1.4 / KEF iQ & Speakercraft (Ceiling) - Celerity 50' Fiber Optic HDMI between AVR and TV
bluechunks is online now
post #9 of 10 Old 05-13-2012, 01:05 PM - Thread Starter
Liked: 24
Just wondering what experience others have had with these splitters?
post #10 of 10 Old 05-13-2012, 01:11 PM - Thread Starter
Liked: 24
I've thought of that one, may have to try it?
Reply Video Processors
