Best component video to VGA (RGBHV) converter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-22-2012, 08:30 PM - Thread Starter
PublicSectorTech's Avatar
Hello ladies'n'gents!
Hope I am posting this in the right place...I got a projector that can do side-by-side split screen with 2 sources...which will mainly be used to watch sports/play video games at the same time. However, my projector apparently does not support 2 HDMI sources at once, and 1 component is already used, so that leaves my VGA input if I want to do 2 HD sources at once. Unfortunately, I can't tell my projector (Epson) that the component source I'm feeding it through an adapter is YPrPb rather than RGB...so I'm off to get a signal converter.
Has anyone used a component-to-VGA converter? If so, what should I look for? Are there any you recommend?
Thanks so much for your time!
Twitter: Gizzmonic
PSN: Gizzmonic
PublicSectorTech is offline
post #2 of 8 Old 05-23-2012, 06:38 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Definitely the Crescendo RTC2000 or 2200 transcoders available at Curt Palme.
I have used others, like Key Digital, Audio Authority, Burosch and Kramer. The Kramer is much more expensive than the Crescendo, the AA is somtimes cheap on cheap but suffers from low bandwith (slightly blurry output with HD). KD is about the same price as the Crescendo, but I prefer the Crescendo. Burosch is nice as well, but you won't find it in the US.
Fudoh is offline
post #3 of 8 Old 05-23-2012, 07:59 AM
Ericglo's Avatar
Quoted: 2161 Post(s)
Liked: 1046
Ditto. I had one with my CRT and it worked flawlessly.
Current projector - JVC RS25 and Marantz VP15S1
Future projector - pre-ordered new JVC from AVScience
Ericglo is online now
post #4 of 8 Old 05-23-2012, 08:16 AM
DonoMan's Avatar
This is probably not the "best" but I'd imagine it works fine (the brand is at least somewhat reputable): http://www.audioauthority.com/product_details/9A65 - it can be found for pretty cheap sometimes
"Vintage" is good for wine, not for A/V equipment.
-Dan D.
DonoMan is offline
post #5 of 8 Old 05-23-2012, 10:04 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
The AA trancoder is really fine for 480p, but as stated above, the picture gets kinda soft with HD sources due to limited bandwith.
Fudoh is offline
post #6 of 8 Old 05-23-2012, 11:01 AM
DonoMan's Avatar
Sorry, didn't notice you mentioned that in your other post. I have a bad habit of only reading half of a post sometimes... Thanks for the info.
-Dan D.
DonoMan is offline
post #7 of 8 Old 07-31-2013, 08:43 AM
SCCHelpdesk's Avatar
Hello,
I looked at the RTC2200 and wanted to know what to expect if I tried to push the signal further than the recommendation of 50 ft?
I am thinking at least 75ft, but less than 125ft.
Are there other products that are more robust for longer cable runs?
My desired goal is to route a new Blu-Ray DVD player from the sound booth, to the 2 projectors in the auditorium with audio going through the sound board which feeds the "house" speakers.
Board is an Avid Venue SC48
James
SCCHelpdesk is offline
post #8 of 8 Old 07-31-2013, 10:45 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
New BD players don't even have component ouputs anymore, so the cable length is the least of your problems.
If you want to use a current BD player you need a HDMI to VGA converter like the HDFury instead. And if you want to run cable lengths like these you might want to use a HDMI to CAT.5 extender (before the converter) or a VGA to CAT.5 extender (after the converter) instead. This way you can keep the video cables short and simply run ethernet cables for the longest part of your distance.
Fudoh is offline
Reply Video Processors
