Do you use DVDO iscan duo with Bryston SP2? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-17-2012, 01:05 PM - Thread Starter
sharok's Avatar
Quoted: 218 Post(s)
Liked: 68
If you have a DVDO iscan duo with Bryston SP2, do you have a lipsync issue?
How would you compensate for that, since SP2 doesn't implement audio delay other than speaker distance?
sharok is online now
post #2 of 4 Old 07-17-2012, 01:31 PM
slb
slb's Avatar
I believe that you can manually adjust the audio delay in the Duo. Wouldn't this allow you to compensate?
slb is offline
post #3 of 4 Old 07-29-2012, 10:23 AM - Thread Starter
sharok's Avatar
Quoted: 218 Post(s)
Liked: 68
Can you adjust the audio delay in Duo while you have no audio cables connected to Duo?
post #4 of 4 Old 07-30-2012, 10:39 AM
slb
slb's Avatar
No, you would need to pass the audio through the Duo. The Duo automatically adjusts the audio delay based on the amount of video processing, but there is also a manual override that allows the delay to be fine tuned in 1mS increments.
slb is offline
Reply Video Processors
