HDMI switcher won't work with both projectors on - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-21-2012, 10:22 AM - Thread Starter
tigerninety's Avatar
Hello all,
My home theater setup includes a PS3, Wii, Sanyo PLV-Z3, and Panasonic AE4000U; an Onkyo TX SR805 receiver is the hub.
I've got two projectors because we had the Z3 first and, when I upgraded to the AE4000U, I decided I wanted to keep the Z3 in action for my kids to play games to reduce the wear on the AE4000U bulb.
I thought that a good solution would be to get an HDMI splitter to take the signal from the single HDMI out on the PLV-Z3 to go to both the Z3 and the AE4000U and then just use my Harmony remote to turn on whichever projector was appropriate, etc.
So, I got one of the cheap splitters (probable from Amazon) that has two HDMI-out ports on one side (along with power input for the switcher) and a single HDMI-in port on an adjacent side.
Basically, it works, except that if I have both of the projectors on, the Panasonic won't recognize the HDMI signal and just keeps flashing, looking for a signal. I have to physically switch the Sanyo projector off using the rocker switch. As soon as I do, the Panasonic recognizes the signal.
Any suggestions? By the way, I'm reluctant to invest in an expensive switcher because I'm thinking I might upgrade to a new receiver that has two HDMI outs built in.
Tiger
tigerninety is offline
Reply Video Processors
