Does anyone know what was new in the vp50 1.09 firmware? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-14-2012, 04:03 AM - Thread Starter
choddo's Avatar
A little background; I just had my PSU blow (again) and it seems to have damaged the unit. New PSU and I get no output picture.
I had a look at the Info on the front panel and it says I'm on 1.08 (though I could have sworn I had the latest) and 1.09 is 3 years old. Doesn't time fly. I can't find anything telling me what was new in 1.09, I might just try it but it means digging out the old laptop with the serial port etc! and it almost certainly won't solve the problem anyway.
choddo is offline
post #2 of 2 Old 09-01-2012, 11:44 AM
CRGINC's Avatar
Hi Choddo,
Yes the last firmware was 1.09. There isn't much difference in 1.08 and 1.09. 1.08 if I remember was a beta release and 1.09 may of been a formal release. There were some comments reagarding fixing some noise issues but I never upgaded past 1.08. I did speak with DVDO and their recomendation was if 1.08 had no problems don't bother with 1.09.
Good luck getting you VP50 running again. PM me if I can help.
CRGINC is offline
Reply Video Processors
