Connect laptop to Crystalio II - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-17-2012, 10:29 AM - Thread Starter
Dave Barton's Avatar
Just wondering what the most simple way to connect a laptop to the Crystalio II unit is so that I can run a Powerpoint off my projector. The projector itself does not seem to have VGA input so I am not sure what the best solution would be...
Dave Barton is offline
post #2 of 3 Old 08-17-2012, 10:33 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
The CII accepts RGBHV through 5 BNC ports. It's one of the Component inputs along with the two sync connectors next to it. You just need a VGA to BNC breakout cable.
Fudoh is offline
post #3 of 3 Old 08-17-2012, 10:37 AM - Thread Starter
Thanks...should have thought of that!
Reply Video Processors
