Would I benefit from a standalone VP - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-20-2012, 09:36 PM - Thread Starter
yaomizzle's Avatar
Liked: 26
I have a Yamaha z7 which has the ABT 2010 chip in it. Would I benefit from a standalone VP? (I ordered a darblet but that's irrelevant) I'm wondering if a DVDO or lumagen would benefit me
Sent from my Galaxy Nexus using Tapatalk 2
yaomizzle is offline
post #2 of 6 Old 08-21-2012, 08:02 AM
shenxiongpeng's Avatar
I think you will benefit a little from a standalone VP,which can help you to improve your skill in that field!
shenxiongpeng is offline
post #3 of 6 Old 08-21-2012, 01:04 PM - Thread Starter
yaomizzle's Avatar
Liked: 26
What more can it do then what my z7 is doing?
post #4 of 6 Old 08-21-2012, 02:19 PM
Tazishere's Avatar
I think it depends on what you want it for. If your z7 does upsacaling, and you're satisfied with the results, then it doesn't make sense to suppliment it. The Lumagem folks are rightfully proud of their VP. If you want it for something it does that you don't have right now, then it makes sense to buy it. It does every trick in the book. You will own it until 4k comes around. It won't become obsolete soon, if ever.
Tazishere is offline
post #5 of 6 Old 08-21-2012, 03:23 PM
bluechunks's Avatar
Quoted: 94 Post(s)
Liked: 125
The Lumagen or DVDO Duo might offer a benefit, if you need/want CMS (Color Management System) or specific output fine tuning options not available in the Yamaha.
FWIW, both the of the current DVDO units (Duo and Edge) use the same ABT 2010 chip so the de-interlacing/scaling performance will be similar, if not identical, to the Yamaha.
__________
4K madness: Visio P65-C1 (4K HDR10 & DV) / Oppo UDP-203 / Nvidia Shield / Roku Ultra / TiVo Bolt
1080P: Apple TV (4th gen) & Intel Nuc (LibreElec/Kodi)
Yamaha RX-A2060 5.1.4 / KEF iQ & Speakercraft (Ceiling) - Celerity 50' Fiber Optic HDMI between AVR and TV
bluechunks is offline
post #6 of 6 Old 08-21-2012, 07:04 PM - Thread Starter
yaomizzle's Avatar
Liked: 26
That's what I thought!! So I'm satisfied. I would recommend the darbee darblet to everyone! Just got mine hooked up and wow....
Sent from my GT-P7510 using Tapatalk 2
Reply Video Processors
