Need a video recorder - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-08-2012, 05:45 AM - Thread Starter
supermagicman's Avatar
Hope this is the correct forum for my problem.
I am in charge of recording our church's services every week. We have two video cameras that send to an A/V mixer with outputs to individual monitors and to an old DVD recorder. The DVD recorder is on its last leg and is giving us huge problems so I need to replace it.
What I would like is a video recorder that takes either S-video or composite video inputs, has at least one composite video output for monitoring and records to internal storage that can be copied to a thumb drive or maybe records to a removable SD card or something like that, so I can take it home and edit it for web deployment.
Thanks in advance.
supermagicman is offline
post #2 of 3 Old 10-08-2012, 01:41 PM
Tazishere's Avatar
You should probably post this question in the HTPC forum. A video card on a computer sounds like what you would need. Something like this, but I don't think it has plain composite out:
http://www.directron.com/haup1191.html
Tazishere is offline
post #3 of 3 Old 10-09-2012, 04:47 AM - Thread Starter
Thanks for the suggestion, but I would prefer to not use a PC. Was hoping there was a stand alone recorder that would fit my needs.
Reply Video Processors
