Forcing a 60Hz 720p 3D signal into 24Hz 1080p 3D. Does such a device exist? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 10-25-2012, 01:25 PM - Thread Starter
Flavius's Avatar
Liked: 46
My problem? 24Hz 1080p 3D movies can have MotionFlow enabled on my new Sony HX950. But 60Hz native 3D 720p games cannot. Even in non-Game modes, if the game is native 3D, no MotionFlow. No such issue for 2D games regardless of resolution.
So I am looking for a device that can trick my TV into thinking that my native 3D game outputting at 60Hz (30Hz per eye) in 720p is actuallly a 3D movie at 1080p 24Hz.
Does such a thing exist? Am I crazy? I know MotionFlow adds lag, etc, but please answer my question. smile.gif
Flavius is offline
post #2 of 10 Old 10-25-2012, 02:01 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
You cannot just convert 60Hz Material to 24fps if there's no 3:2 pulldown in it (which you find in movies). And if you tried, you'd be looking at serious judder and stuttering. So, I guess, no, there's nothing to do this.
Fudoh is offline
post #3 of 10 Old 10-25-2012, 03:48 PM
rfpublic's Avatar
Quoted: 21 Post(s)
All of the Lumagen Radiance video processors can be used to convert 720p60 Side-by-Side or Top-Bottom 3D to 1080p24 Frame-Packed 3D.
Randy Freeman
support@lumagen.com
rfpublic is offline
post #4 of 10 Old 10-25-2012, 04:03 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
yeah, technically, but forcing a "hard" conversion when there's no pulldown in the source material, isn't the way to go, is it ?
Fudoh is offline
post #5 of 10 Old 10-25-2012, 04:20 PM
rfpublic's Avatar
Quoted: 21 Post(s)
If someone can send us a short sample video, we can see how it looks. We probably only need 20 to 30 seconds of video.
Randy Freeman
support@lumagen.com
rfpublic is offline
post #6 of 10 Old 10-25-2012, 06:34 PM - Thread Starter
Flavius's Avatar
Liked: 46
But MotionFlow would eliminate judder and stuttering, which is what I am trying to achieve for 3D games.
Flavius is offline
post #7 of 10 Old 10-25-2012, 06:35 PM - Thread Starter
Flavius's Avatar
Liked: 46
Randy Freeman
support@lumagen.com
But what about 720p60 Frame Packed? Can it convert that to 1080p24 Frame Packed? If so, might have to but one of these Lumagens!
Flavius is offline
post #8 of 10 Old 10-25-2012, 09:37 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
doesn't work. Motionflow compensates a lack of frames, but requires a constant fps nevertheless.
I mean, just try this on a PC. Just convert a 30fps video file (video-based, not film based, any smooth movement) to 24 frames and take it to your Sony afterwards. You won't like the result.
Fudoh is offline
post #9 of 10 Old 10-31-2012, 11:27 AM
rfpublic's Avatar
Quoted: 21 Post(s)
Originally Posted by Flavius View Post
But what about 720p60 Frame Packed? Can it convert that to 1080p24 Frame Packed?!
The Radiance won't work for this conversion. There isn't a way to pick out the correct frames from the 720p60 Frame-Packed signal.
Randy Freeman
rfpublic is offline
post #10 of 10 Old 06-17-2013, 09:26 PM
Jonathan Hersey's Avatar
What refresh rate is required for 3d? is 120hz just needed for frame sequential? I would think images that are put into one frame would work fine at Framepacked 60hz. Very confused
Jonathan Hersey is offline
Reply Video Processors
720p Vs 1080p , 1080p Vs 720p
