Given the Choice Between an iScan Duo and a Faroudja DVP-1080... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-21-2012, 03:32 PM - Thread Starter
DiscCollector's Avatar
Quoted: 16 Post(s)
...for the same price - which would you choose?
(Been out of the loop on video processors for a while)
I want upscaling to 1080p of 2 analog video sources (HLD-X9 laserdisc player and SVHS/DVHS deck), and possibly conversion of a 1080i satellite signal to 1080p.
The Faroudja was always tremendously lauded back in the day as the absolute best - but the DVDO iScan Duo is, presumably, newer technology (and the feature sheet seems to list a lot more capabilities e.g. mosquito noise reduction).
Which would you choose, if both are $800?
Is there something even better in this price range I should be looking at?
Thanks in advance for your help and comments,
DC
DiscCollector is offline
post #2 of 4 Old 11-22-2012, 03:06 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Between the two, get the Duo. If you're shopping 2nd hand, you can probably find a better price for the Duo here in the classifieds.
For your HLD-X9 get an external comb filter. I have the X9 and the Duo's comb filter doesn't cut it, neither does the X9's internal filter which heavily suffers from checkerboard artefacts.
If you can find one a Crystalio II would be nice. It has an excellent internal comb filter and excellent processing for LD.
Fudoh is offline
post #3 of 4 Old 11-22-2012, 01:57 PM - Thread Starter
Quoted: 16 Post(s)
The seller dropped the price on a brand new Faroudja DVP-1080 to $550 - so it's making it a tougher decision.
I doubt I'll find a Duo or Crystalio for anwhere near that price, and the Faroudja has an excellent comb filter from what I've heard.
What do you think?
post #4 of 4 Old 11-22-2012, 02:02 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
I don't like the SD processing of the later Faroudjas (1010 and 1080) very much.
There's an Iscan Duo available here in the classifieds section for $600. I think that's a better choice, even if you'll eventually be looking for a comb filter.
The Faroudja will give better results with very poor material, while the Duo will be considerably better with good sources.
Fudoh is offline
Reply Video Processors
