VHS conversion help - "jiggle" artifact - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-29-2012, 10:02 PM - Thread Starter
Dave Sieja's Avatar
Hello,
I have been recording old home movies to my computer using the elgato video capture device. I have also tried with a tv tuner card. Both gives the same results.
The issue is that the video capture records a "jiggle" when camera is being moved around a lot. However, it doesn't show up when I play directly to the tv.
Here is an example: http://www.youtube.com/watch?v=wFAJba3VxFY
Any help would be appreciated. Any software or hardware that can help with this? I tried running it through the tv then to the card, but it didnt work. The jiggle still shows up. I assume the Tv out is just a pass through. Something on the tv is stabilizing it. What can i put between the VCR and the tuner / elgato device to do the same? or is thee some software for this?
Dave Sieja is offline
post #2 of 3 Old 11-30-2012, 03:54 PM
bluechunks's Avatar
Quoted: 94 Post(s)
Liked: 125
It's been a while since I played with analog video out of a VHS deck but I'd suspect the fix is a device called a Time Based Corrector that will keep your video in sync between the two devices.
__________
4K madness: Visio P65-C1 (4K HDR10 & DV) / Oppo UDP-203 / Nvidia Shield / Roku Ultra / TiVo Bolt
1080P: Apple TV (4th gen) & Intel Nuc (LibreElec/Kodi)
Yamaha RX-A2060 5.1.4 / KEF iQ & Speakercraft (Ceiling) - Celerity 50' Fiber Optic HDMI between AVR and TV
bluechunks is online now
post #3 of 3 Old 11-30-2012, 04:34 PM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
Yeah, you definitely need a TBC.
Some better SVHS decks or DVD or HDD recorders have this built into them, so if you simply route the video through the deck first and then into the recording device you should be fine.
Maybe you something standing around ? Or friends, or neighbours ?
Fudoh is offline
Reply Video Processors
