looking for a hdmi switch that will let me split screen output to a projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-10-2012, 12:34 PM - Thread Starter
jtbullet's Avatar
jtbullet is offline
post #2 of 5 Old 12-10-2012, 12:57 PM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1770
In general, a switch lets you select among several different inputs, so that one of them goes to a single display, which can be a projector or a TV.
Your question is rather ambiguous, though.
Do you mean you want to view two separate images with the same projector at the same time? For that you'd need electronics which supports PIP (Picture in Picture).
Or do you want to view the same image on two different displays at the same time, one of them being a projector? For that you would normally use a splitter.
If you want to select from several different sources and send a different image to each of several different displays, you'd need what's called a matrix switch.
Selden
Selden Ball is offline
post #3 of 5 Old 12-10-2012, 01:23 PM - Thread Starter
jtbullet's Avatar
Sorry for the confusion! I am putting in a projector that does not have split screen capabilities. I was hoping to find a device that would output the splitscreen before it hits the projector.
Regards!
jtbullet is offline
post #4 of 5 Old 12-10-2012, 01:27 PM
Liked: 1770
A Web search for "split screen video processor" located quite a few.
e.g.
http://www.ambery.com/spscvipr.html
I don't have any experience with any of them.
Selden
post #5 of 5 Old 12-10-2012, 01:57 PM - Thread Starter
jtbullet's Avatar
I appreciate it! Hopefully I can find something acceptable. I can go with the epson 3020, it has it built in, but its got a lot of lag for gaming.
jtbullet is offline
Reply Video Processors
