Does the dvdo edge green zoom or scal 16:9 to CinemaScope - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-23-2012, 01:45 AM - Thread Starter
amb1s1's Avatar
I would like to know if the edge green can either zoom 16:9 to make it look like cinemascope? Or scale to CinemaScope? I see the iscan duo doing this in YouTube, but I have not see the edge. Thanks
amb1s1 is offline
post #2 of 3 Old 12-23-2012, 03:14 AM
Kelvin1965S's Avatar
Quoted: 257 Post(s)
Liked: 153
The Edge can do vertical stretch and horizontal squeeze for use with an A Lens, but I'm pretty sure it can't do the 16:9 shrink then stretch width to 2.35:1 like the Lumagen can.
However, please be aware that as impressive as the you tube clips of this might look, that the stretched 16:9 to 2.35:1 is done at a lower resolution as the black bars from 2.35:1 are zoomed off the screen, so only 1920 x 810 pixels are used: The 16:9 unstretched content is then viewed in a 'window' within the 2.35:1 screen at approx 1400 x 810, then when stretched to fill the width of th 2.35:1 screen it uses the 1920 x 810 section.
I used the shrink method myself with my Lumagen before I got a lens and it's useful for menus and trailers, but wasting resolution for a whole 16:9 film, so I would always rezoom for these films to get the full 1920 x 1080 image.
"Don't believe everything you read on the internet". William Shakespeare 1615
Kelvin1965S is offline
post #3 of 3 Old 01-12-2013, 09:02 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
How using anamorphic lens makes itmhigher resolution? The data is still 1920 x 810. You only stretch it to full sensor and squeezing it back to get hgher brightness, not resolution.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
Reply Video Processors
