Crystallio II VPS3800 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-07-2013, 04:44 PM - Thread Starter
lonewolf77's Avatar
Hey Guys,
I have a Crystallio II VSP3800. Which i had upgraded from a VP50 which had been upgraded from a VP30+ ABT102D card.
The reason why i state all 3 VPs that i currently have, is due to the fact that i have an opportunity to buy a DVDO ISCAN Duo at the moment and was considering it as its a lot newer than all my other VPs and i presume the technology would have improved and gotten more advanced. It also has more HDMI inputs and outputs and supports 1.3 which is more compatible with my needs probably. I wanted to get peoples opinions on how it would compare with my current VPs especially the Crystallio and the VP50..
I have a JVC HD550 projector and a Samsung 58" Plasma. My sources are Satellite HD TV (has a lot of SD channels on it too although i mainly try to watch HD on it), PC, Xbox360, PS3 and HTPC.
lonewolf77 is offline
post #2 of 2 Old 01-08-2013, 04:03 AM
Fudoh's Avatar
Quoted: 23 Post(s)
Liked: 27
The Duo (CMS aside) has the processing nearly identical to the 50Pro and the Edge. Compared to the VP50 that's the same deinterlacing, but with a sharper and more aggressive scaling engine. The VXP in your CII is much smoother when it comes to scaling. I could imagine that you prefer the Duo on a small screen, but on a projector it's hard to switch from a CII to a current DVDO machine.
Fudoh is offline
Reply Video Processors
